Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 6th Feb 2013, 10:24   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!Gareth Halfacree - it's over 9000!!!!!!!!1!1!1!!!
AMD SDK teases dynamic GPU clocking technology
Looks to compete with Nvidia's GPU Boost.
http://www.bit-tech.net/news/hardwar...ynamic-clock/1
__________________
Co-author, Raspberry Pi User Guide, Meet the Raspberry Pi | gareth.halfacree.co.uk | twitter
bit-tech news correspondent, Custom PC columnist
I'm a filthy freelancer! Hire me!
Gareth Halfacree is offline   Reply With Quote
Old 6th Feb 2013, 11:42   #2
mattbailey
Multimodder
mattbailey has yet to learn the way of the Dremel
You cant polish a turd!
mattbailey is offline   Reply With Quote
Old 6th Feb 2013, 12:05   #3
zebby2k
What's a Dremel?
zebby2k has yet to learn the way of the Dremel
But you can roll it in glitter!!
zebby2k is offline   Reply With Quote
Old 6th Feb 2013, 13:03   #4
Sheiken
Wat?
Sheiken's Avatar
Sheiken has yet to learn the way of the DremelSheiken has yet to learn the way of the DremelSheiken has yet to learn the way of the Dremel
The 7970ghz is the fastest single gpu card. Why is it a turd?
__________________
Whoring Out My Hardware 3.2!
Portaputer - Clevo W540EU - 14" / i5 / 8GB / 256gb ssd
H@ck Pro Gigabyte Z77-DS3H / i3 3225/ 8GB DDR3 / Gigabyte GTX 660 OC / Corsair Carbide 300r / 250GB / 1000GB
Sheiken is offline   Reply With Quote
Old 6th Feb 2013, 13:19   #5
Slayer the Unholy
Multimodder
Slayer the Unholy's Avatar
Slayer the Unholy has yet to learn the way of the DremelSlayer the Unholy has yet to learn the way of the DremelSlayer the Unholy has yet to learn the way of the DremelSlayer the Unholy has yet to learn the way of the DremelSlayer the Unholy has yet to learn the way of the DremelSlayer the Unholy has yet to learn the way of the Dremel
www.youtube.com/watch?v=yiJ9fy1qSFI polishing a turd
__________________
Its my computer so I'll do what i want with it
26.62722% Total Geek
Slayer the Unholy is offline   Reply With Quote
Old 6th Feb 2013, 13:19   #6
Griffter
Supermodder
Griffter - it's over 9000!!!!!!!!1!1!1!!!Griffter - it's over 9000!!!!!!!!1!1!1!!!Griffter - it's over 9000!!!!!!!!1!1!1!!!Griffter - it's over 9000!!!!!!!!1!1!1!!!Griffter - it's over 9000!!!!!!!!1!1!1!!!Griffter - it's over 9000!!!!!!!!1!1!1!!!Griffter - it's over 9000!!!!!!!!1!1!1!!!Griffter - it's over 9000!!!!!!!!1!1!1!!!Griffter - it's over 9000!!!!!!!!1!1!1!!!Griffter - it's over 9000!!!!!!!!1!1!1!!!Griffter - it's over 9000!!!!!!!!1!1!1!!!
valve must make a gpu.
Griffter is offline   Reply With Quote
Old 6th Feb 2013, 13:55   #7
Griffter
Supermodder
hahahahhahahahhahahahahahahaha best reply ever!
Old 6th Feb 2013, 14:37   #8
damien c
Mad FPS Gamer
damien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for president
Grr I was going to post that link lol
__________________
Core I7 3930K, Rampage IV Extreme, 16GB Corsair Vengance 1600mhz, GTX 680 SLI, Corsair Force 3 250Gb SSD, Creative Sound Blaster X-Fi Titanium, NZXT Switch 810, XSPC RX 360mm + Alphacool 240mm All Copper, 10x Scythe Kazi Jyuni 1900rpm 5v & And It's Silent!!!!!!!!! .
Market Place Feedback
http://forums.bit-tech.net/showpost....&postcount=104
damien c is offline   Reply With Quote
Old 6th Feb 2013, 19:43   #9
rollo
I Mod, Therefore I Own
rollo should be considered for presidentrollo should be considered for presidentrollo should be considered for presidentrollo should be considered for presidentrollo should be considered for presidentrollo should be considered for presidentrollo should be considered for presidentrollo should be considered for presidentrollo should be considered for presidentrollo should be considered for presidentrollo should be considered for president
Dont AMD already have a 7950 boost? that does this clock rate thing already.
rollo is offline   Reply With Quote
Old 7th Feb 2013, 07:19   #10
Lenderz
Supermodder
Lenderz has yet to learn the way of the DremelLenderz has yet to learn the way of the DremelLenderz has yet to learn the way of the DremelLenderz has yet to learn the way of the DremelLenderz has yet to learn the way of the DremelLenderz has yet to learn the way of the DremelLenderz has yet to learn the way of the Dremel
Because hes a fanboy, and is emotionally attached to a company.
Lenderz is offline   Reply With Quote
Old 10th Feb 2013, 03:40   #11
LightningPete
Diagnosis: ARMAII-Holic
LightningPete has yet to learn the way of the Dremel
Landerz, is that an 'EMO' ???
I think we desperately another GPU maker with something ti compete with these polished turds (both companies)
Sent from Bittech Android app
LightningPete is offline   Reply With Quote
Reply
Tags
adl, adl sdk, amd display library, gpu boost, nvidia, overdrive 5, overdrive 6, powertune, powertune with boost, sdk, software development kit, techpowerup
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
