#1 |
Minimodder
Project: Parvum
This is going to be a major upgrade to my current system, I appreciate any constructive criticism
Specs: CPU - Intel i5 3570k Motherboard - Gigabyte G1.Sniper M3 RAM - 16GB Corsair Vengeance Black 1600MHz (4x 4GB) GPU - AMD Radeon 7950 3GB SSD - 120GB OCZ Vertex 3 HDD - 1TB Western Digital Caviar Black Case - Parvum Systems S1.0 Black (With green accents) Fans - 4x Noctua NF-F12 (120mm) PSU - OCZ ZS 750w Watercooling hardware: EK-Supremacy (Clean Nickel Plexi) EK-FC7950 EN (Nickel Plexi) EK-FC7970 Backplate - Black EK-VGA I/O bracket HD7970 Swiftech MCRES V2 Bitspower 250mm Z-Multi - Clear Laing D5 with EK D5 X-Top 2x Alphacool NexXxoS ST30 240mm Primochill Primoflex Advanced LRT Clear 3/8 ID - 5/8 OD Deionized Water Mayhems X1 - UV Green Concentrate Various Compression Fittings Other parts: BCMods Green/Black Paracord Sleeved Cables - 24 Pin Motherboard, 4 Pin CPU, 2x 6 Pin GPU, 3 Pin Fans 2x BCMods 30CM Ultra-Bright LED Strip (White) BCMods on Facebook Parvum Systems on Facebook Case will look like this: ![]() My current rig:
#2 |
Hypermodder
2x XSPC RX240 240mm Dual Radiator
Have fun !EDIT: Helped u in my topic
#3 |
Minimodder
Lots of parts updated!
#4 |
www.^.nl
Looks like a very familiar case to me :P
Certainly following!
__________________
Preparing: Raz3r D3sk Running : L3p Parvum Finished : Cross - L3p AlCu - L3p L4n - L3p D3sk Sites: www.l3p.nl - www.redharbinger.com |
#5 |
Minimodder
Cheers mate, love your build log
#6 |
Minimodder
CPU and motherboard ordered!
#7 |
Minimodder
Received the CPU and motherboard today
![]() ![]() ![]() ![]() Just ordered my GPU for delivery tomorrow so i'll get some photos of it up once i get it installed
#8 |
Hypermodder
Niice
#9 |
Multimodder
When in doubt.... MOAR GREEN!!!
#10 |
Multimodder
Sexy motherboard
__________________
Autobot Bumblebee Autob0t Sk1ds Icelandic Winter DareDevil AciD_RaiN's facebook page |
#11 |
Minimodder
Thanks
![]() New GPU! ![]() ![]() ![]() ![]() ![]() Watercooling goodness ![]() ![]() ![]()
#12 |
Multimodder
Look at the size of that card compared to the mobo O.0
#13 |
Minimodder
Yeah right! Should look a lot better once it's in a case and has that fugly stock cooler off of it
#15 |
Minimodder
#16 |
Minimodder
Case is in production!
#17 |
Hypermodder
nice nice
#18 |
Minimodder
Did some overclocking on the 7950. Temps are around 75c when stressed and the stock cooler makes it sound like a leaf blower. Need to get it underwater soon...
#19 |
Minimodder
Not really anything that interesting today as all I did was put my hardware into the case
![]() Look what TNT brought me! ![]() A few extras that were included with the case ![]() Mystery bag ![]() This is where a photo of the case would go, if I had remembered to take one... Nice and simple HDD mounting. Simply slots into place ![]() ![]() ![]() Motherboard in ![]() GPU installed ![]() This is one of the only issues I had with the case but it's still an extremely annoying one. Since the plastic above the PCI slots is directly in line with the hold-down screws, you have to remove the entire back panel and pull back the metal mounting plate to get the screws in... A PITA, to say the least. ![]() Cable monster ![]() Tidied up and hidden ![]() Windowed side panel back on with everything installed ![]() ![]() Installed the rubber case feet ![]() Watercooling goodness coming soon! |
#20 |
Minimodder
Got a fantastic deal on this drive, also fits the theme really well so i'll have to find somewhere to put it on display!
| Thread Tools | |
| View Mode | |
