Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 5th Feb 2013, 12:04   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
Wine looks to bring Windows apps to Android
Not clear how the ISA issue will be solved.
http://www.bit-tech.net/news/bits/20...wine-android/1
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is offline   Reply With Quote
Old 5th Feb 2013, 12:58   #2
Byron C
This space for rent.
Byron C's Avatar
Byron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming SaiyanByron C is a Super Spamming Saiyan
I would have to question why you'd even want this... The big benefit I can see is being able to run desktop office suites - hello Microsoft Office - on tablet hardware. For pretty much all other applications you'd want on a tablet there's probably an alternative already available. I've no idea why you'd want to run traditional desktop applications on a phone; even the Galaxy Note simply wouldn't have a big enough screen. The only way they'll realistically get around the fact that Windows software is x86 only is by emulation of an x86 CPU; as the article mentions, and as I've experienced myself, that carries massive performance implications - you won't be running MS Office on your Android tablet if it's emulating x86.
Restricting it to x86 Android would work, but few commercial products use x86 hardware with Android. It might be handy for those few that do run such devices, but is it honestly worth the effort?
__________________
Saturn: Gen8 Microserver, G1610T, 4GB RAM, 5TB Disk | Titan: Raspberry Pi 2 Model B, 160GB USB HDD | Rhea: XW4600 Workstation, Xeon X3323, 4GB RAM, 292GB 15K SAS Array | Earth: RVZ01, i5-4670K, GA-Z97N-WIFI, 8GB RAM, 4GB GTX970 | Mars: Dell Inspirion 15-7559, i7-6700HQ, 16GB RAM, 4GB GDDR5 GTX960M
Byron C is offline   Reply With Quote
Old 5th Feb 2013, 13:25   #3
XXAOSICXX
Hypermodder
XXAOSICXX is almost as Godly as yodasarmpitXXAOSICXX is almost as Godly as yodasarmpitXXAOSICXX is almost as Godly as yodasarmpitXXAOSICXX is almost as Godly as yodasarmpitXXAOSICXX is almost as Godly as yodasarmpitXXAOSICXX is almost as Godly as yodasarmpitXXAOSICXX is almost as Godly as yodasarmpitXXAOSICXX is almost as Godly as yodasarmpitXXAOSICXX is almost as Godly as yodasarmpitXXAOSICXX is almost as Godly as yodasarmpitXXAOSICXX is almost as Godly as yodasarmpit
gareth... " they are having to emulate a full x86 processor on an ARM chip optimise for low power draw in a mobile device" <- optimised
XXAOSICXX is offline   Reply With Quote
Old 5th Feb 2013, 13:46   #4
Guinevere
Mega Mom
Guinevere's Avatar
Guinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming Saiyan
No, they're talking about replicating the API layer and not the hardware layer. So a 'standard' compiled app that is basically a list of calls to standard windows APi calls will work 'as is' and each call will be directed to a re-written equivalent.
But without any ability to run x86 code then their compatibility list is going to be limited.
But it's a start, and of course an extension of it will be to (potentially) run x86 windows apps on RT.
But lets not underestimate the amount of work it is to get even a subset of the required APIs re-written and stable. MS have not exactly been frugal when it comes to releasing new APIs.
Guinevere is offline   Reply With Quote
Old 5th Feb 2013, 13:50   #5
Rhydian
Hypermodder
Rhydian's Avatar
Rhydian is definitely a rep cheat.Rhydian is definitely a rep cheat.Rhydian is definitely a rep cheat.Rhydian is definitely a rep cheat.Rhydian is definitely a rep cheat.Rhydian is definitely a rep cheat.Rhydian is definitely a rep cheat.Rhydian is definitely a rep cheat.Rhydian is definitely a rep cheat.Rhydian is definitely a rep cheat.Rhydian is definitely a rep cheat.
If I had a 1 for everything I didn't understand here, I would be able to take a holiday.
Rhydian is offline   Reply With Quote
Old 5th Feb 2013, 14:35   #6
faugusztin
I *am* the guy with two left hands
faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.faugusztin is the Cheesecake. Relix smiles down upon them.
If i have to guess, they are aiming for stuff like this. That is, desktop Windows applications running on ARM.
faugusztin is offline   Reply With Quote
Old 5th Feb 2013, 14:42   #7
RichCreedy
Hey What Who
RichCreedy's Avatar
RichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming SaiyanRichCreedy is a Super Spamming Saiyan
what I can't understand, is if windows stuff is bad enough not to choose it in the first place, why emulate it?
__________________
if there are errors in my messages, its because my brain is to far ahead of my hands
RichCreedy is offline   Reply With Quote
Old 5th Feb 2013, 14:43   #8
Snips
I can do dat, giz a job
Snips's Avatar
Snips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming SaiyanSnips is a Super Spamming Saiyan
" The big benefit I can see is being able to run desktop office suites - hello Microsoft Office - on tablet hardware."
Actually, it runs perfectly well on my Surface Tablet. So your point is?
Snips is offline   Reply With Quote
Old 5th Feb 2013, 14:50   #9
Shirty
Here from the future...
Moderator
Shirty's Avatar
Shirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, Shirty
This, but replace 1 with 5p
__________________
3770K | Z77E-ITX | Liqtech 120X | EVGA GTX 980Ti SC | 8GB | 1TB M550 | Node 304 | SS-460FL2 (fanless) | Dell S2740L | Ducky TKL | Logitech G500
I also have a Surface Pro 2, even though I'm not a pro...
Shirty is offline   Reply With Quote
Old 5th Feb 2013, 15:22   #10
Gareth Halfacree
WIIGII!
bit-tech Staff
The runaway 'd' has been found and returned to his rightful place - ta!
__________________
Old 5th Feb 2013, 15:25   #11
SchizoFrog
I *am* a Dremel
SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.
I would have thought there would be a much bigger demand for running iOS and Android apps on WP8. The biggest downfall of WP8 is the lack of apps that are available to the other two OS's. It would be awesome if you could bring the best of iOS and Android apps to WP8.
__________________
SchizoFrog is offline   Reply With Quote
Old 5th Feb 2013, 17:04   #12
Instagib
Ultramodder
Instagib's Avatar
Instagib is definitely a rep cheat.Instagib is definitely a rep cheat.Instagib is definitely a rep cheat.Instagib is definitely a rep cheat.Instagib is definitely a rep cheat.Instagib is definitely a rep cheat.Instagib is definitely a rep cheat.Instagib is definitely a rep cheat.Instagib is definitely a rep cheat.Instagib is definitely a rep cheat.Instagib is definitely a rep cheat.
If all that comes from this is that I can run the full football manager 2012 on my phone, I would be a very happy chappy!
__________________
Silverstone FT04B | Maximus V Extreme | i7 - 3770K @4.6 | 16Gb Corsair Vengeance LP DDR3 1600Mhz | H80i | ASUS GTX 780Ti DCII |Seasonic 660XP2
Silverstone TJ07|Rampage 3 Extreme | X5650 @ 4.2 | 12Gb Corsair DDR3 1600mhz | EVGA GTX680 | Akasa 1000W Powermax | 480 rad; all under water
Instagib is online now   Reply With Quote
Old 5th Feb 2013, 18:15   #13
Byron C
Byron C's Avatar
That's sort of my point; for anything that's specific to the x86 ISA - whether that's the application binary or the APIs it calls - you're going to be SOL unless you can reverse-engineer that API and implement your own version of it, or wrap those calls to a Linux/Android ARM equivalent (if one exists).
Quite...
Meanwhile in the real world, compared to the number of Android tablets and iPads out there the Surface doesn't even warrant mentioning (see http://rcpmag.com/articles/2013/01/3...registers.aspx). That isn't a criticism of the hardware or the software, it's a cold hard commercial reality.
__________________
Old 5th Feb 2013, 19:41   #14
PCBuilderSven
Multimodder
PCBuilderSven has yet to learn the way of the Dremel
...require developers to recompile their Windows applications for ARM before they would be compatible with the Wine shim.
With Microsoft pushing towards ARM themselves with Windows RT, developers may have to do this anyway. If they continue pushing ARM I wouldn't be surprised if Windows 9 (or a later version) allow the full version of Windows to run on ARM. The power of new ARM chips means they could easily power (low-mid range) laptops relatively soon.
PCBuilderSven is offline   Reply With Quote
Old 5th Feb 2013, 23:43   #15
Nexxo
Whatever's Geek.
Nexxo's Avatar
Nexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming Saiyan
Quite...
It's been only three months of a poorly distributed product going against a really well-distributed one that has had nearly three years head start. Give it a chance to catch up.
Windows RT is the full version of Windows. It is just not unlocked. But that may still happen after all. When it's jailbroken you realise how it can do more or less everything Windows 8 can.
__________________
In memory of Kidmod-Southpaw (1997 - 2014), Teelzebub (1955 - 2016) and Waynio (1978 - 2016)
"We are the music makers; we are the dreamers of dreams"
Current project: Metaversa 02 Ada.
Nexxo is offline   Reply With Quote
Old 6th Feb 2013, 10:09   #16
Gareth Halfacree
WIIGII!
bit-tech Staff
Except, y'know, run Windows applications. Which, let's face it, is sort of what people want from Windows. It's one of the few complaints against Linux on the desktop that remains valid: if I can't run my existing applications, why would I make the move? (I mean, not me I, 'cos I run Linux already. The Royal I. So to speak.)
__________________
Old 6th Feb 2013, 14:21   #17
Byron C
Byron C's Avatar
My post was in response to a claim that running MS Office on tablets is a moot point because it's available on WinRT. Whoopee-do, what about the overwhelming majority of tablet owners that don't have a Surface RT? My point was more that there would be an awful lot of people interested in running MS Office on Android or iOS tablets, as they are by far the most widespread tablets on the market.
It wasn't a criticism of the Surface or Win8/WinRT. In fact the Surface hardware looks pretty damn sweet; both the RT and Pro versions.
__________________
Old 6th Feb 2013, 17:57   #18
Snips
Snips's Avatar
So you're moaning at Microsoft for not porting it's Microsoft Office software onto a none Microsoft touch OS while it's busy developing and doing a damn fine job at it, it's own touch OS?
Good luck with that!
Old 6th Feb 2013, 19:39   #19
Nexxo
Whatever's Geek.
Nexxo's Avatar
It does --as long as they are ported to ARM. I realise that there aren't many yet, but the list is growing.
(And as long as it has got Quake and Rainmeter in that list, who cares! )
__________________
Old 6th Feb 2013, 20:55   #20
Gareth Halfacree
WIIGII!
bit-tech Staff
And how many of those are closed-source, commercial Windows packages? You know, the ones that are Windows exclusive, or Windows and Mac exclusive? Nobody would stick with an operating system because it runs Quake - especially as everything from a Texas Instruments calculator upwards can run Quake - but because it runs the full-fat version of Microsoft Office, or Adobe Photoshop, or Sage Line 50.
I specifically said "Windows applications" in my post, not "cross-platform, open-source applications." When they are available for Windows RT, I'll accept that it can "do everything Windows 8 can do." But the fact that it can be made to run OpenTDD does not invalidate my point.
__________________
Reply
Tags
android, codeweavers, crossover, linux, windows, wine, wine for android
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
