Old 3rd Feb 2013, 00:35   #1
Furball Zen
Shut up and Mod
Furball Zen's Avatar
Furball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run Crysis
FBZ's WHS2011
New build!
Ive been tossing the idea of throwing together a WHS build using AMD's new FM2 socket APU chips. It doesnt need a lot of horsepower, but ive changed the specs and path this is taking. I know nothing about this mobo but i snagged it off eBay for CHEAP. I cant seem to find ANY images online, all the models have black heatsinks with either black or copper heat pipes.
Parts list:
Case: Acrylic
Mobo: DFI Lanbparty DK T2RS Plus
CPU: Q6600
Mem: Corsair TBD
PSU: Corsair CX430 or other depending on configuration
Cooling: Swiftech Apogee GTZ and other
OS Drive: Seagate ST3250312AS 250GB
Storage Drives: 4x Seagate ST31000524AS 1 TB in RAID 5.
Because of all the acronyms i decided to name this build: Acronymus.
Enter the drag... er DFI LP DK T2RS, my first DFI Intel board
Q6600 i snagged for free!
Couple colors of acrylic that will find its way into the build
Got a sweet idea on what I want to do to the case. If I can get sponsored I'm thinking dual 360 rads in a Sunbeam 9 bay case like I used in another build a few years back using the entire front for an intake but exhausting the rads out the sides. The drives would go in a stack behind them in front of the PSU and there would be a 120mm fan behind them drawing air over the 5 platters. PSU sleeving would be in reverse of Carbide. Video cards would probably be 4850's since the mobo only does dual 8x, unless I find like 3870x2's for a nice price. I would probably at that point find another Antec TPQ-850 to run it.
__________________
Life. Liberty. The pursuit of those who oppose it.
Guides: Modular PSU ~ FC foam removal Mods: Blue on Black ~ DVD-ROM Worklog: Acronymus ~ Carbide
@furballzen
Furball Zen is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
