Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 31st Jan 2013, 15:27   #1
LennyRhys
Silenced
LennyRhys's Avatar
LennyRhys is almost as Godly as yodasarmpitLennyRhys is almost as Godly as yodasarmpitLennyRhys is almost as Godly as yodasarmpitLennyRhys is almost as Godly as yodasarmpitLennyRhys is almost as Godly as yodasarmpitLennyRhys is almost as Godly as yodasarmpitLennyRhys is almost as Godly as yodasarmpitLennyRhys is almost as Godly as yodasarmpitLennyRhys is almost as Godly as yodasarmpitLennyRhys is almost as Godly as yodasarmpitLennyRhys is almost as Godly as yodasarmpit
GTX 480 SLI Power Draw - Figures Revealed
Well you got there in the end Here are the figures from my "rigorous" testing:
(Power draw was measured at the wall for the entire system, not just the GPUs)
1) Heaven Benchmark, both cards at stock: 585W (peak)
2) Heaven Benchmark, both cards at SOC speed: 608W (peak)
3) Furmark Burn Test, both cards at stock: 610W (peak)
4) Furmark Burn Test, both cards at SOC speed: 661W (peak)
I was amazed to see such low figures given how much "power hog" propaganda there is about the GTX 480. Well this should dispel any myths...even with both GPUs overclocked significantly (and overvolted), the power draw at 99% load stayed well below 700W.
I'm currently installing the latest F@H client to see how it compares with Furmark.
__________________
i7 930 @ 4.2 :: Gigabyte X58 USB3 :: 6GB Elpida @ 1528MHz 6-7-6-18-1T
GTX480 SE :: Toughpower 775w :: 320GB & 2TB :: Cherry G80-3000HSMGB
LennyRhys is offline   Reply With Quote
Old 31st Jan 2013, 15:44   #2
Parge
Do you even mod, bro?
Parge's Avatar
Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.
778W
__________________
Deep Silence 1 - 2500K @4.5Ghz - Gigabyte UD7 - GTX 670 - 16GB 1866mhz Tactical Tracer - 240GB Vertex 3 - Xonar DX - U3011
Pump/MCP 355 - CPU/EK Supreme HF Nickel Plexi - GPU/EK Nickel Acetal Full Cover - Rads/2x EK 240 XTX - Fans/6x Gentle Typhoon 1850s - Controller/BigNG
Parge is offline   Reply With Quote
Old 31st Jan 2013, 16:17   #3
fuus
Confessed Rep Addict
fuus's Avatar
fuus is definitely a rep cheat.fuus is definitely a rep cheat.fuus is definitely a rep cheat.fuus is definitely a rep cheat.fuus is definitely a rep cheat.fuus is definitely a rep cheat.fuus is definitely a rep cheat.fuus is definitely a rep cheat.fuus is definitely a rep cheat.fuus is definitely a rep cheat.fuus is definitely a rep cheat.
900W
__________________
:: i5 3570k :: EVGA GTX 670 :: Z77X D3H :: 8GB RAM :: 800W PSU :: Filco with Browns :: 23' 1920x1080 :: 19' 1440x900 :: Microlab FC360 ::
GiffGaff
fuus is online now   Reply With Quote
Old 31st Jan 2013, 16:25   #4
Teelzebub
Satan the one true God / Modarator
Teelzebub's Avatar
Teelzebub is definitely a rep cheat.Teelzebub is definitely a rep cheat.Teelzebub is definitely a rep cheat.Teelzebub is definitely a rep cheat.Teelzebub is definitely a rep cheat.Teelzebub is definitely a rep cheat.Teelzebub is definitely a rep cheat.Teelzebub is definitely a rep cheat.Teelzebub is definitely a rep cheat.Teelzebub is definitely a rep cheat.Teelzebub is definitely a rep cheat.
823W
What do we get if we win
__________________
Before buying from someone on the MP please read the rules and the Problematic sales on the Market Place http://forums.bit-tech.net/group.php?groupid=86
A large wooden box with screws, nails and a condom in it just to be on the safe side, All over clocked to the max I'm not boasting really I'm not
Teelzebub is offline   Reply With Quote
Old 31st Jan 2013, 17:34   #5
Parge
Parge's Avatar
Originally Posted by Teelzebub View Post
823W
Probably a burnt out Thermaltake Toughpower 775W
__________________
Old 31st Jan 2013, 17:41   #6
The_Crapman
MD of Mutant Zombie Armies Inc
The_Crapman's Avatar
The_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpit
836W
__________________
Project: RAt MoD:CPU:i5 3570K, Motherboard:ASUS Maximus 5 Gene, GPU:Gainward GTX 670 Phantom, Cooler:Modded Antec Kuhler 620, RAM:4GB 1600MHz G.Skill RipjawsX CL6, HDD: WD Raptor 150GB , PSU: Enermax Revolution 1050W Case: Antec P182, How to Get a FREE (sort of) Hard Drive and Other Small Parts.
The_Crapman is offline   Reply With Quote
Old 31st Jan 2013, 17:52   #7
fdbh96
I *am* a Dremel
fdbh96's Avatar
fdbh96 - it's over 9000!!!!!!!!1!1!1!!!fdbh96 - it's over 9000!!!!!!!!1!1!1!!!fdbh96 - it's over 9000!!!!!!!!1!1!1!!!fdbh96 - it's over 9000!!!!!!!!1!1!1!!!fdbh96 - it's over 9000!!!!!!!!1!1!1!!!fdbh96 - it's over 9000!!!!!!!!1!1!1!!!fdbh96 - it's over 9000!!!!!!!!1!1!1!!!fdbh96 - it's over 9000!!!!!!!!1!1!1!!!fdbh96 - it's over 9000!!!!!!!!1!1!1!!!fdbh96 - it's over 9000!!!!!!!!1!1!1!!!fdbh96 - it's over 9000!!!!!!!!1!1!1!!!
999W
fdbh96 is offline   Reply With Quote
Old 31st Jan 2013, 18:03   #8
LennyRhys
Silenced
LennyRhys's Avatar
LOLOL My Toughpower has survived much worse than this... it survived the short that killed my Bloodrage
Keep the guesses coming folks.
__________________
Old 31st Jan 2013, 18:03   #9
TaRkA DaHl
Ultramodder
TaRkA DaHl's Avatar
TaRkA DaHl is almost as Godly as yodasarmpitTaRkA DaHl is almost as Godly as yodasarmpitTaRkA DaHl is almost as Godly as yodasarmpitTaRkA DaHl is almost as Godly as yodasarmpitTaRkA DaHl is almost as Godly as yodasarmpitTaRkA DaHl is almost as Godly as yodasarmpitTaRkA DaHl is almost as Godly as yodasarmpitTaRkA DaHl is almost as Godly as yodasarmpitTaRkA DaHl is almost as Godly as yodasarmpitTaRkA DaHl is almost as Godly as yodasarmpitTaRkA DaHl is almost as Godly as yodasarmpit
947W.
Has to be higher than the PSU 'maximum' rating otherwise you probably wouldn't create a thread about it
TaRkA DaHl is offline   Reply With Quote
Old 31st Jan 2013, 18:07   #10
flame696
Terminating People Since 1980....
flame696's Avatar
flame696 - may the hammer of Bindi be bestowed on youflame696 - may the hammer of Bindi be bestowed on youflame696 - may the hammer of Bindi be bestowed on youflame696 - may the hammer of Bindi be bestowed on youflame696 - may the hammer of Bindi be bestowed on youflame696 - may the hammer of Bindi be bestowed on youflame696 - may the hammer of Bindi be bestowed on youflame696 - may the hammer of Bindi be bestowed on youflame696 - may the hammer of Bindi be bestowed on youflame696 - may the hammer of Bindi be bestowed on youflame696 - may the hammer of Bindi be bestowed on you
850w
__________________
The Rig: i7 3770K @ 4.6Ghz/ Asus Maximus Gene V/ 16Gb Corsair Vengeance (Red) / 120Gb Kingston V+200 SSD / Asus HD7970 / Corsair AX850 / CM Storm Trooper / Mionix Zibal 60 /
The Water: EK Supreme HF CPU Block / EK 7970 CSQ GPU Block / XSPC H2O 750 V4 / 2 x 240mm AlphaCool NeXXXos UT60 RADs /
The Project: Antec TwelvOrange
flame696 is offline   Reply With Quote
Old 31st Jan 2013, 18:16   #11
jizwizard
stop your grinning and drop your li
jizwizard's Avatar
jizwizard is almost as Godly as yodasarmpitjizwizard is almost as Godly as yodasarmpitjizwizard is almost as Godly as yodasarmpitjizwizard is almost as Godly as yodasarmpitjizwizard is almost as Godly as yodasarmpitjizwizard is almost as Godly as yodasarmpitjizwizard is almost as Godly as yodasarmpitjizwizard is almost as Godly as yodasarmpitjizwizard is almost as Godly as yodasarmpitjizwizard is almost as Godly as yodasarmpitjizwizard is almost as Godly as yodasarmpit
Well for the cards on there own your looking at 660w ish so high 900 low 1000
__________________
Bitfenix Prodigy / Asus p8z77-I deluxe / 2700k@5.2 / Samsung 2x4gb @ 2400mhz /
Hx1050 (overkill) / Gtx570 (soon to be 690) / 2x64gb M4 / WD 3tb book / BenQ 2410t
G19 / G27 / and some watercooling for good measure
jizwizard is online now   Reply With Quote
Old 31st Jan 2013, 18:18   #12
fuus
fuus's Avatar
1001W
__________________
GiffGaff
Old 31st Jan 2013, 18:19   #13
.//TuNdRa
Resident Bulldozer Guru
.//TuNdRa's Avatar
.//TuNdRa is a hoopy frood who really knows where their towel is..//TuNdRa is a hoopy frood who really knows where their towel is..//TuNdRa is a hoopy frood who really knows where their towel is..//TuNdRa is a hoopy frood who really knows where their towel is..//TuNdRa is a hoopy frood who really knows where their towel is..//TuNdRa is a hoopy frood who really knows where their towel is..//TuNdRa is a hoopy frood who really knows where their towel is..//TuNdRa is a hoopy frood who really knows where their towel is..//TuNdRa is a hoopy frood who really knows where their towel is..//TuNdRa is a hoopy frood who really knows where their towel is..//TuNdRa is a hoopy frood who really knows where their towel is.
God, at a guess? You must've been pulling way over the PSU's rated max from the wall, accounting for PSU efficiency, and how damn hungry 480's are under load. I'm hedging my bet at 790W.
__________________
Dozy Beast: AMD FX8120 | Thermalright Archon | Asus Crosshair V Formula | 16GB (4x4GB) Corsair Vengeance LP | Asus Xonar DX/XD | 2X SLI KFA2 550Ti White Edition | Silverstone SSTG1000W | Silverstone Raven RV-02B V1.7 | OCZ Agility 3 60GB | 1.5TB in Drives | Lite-on Blu-ray ROM
Dell 1908 | Sennheiser HD 485s | Creative Gigaworks T40s | Logitech G13 | Microsoft Sidewinder X6 | Cyborg R.A.T 9
.//TuNdRa is offline   Reply With Quote
Old 31st Jan 2013, 18:27   #14
Madness_3d
Bit-Tech/Asus OC Winner
Madness_3d's Avatar
Madness_3d - it's over 9000!!!!!!!!1!1!1!!!Madness_3d - it's over 9000!!!!!!!!1!1!1!!!Madness_3d - it's over 9000!!!!!!!!1!1!1!!!Madness_3d - it's over 9000!!!!!!!!1!1!1!!!Madness_3d - it's over 9000!!!!!!!!1!1!1!!!Madness_3d - it's over 9000!!!!!!!!1!1!1!!!Madness_3d - it's over 9000!!!!!!!!1!1!1!!!Madness_3d - it's over 9000!!!!!!!!1!1!1!!!Madness_3d - it's over 9000!!!!!!!!1!1!1!!!Madness_3d - it's over 9000!!!!!!!!1!1!1!!!Madness_3d - it's over 9000!!!!!!!!1!1!1!!!
775W? :P My system is 830W at the wall so given a 930 is a bit more efficient?
__________________
XFXScorpio911 ¦ PHENOM II X4 965 @ 4.02Ghz ¦ SLI GTX 480 1536MB¦ ASUS CROSSHAIR II FORMULA ¦ 4GB OCZ REAPER 1066 5-5-4-8 2T¦ CORSAIR HYDRO H50 ¦ CORSAIR F60 ¦ WINDOWS 7 HP 64bit ¦ Musings On The Technical World ¦ Steam
Madness_3d is offline   Reply With Quote
Old 31st Jan 2013, 19:03   #15
jizwizard
jizwizard's Avatar
The 930 will sup more power than your phenom but only just
__________________
Old 31st Jan 2013, 19:07   #16
Harlequin
I Mod, Therefore I Own
Harlequin's Avatar
Harlequin - may the hammer of Bindi be bestowed on youHarlequin - may the hammer of Bindi be bestowed on youHarlequin - may the hammer of Bindi be bestowed on youHarlequin - may the hammer of Bindi be bestowed on youHarlequin - may the hammer of Bindi be bestowed on youHarlequin - may the hammer of Bindi be bestowed on youHarlequin - may the hammer of Bindi be bestowed on youHarlequin - may the hammer of Bindi be bestowed on youHarlequin - may the hammer of Bindi be bestowed on youHarlequin - may the hammer of Bindi be bestowed on youHarlequin - may the hammer of Bindi be bestowed on you
850w
__________________
i have a 3dfx voodoo5 6000
Harlequin is online now   Reply With Quote
Old 31st Jan 2013, 21:07   #17
rollo
rollo should be considered for presidentrollo should be considered for presidentrollo should be considered for presidentrollo should be considered for presidentrollo should be considered for presidentrollo should be considered for presidentrollo should be considered for presidentrollo should be considered for presidentrollo should be considered for presidentrollo should be considered for presidentrollo should be considered for president
860-900 watts
you would break 1kw if you overclocked both cards.
and maybe if you broke out furmark you would see it as well.
Unique heaven does not stress the cards like furmark though
Id say 700 watts would be my guess.
rollo is offline   Reply With Quote
Old 1st Feb 2013, 07:11   #18
Pookeyhead
It's big, and it's clever.
Pookeyhead's Avatar
Pookeyhead is the Cheesecake. Relix smiles down upon them.Pookeyhead is the Cheesecake. Relix smiles down upon them.Pookeyhead is the Cheesecake. Relix smiles down upon them.Pookeyhead is the Cheesecake. Relix smiles down upon them.Pookeyhead is the Cheesecake. Relix smiles down upon them.Pookeyhead is the Cheesecake. Relix smiles down upon them.Pookeyhead is the Cheesecake. Relix smiles down upon them.Pookeyhead is the Cheesecake. Relix smiles down upon them.Pookeyhead is the Cheesecake. Relix smiles down upon them.Pookeyhead is the Cheesecake. Relix smiles down upon them.Pookeyhead is the Cheesecake. Relix smiles down upon them.
over 9000!!!
__________________
MAIN RIG |Intel i7 3960X @ 4.7GHz ¦¦ Asus Rampage IV Extreme ¦¦ 16Gb Mushkin DDR3 2133 ¦¦ 512GB Samsung 830 SSD ¦¦ 4TB of HDD Storage ¦¦ 4GB EVGA GTX670 Superclocked SLI ¦¦ Corsair 650D ¦¦ Eizo ColorEdge CG303W & Dell 2007FP ¦¦ Logitech Z623
EARTH| Celeron E3200 ¦¦ Gigabyte G31M-ES2L ¦¦ LSI SAS8704EM2 ¦¦ 3TB RAID5 ¦¦ Headless - VNC administered
MOON | Thecus N3200pro 3TB RAID5
Pookeyhead is offline   Reply With Quote
Old 1st Feb 2013, 09:33   #19
LennyRhys
Silenced
LennyRhys's Avatar
LOL Pookey
So far, rollo is far closer to the real figure than anybody else. He is also correct that Heaven doesn't stress the GPUs as much as Furmark might (but I ran Furmark too... all will be revealed shortly).
I'll give you a clue and I still don't think anybody will get it right:
Peak power draw for the entire system whilst running Heaven was below 700 watts.
Keep the guesses coming.
__________________
Old 1st Feb 2013, 09:38   #20
jinq-sea
Steering a Boat in Holland
jinq-sea's Avatar
jinq-sea is definitely a rep cheat.jinq-sea is definitely a rep cheat.jinq-sea is definitely a rep cheat.jinq-sea is definitely a rep cheat.jinq-sea is definitely a rep cheat.jinq-sea is definitely a rep cheat.jinq-sea is definitely a rep cheat.jinq-sea is definitely a rep cheat.jinq-sea is definitely a rep cheat.jinq-sea is definitely a rep cheat.jinq-sea is definitely a rep cheat.
698W?
__________________
"The Quiet Rig":
Maximus IV Extreme Z - i7 2600K @ 4.5GHz - Frio - 8Gb Ballistix Sport @ 1600 - Sapphire 7970 @ 1150/1550 - M4 256Gb - LG Blu-Ray - Seasonic G Series 650W - Fractal Design R4 - Asus VS247H - Logitech MX5000 - Digidesign 003 - KRK Rokit 5 G2s
jinq-sea is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
