#1 |
Supermodder
Opteron online
Now have it back online and temps all around 47°C.
Will check out the Recon unit at the weekend. Saying adios to Spain now too. Onshore phase over, now onto offshore phase from Aberdeen. ![]() ---- Had to take my server offline today. I think I have a problem with the BitFenix Recon unit. Did a cold reboot earlier this morning to sort a problem with my TV card. Everything looked fine when I restarted it, but F@H client wasn’t picking up any work units, maybe unrelated. I then rebooted it again and then copied over the client to a clean folder and it picked up a work unit ok and started to fold. Don’t know why, but I went to check 'Phoebetria'; linux software to control the Recon, and it wasn’t responding well and indicated all fans were off, eventually. I double checked with phpsysinfo and the temperatures were going high 65°C+. I was able to get someone to switch the Recon unit off and back on and said all the fans were running once again, so stupidly I check Phoebetria again and it said the same. Immediately after this the temperatures from phpsysinfo were soaring. I eventually shutdown at 74.4°C. OK probably a bad idea to run the heat sink fans from the Recon. But it was working so well. Temps always around 43°C.
__________________
Folding Summary Desktop: Corsair Carbide 400R; Asus Sabertooth X79; Intel i7-3930K; Hydro H100; EVGA GTX 580 772MHz; Corsair Vengeance 16GB DDR3 1600MHz; Corsair HX850W; Samsung 256GB 840 Pro; 2TB HDD; Windows 7 Ult. 64bit. Last edited by Scorpuk; 6th Feb 2013 at 15:23. |
| Thread Tools | |
