#1 |
Hypermodder
still unnamed SNES steampunk mod
Hy @ all!
we thought we should share this non-PC mod weīre currently building.... As base for our mod we use an old snes gaming console. We got it with a totally broken enclosure...but the electronics still works perfect....so we thought why not make a new case for the console so that it can be used again.... So the first thing we had to do, was to get rid of the rest of the original plastic case...so that we could start over just with the raw pcb of it... ![]() then we cut out a sheet of plexiglas which will be used to mount the pcb on it....therefore we had to make a few holes in it and also had to make a few spacers so that the pcb could be mounted like in its original case... ![]() ![]() ![]() After that we milled out the sidepanels for the new case... ![]() then we put the first parts together, just to test if the pcb fits in and to see if there were no problems with the height... ![]() As next we work out a nice matching theme for the sidepanels and engraved & cutted out a few brass parts... ![]()
#2 |
Hypermodder
Loving it so far
Good to see some old hardware given a new life in a really fancy enclosure ![]() /subscribe
__________________
"Psychology is just meta-hacking an OS that was randomly bashed out by a million monkeys on typewriters over a few billion years and runs on constantly changing, badly shielded hardware with a lot of legacy design issues. I think." - Nexxo www.mayaposch.com - my site and blog. www.nyanko.ws - my company's site. |
#3 |
There is no rep for awesomeness.
Moderator
Awesome!!!
__________________
"You actually hope to achieve your ideals, I just use mine as an excuse to hate everything" --specofdust "Right wing Republicans, all the murderousness of nut-job Iranian ayatollahs, none of the bearded coolness" --specofdust |
#4 |
I've got wood
Nice engraving on the side panels - did you do it by hand or with a CNC machine?
#5 |
Squid
Aaaaaawsome!! Im watching
#6 |
Professional Sleever & Modder
where is super metroiiid
#7 |
"Jammy..."
Steam NES
SEN Steam S punk NES SNEam S punk For the sake of clarity (internationalisation), they aren't genuine suggestions, and spunk probably isn't appropriate. But it looks like the dogs nads so far, so maybe it is appropriate. |
#8 |
Captin Calliope
that looks amazing...my snes is still going strong ^_^ would love to mod it eventually
__________________
I7 3770 @ 4.5Ghz | Asrock z77 extreme 6 | 16gb hyper X Ram 1600 | SfX7870 oc |Crucial 512 gb M4 | Samsung Spin point 2tb x2 | SiverStone Raven02 | Corsair Hx 850 |
#9 |
Hypermodder
thanks a lot m8īs!!!
@morgansk....they are done by our cnc , but there is no problem to do this by hand....we just did it...because...that way we can reuse the pictures on the game cartridge....Ok, but now itīs time for an update: as next we stained the wood parts so that we get a much darker color... ![]() beside that we sanded and polished the brass parts to get rid of the last uneveness in the surface which came from the engraving process ![]() ![]() then we made a stamp (positive + negative) and tried to emboss a thin sheet of metal with it....(first test) ![]() ![]()
#10 |
Supermodder
Nice, look forward to seeing it evolve .
__________________
Q6600 @ 3.0ghz | gigabyte g31m-es2l | 4gb crucial ballistix | 2GB XFX 6870 | antec 300 |Antec TruePower 550w | arctic cooling rev2 pro | 1tb wd caviar black
![]() Antec 300 mini mod |
#11 |
Multimodder
![]() ![]() subbed Looking forward to this. |
#12 |
Beyond Complexity Lies Simplicity
Nice, designing a Steampunk build myself too!
Subbed!
__________________
Current Build : BORG COSMOS II Current build : 2001 - A Case Modyssey Finished build : IMPERIAL AT-AT Finished Build : USS EURISKO - Intrepid Mark II Class www.asphiax.wordpress.com |
#13 |
Keep calm & mod on. =)
Awesome idea, scratch build for a classic console, if PC's go sideways I'll be doing a lot of that in the future.
![]() This is highly awesome, sooooo damn nice. ![]()
#14 |
Hypermodder
thanks a lot m8īs!!!!
in the last days we continued to work on it.... as first we cut out a few parts for the outter shell... ![]() beside that we prepared a few copper pipe pieces which will be used as a small chimney (with a small smoke generator in it).... ![]() ![]() then we worked on the wooden sidepanels....(stain/oil/wax) ![]() and last but not least we worked on the metal for the outter shell...first we embossed it before we bended the whole piece around our sidepanels.... ![]() ![]() ![]()
#15 |
Holy moly, embossing as well now.
![]() ![]() ![]() Really loving this, all these skills going together so nicely.
#16 |
↓ Don't trust that face!
You guys are having a lot of fun with this one.
I'm guessing the smoke maker will be from the model train industry?
__________________
#17 |
Minimodder
I really like the embossed detail using the stamps. Great trick!
#18 |
Squid
Mmmmmmm... Just mmmmmmm...
#19 | |
Hypermodder
itīs really a fun project...and the smoker is really from the model train industry ![]() And now, its time for an update again: First, we continued with a wooden slot for the Cartridges... ![]() ![]() ![]() as next we continued with a inner frame on which we could mount the outer shell.... ![]() ![]() And then, we started with the first game cartridges....first a quick disassembly to see whats exactly inside.... ![]() after that we directly started to make a cartridge out of wood.... ![]() ![]() Beside that we also painted a few inner parts and started to build a inner backside to hold all the connectors (AC;TV Out; On/Off).... ![]() ![]()
#20 |
Multimodder
looking niice
| Tags |
| babetech.de, bt-custompc.de, retro gaming console, snes, steampunk |
| Thread Tools | |
| View Mode | |
