#1 |
Supermodder
Is my GTX 670 crashing my PC?
I've had a MSI GTX 670 TF4 Power Edition for little over a month now.
Just now, for the 5th time, I just had my entire PC randomly shut off for a few seconds before restarting. I keep my CPU at stock speeds and a I have a tiny OC on my GPU. GPU Clock - 1055, Memory 1520, Boost - 1133. The highest temp I have seen it reach is slightly under 70C in BF3. I play everything max settings. It first happened when I was playing the new SimCity beta. At first I thought I might have OC'd a little to much, so I turned it down. The shut off happened again so I turned off all OC. And again, with no OC it shut off during the beta play. It has happened twice now while playing Boarderlands 2 (OC on, see above paragraph for current stats). In BL2, temp reaches a max of about 60C. I looking for some help to see what the problem might be. Rig in sig. Thanks for reading! Edit: 6th time, no OC, right after starting BL2.
__________________
i5-2500K l MSI P67A-GD65 l MSI Twin Frozr IV GTX 670 PE l 8GB G Skill l WD 500GB Caviar Black l Corsair HX750 l CM Hyper 212 Plus l NZXT Phantom Black l Last edited by WhiteKnight226; 4th Feb 2013 at 04:43. |
#2 |
Good news everyone!
Is there anything to go on in event viewer?
__________________
2500K | Corsair H55 | HIS 7950 | 8GB XMS3 | 128GB Crucial M4 | Samsung 2TB | ASRock H77M-ITX | Corsair CX500M | White Bitfenix Prodigy | Dell U2311H | Creative T6060s | Ducky G2 Pro TKL (Reds) | Logitech G500 Why. |
#3 |
Packaging Master!
What are your RAM speeds/timings? Are they all at stock? Voltages?
Also, how old is your PSU?
__________________
Bonnie i3-2100T | H61M-P31 | 4GB DDR3 1333MHz | 60GB OCZ Agility 3 SSD | GTX 260 |
#4 |
Supermodder
Changed ram in BIOS to 1600 as that is what I bought and psu is year and like 8 months. I'm starting to think it is afterburner or fraps doing it.
However this problem only started when I got the 670.
__________________
i5-2500K l MSI P67A-GD65 l MSI Twin Frozr IV GTX 670 PE l 8GB G Skill l WD 500GB Caviar Black l Corsair HX750 l CM Hyper 212 Plus l NZXT Phantom Black l |
#5 |
Packaging Master!
Did you use Driver sweeper to completely remove your GPU drivers before installing the 670?
What voltage is your RAM? What voltage is it running at currently?
__________________
#6 |
No disassemble!
Wasn't there an issue reported with the MSI Power edition cards?
Something about their excessive overvolting causing errors and failures?
__________________
Before you judge a man, walk a mile in his shoes; after that, who cares?! He's a mile away and you've got his shoes! 2500K|Gene-Z|8GB|670|X-Fi|V1200+|3007WFP-HC|M4|F3|MK-85|G500|EK Full Ni|FC670|D5|360 GTS|240 UT60 |
#7 |
Packaging Master!
__________________
#8 |
Supermodder
can't say I have had any issues with my 670 PE
__________________
2500k @4.1Ghz /BeQuiet Dark rock advanced / Gigabyte Z68 UD4 /8GB Corsair Vengeance /MSI twin frozr GTX 670 /Audigy 4 Platinum Pro /128GB+64GB Crucial M4's /Antec P182 /BeQuiet Dark Power Pro 650W. |
#9 |
I Mod, Therefore I Own
Hmmm, interesting article, the question is, is your card one of the faulty batch, or a newer one?
__________________
SN25P A64 3700+ (San Diego) 2 GB DDR400 OCZ Platinum EL 2-3-2-5 1T X1800XT 512mb Sapphire 200GB Samsung SP2004C 24" Asus something 1920x1080 |
#10 | |
MD of Mutant Zombie Armies Inc
__________________
Project: RAt MoD:CPU:i5 3570K, Motherboard:ASUS Maximus 5 Gene, GPU:Gainward GTX 670 Phantom, Cooler:Modded Antec Kuhler 620, RAM:4GB 1600MHz G.Skill RipjawsX CL6, HDD: WD Raptor 150GB , PSU: Enermax Revolution 1050W Case: Antec P182, How to Get a FREE (sort of) Hard Drive and Other Small Parts. |
#11 |
Supermodder
I saw that article as well. I just updated my gtx drivers (though I believe they were already up to date). I uninstalled my old 6870 drivers myself(a month ago) but downloaded Driver Sweeper anyways. There is an ATI - Display section I can "clean" but am not to sure if I should. Lot of files in the system 32 folder.
__________________
#12 |
Supermodder
I honestly think it's Boarderlands 2 crashing my PC. I can run BF3 just fine (and it's harder on my GPU). Any thoughts on this? Never had a game crash my system. I verified the integrity of game cache and everything is fine there.
__________________
#13 |
Do you use a soundcard? could be soundcard drivers.
__________________
#14 |
Supermodder
Nope, everything in my system is in my sig.
__________________
#15 | |
Packaging Master!
You said it also happened with the Simcity beta, so it might not be game related. The fact that its happening during gaming tells me that the pc is being stressed to some point, especially the GPU, which in turn is too much for the PSU to handle. Have you got any other PSU to test the system with? In most cases, hardware faults cause BSOD's. Complete shutdowns are usually (in my experience) a result of the PSU not coping with the load.
__________________
#16 |
Proud Model M User
If it's not crashing in safe mode. RMA the card. It happened to my 670 cheesecake.
__________________
There's good ideas and then there's terribly great ideas. |
#17 |
Supermodder
Too late for an RMA, would have to deal with MSI. I'll test that out tomorrow.
__________________
#18 |
Supermodder
Only thing I'm not understanding is why is it only happening when I play BL2 and in the past when I played the SimCity beta?
__________________
#19 |
Packaging Master!
Are those the only two games you play? If not, what other games?
__________________
#20 |
Packaging Master!
__________________
| Thread Tools | |
