Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 1st Feb 2013, 12:24   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
Scythe unveils Ashura cooler with 140 Hayabusa fan
New retaining clip design, clever fan.
http://www.bit-tech.net/news/hardwar...cythe-ashura/1
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is online now   Reply With Quote
Old 1st Feb 2013, 13:13   #2
Corky42
I Mod, Therefore I Own
Corky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming Saiyan
With so many CPU HS being large tower designs (at least top end air) is there anything more designers can do to get better cooling on air ?
There seems to be very little innovation now days in CPU HS
Corky42 is offline   Reply With Quote
Old 1st Feb 2013, 13:24   #3
dogknees
Multimodder
dogknees has yet to learn the way of the Dremeldogknees has yet to learn the way of the Dremeldogknees has yet to learn the way of the Dremeldogknees has yet to learn the way of the Dremeldogknees has yet to learn the way of the Dremeldogknees has yet to learn the way of the Dremeldogknees has yet to learn the way of the Dremel
I think they've gotten as good as they can for a reasonable cost. It's a bit like convergent evolution where everyone starts off with different, individual idea, but they all end up at almost the same place after a few cycles of optimisation.
I guess there aren't enough people prepared to pay significantly more for air cooling. I'd like to see what the manufacturers could do if they could charge what a good water cooling system costs. What could they do for $200+ I wonder.
Most of the change these days seems to be fiddling about with fan blade shapes, notches, slots,....
I agree, it's getting boring!
dogknees is offline   Reply With Quote
Old 1st Feb 2013, 14:04   #4
kingred
Surfacing sucks!
kingred's Avatar
kingred is definitely a rep cheat.kingred is definitely a rep cheat.kingred is definitely a rep cheat.kingred is definitely a rep cheat.kingred is definitely a rep cheat.kingred is definitely a rep cheat.kingred is definitely a rep cheat.kingred is definitely a rep cheat.kingred is definitely a rep cheat.kingred is definitely a rep cheat.kingred is definitely a rep cheat.
Cue the stretch Hyabusa jokes!
kingred is online now   Reply With Quote
Old 1st Feb 2013, 20:57   #5
Kacela
Minimodder
Kacela has yet to learn the way of the Dremel
The only reasonable improvement they could make to an air-cooled setup would be to use silver fins rather than aluminum. Silver is at least 50% higher in terms of thermal conductivity than aluminum, so yes, air-cooling could be made much more efficient within existing architectures, but obviously at a higher cost. I'd easily pay double for a silver finned air-cooled setup if I saw a 50% improvement in cooling efficiency over aluminum...
Kacela is offline   Reply With Quote
Old 1st Feb 2013, 23:07   #6
sixfootsideburns
modeteer
sixfootsideburns is definitely a rep cheat.sixfootsideburns is definitely a rep cheat.sixfootsideburns is definitely a rep cheat.sixfootsideburns is definitely a rep cheat.sixfootsideburns is definitely a rep cheat.sixfootsideburns is definitely a rep cheat.sixfootsideburns is definitely a rep cheat.sixfootsideburns is definitely a rep cheat.sixfootsideburns is definitely a rep cheat.sixfootsideburns is definitely a rep cheat.sixfootsideburns is definitely a rep cheat.
or copper... why would any company use a precious metal when they could use copper which is vastly cheaper and has nearly the same thermal conductivity. Silver is typically traded at about $32 USD/troy ounce and copper costs about $4 USD/lb
sixfootsideburns is offline   Reply With Quote
Old 2nd Feb 2013, 02:17   #7
Corky42
Carve the hole HS from the worlds biggest diamond....
Old 2nd Feb 2013, 02:26   #8
Maki role
Dale you're on a roll...
Maki role's Avatar
Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.
Well full copper heat sinks do exist, just look at the Thermalright True Copper for example. One major issue though is that copper is much denser than aluminium (8.97gcm^-3 vs 2.70gcm^-3) which leads to incredibly heavy heat sinks that are often simple too impractical to use. Certainly I don't think I'd want to strap on 2KG+ of metal onto my motherboard and CPU without a hefty amount of reinforcement.
Also a major bottleneck is simply air itself, changing the heat sink material honestly wouldn't make that much of a difference. What would make a bigger difference would be the quantity of air passing through, thus being able to remove as much heat as possible. Water cooling works so well mostly because you can have giant radiators that maximise the surface area available, leading to much more cool air being available in comparison to a standard heat sink.
__________________
Finished Builds: Azure, Vesper, Loramentum, Aetos, Exsectus (Tt UK Modding Trophy 1st Place)
Work in Progress: Cheers Luv!
Website: http://www.praetex-design.com Twitter: @Maki_Role Instagram: @Maki_Role
Maki role is offline   Reply With Quote
Old 2nd Feb 2013, 22:01   #9
brooksy
Supermodder
brooksy's Avatar
brooksy is a Super Spamming Saiyanbrooksy is a Super Spamming Saiyanbrooksy is a Super Spamming Saiyanbrooksy is a Super Spamming Saiyanbrooksy is a Super Spamming Saiyanbrooksy is a Super Spamming Saiyanbrooksy is a Super Spamming Saiyanbrooksy is a Super Spamming Saiyanbrooksy is a Super Spamming Saiyanbrooksy is a Super Spamming Saiyanbrooksy is a Super Spamming Saiyan
I bought Thermalright True Copper second hand from ebay it weighs a ton. I think I can sell it for scrap and make a fortune.
brooksy is offline   Reply With Quote
Old 3rd Feb 2013, 03:47   #10
dogknees
Multimodder
Agree. More, thinner, copper fins with more airflow/pressure drop across the stack. Ultimately it's the air that has to carry the heat away, so the more air you can move and the greater the surface area, the more heat you can shift. = More $$
Reply
Tags
140 hayabusa, air cooling, amd, ashura, hayabusa, heatsink, intel, scythe, scythe ashura, static pressure
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
