Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 6th Feb 2013, 18:02   #1
Dean R
Modder
Dean R has yet to learn the way of the Dremel
Budget Gaming PC for £250?
A friend at work wants me to upgrade her PC for £250 max for her grandson.
She only uses it for Office and web browsing but wants it for her grandson to play games on. I told her it would be difficult for that kind of price but I would give it a go.
She has given me her Dell Dimension E520 to upgrade or sell on ebay to put towards a new build.
Was looking to build a i3 based system but its looking tough at that price.
Also, not quite sure what condition this Dell is in yet and whether anything is salvageable.
Basically wondering if anyone out there could recommend a possible build for me? £250 has to include postage from Scan.
__________________
Got a new build now, but cba typing it out..
Dean R is offline   Reply With Quote
Old 6th Feb 2013, 18:07   #2
xTatic
xTatic's Avatar
xTatic - it's over 9000!!!!!!!!1!1!1!!!xTatic - it's over 9000!!!!!!!!1!1!1!!!xTatic - it's over 9000!!!!!!!!1!1!1!!!xTatic - it's over 9000!!!!!!!!1!1!1!!!xTatic - it's over 9000!!!!!!!!1!1!1!!!xTatic - it's over 9000!!!!!!!!1!1!1!!!xTatic - it's over 9000!!!!!!!!1!1!1!!!xTatic - it's over 9000!!!!!!!!1!1!1!!!xTatic - it's over 9000!!!!!!!!1!1!1!!!xTatic - it's over 9000!!!!!!!!1!1!1!!!xTatic - it's over 9000!!!!!!!!1!1!1!!!
You should have free delivery from Scan if you link your BT account.
__________________
NZXT Tempest EVO >> Phenom II X4 955 >> Thermaltake Frio >> Zotac GTX570
ASRock 890 GM Pro3 >> 4GB (2x2GB) Crucial Ballistix DDR3 1600MHz CL8 >> Corsair TX650W
Samsung Spinpoint F3 1TB >> NZXT Sentry 2 >> WD Caviar Black 640GB
xTatic is offline   Reply With Quote
Old 6th Feb 2013, 18:07   #3
Nealieboyee
Packaging Master!
Nealieboyee's Avatar
Nealieboyee should be considered for presidentNealieboyee should be considered for presidentNealieboyee should be considered for presidentNealieboyee should be considered for presidentNealieboyee should be considered for presidentNealieboyee should be considered for presidentNealieboyee should be considered for presidentNealieboyee should be considered for presidentNealieboyee should be considered for presidentNealieboyee should be considered for presidentNealieboyee should be considered for president
Can you keep the HDD and Monitor, Keyboard, Mouse, and Case?
__________________
Bonnie
i3-2100T | H61M-P31 | 4GB DDR3 1333MHz | 60GB OCZ Agility 3 SSD | GTX 260
Nealieboyee is offline   Reply With Quote
Old 6th Feb 2013, 18:07   #4
modd1uk
Corsair Fan
modd1uk's Avatar
modd1uk - it's over 9000!!!!!!!!1!1!1!!!modd1uk - it's over 9000!!!!!!!!1!1!1!!!modd1uk - it's over 9000!!!!!!!!1!1!1!!!modd1uk - it's over 9000!!!!!!!!1!1!1!!!modd1uk - it's over 9000!!!!!!!!1!1!1!!!modd1uk - it's over 9000!!!!!!!!1!1!1!!!modd1uk - it's over 9000!!!!!!!!1!1!1!!!modd1uk - it's over 9000!!!!!!!!1!1!1!!!modd1uk - it's over 9000!!!!!!!!1!1!1!!!modd1uk - it's over 9000!!!!!!!!1!1!1!!!modd1uk - it's over 9000!!!!!!!!1!1!1!!!
Would be looking at used parts with that budget if the old system cant be upgraded.
PSU will be crap for a start.
__________________
Corsair 800D :: ASUS P8P67-EVO :: i5 2500K :: 8GB Corsair Vengeance :: MSI Twin FrozrII GTX 570 :: Corsair HX520 :: Corsair H100 :: Samsung 830 256gb :: Samsung F3 :: Samsung F4
Originally Posted by loftie View Post
^+1
Energy saving light bulb agrees with the incandescent bulb.
modd1uk is offline   Reply With Quote
Old 6th Feb 2013, 18:11   #5
Dean R
Modder
HDD is busted apparently. Not got my hands on the PC yet so dunno for definite. She doesnt need a monitor. I can use anything theyve given me so drives and stuff yes.
__________________
Old 6th Feb 2013, 18:12   #6
Dean R
Modder
Didnt know that thanks. Always tried signing up with AV forums but you have to be active now,
__________________
Old 6th Feb 2013, 18:14   #7
Nealieboyee
Packaging Master!
This is a good start. People will tell you to go for the i3, but its not necessary. Still needs a hard drive though. What cpu does the Dell Dimension have?
__________________
Bonnie
Old 6th Feb 2013, 18:24   #8
Harlequin
I Mod, Therefore I Own
Harlequin's Avatar
Harlequin - may the hammer of Bindi be bestowed on youHarlequin - may the hammer of Bindi be bestowed on youHarlequin - may the hammer of Bindi be bestowed on youHarlequin - may the hammer of Bindi be bestowed on youHarlequin - may the hammer of Bindi be bestowed on youHarlequin - may the hammer of Bindi be bestowed on youHarlequin - may the hammer of Bindi be bestowed on youHarlequin - may the hammer of Bindi be bestowed on youHarlequin - may the hammer of Bindi be bestowed on youHarlequin - may the hammer of Bindi be bestowed on youHarlequin - may the hammer of Bindi be bestowed on you
ebuyer have complete systems for that budget , not the most awesome but should do teh job
__________________
i have a 3dfx voodoo5 6000
Harlequin is online now   Reply With Quote
Old 6th Feb 2013, 18:29   #9
Nealieboyee
Packaging Master!
Yeah but I wouldn't trust the PSU's in those systems, at least not for gaming with a dedicated gpu
__________________
Bonnie
Old 6th Feb 2013, 18:36   #10
Harlequin
Harlequin's Avatar
true, they seem to be 300w ; but for your list your missing a hdd as well (op said it was busted) so thats another £40 on top , so that £250 machine is kncking on 300
__________________
Old 6th Feb 2013, 18:40   #11
Nealieboyee
Packaging Master!
Yeah I got the list together before I saw the "hdd is busted" part. But if he sells the parts from the Dell Dimension, he should be able to afford a new HDD, hopefully. It depends what cpu that system has. He can sell a core 2 duo quite easily, but Pentium 4's are worth nothing these days.
__________________
Bonnie
Old 6th Feb 2013, 18:40   #12
modd1uk
Corsair Fan
modd1uk's Avatar
Operating system?
__________________
^+1
Old 6th Feb 2013, 18:55   #13
rollo
rollo should be considered for presidentrollo should be considered for presidentrollo should be considered for presidentrollo should be considered for presidentrollo should be considered for presidentrollo should be considered for presidentrollo should be considered for presidentrollo should be considered for presidentrollo should be considered for presidentrollo should be considered for presidentrollo should be considered for president
Decent question that from modd1uk if it has no operating system this budget is way too small. Borderline impossible tbh.
Depends totally whats in the dell dimension as there will be no OS disk. If the HD is busted theres £40 that you have to find also.
If it has a core 2 duo he could use it instead of buying a cpu its still a more than capable gaming cpu.
You may be better off heading the AMD route with there intergrated graphics been good enough for most basic games assuming the resolution is not pushed too high.
rollo is offline   Reply With Quote
Old 6th Feb 2013, 18:57   #14
Spreadie
No disassemble!
Spreadie's Avatar
Spreadie is definitely a rep cheat.Spreadie is definitely a rep cheat.Spreadie is definitely a rep cheat.Spreadie is definitely a rep cheat.Spreadie is definitely a rep cheat.Spreadie is definitely a rep cheat.Spreadie is definitely a rep cheat.Spreadie is definitely a rep cheat.Spreadie is definitely a rep cheat.Spreadie is definitely a rep cheat.Spreadie is definitely a rep cheat.
Probably gunna need a new case - the layout of those Dell boxes is usually proprietary.
__________________
Before you judge a man, walk a mile in his shoes; after that, who cares?! He's a mile away and you've got his shoes!
2500K|Gene-Z|8GB|670|X-Fi|V1200+|3007WFP-HC|M4|F3|MK-85|G500|EK Full Ni|FC670|D5|360 GTS|240 UT60
Spreadie is online now   Reply With Quote
Old 6th Feb 2013, 19:01   #15
Harlequin
Harlequin's Avatar
rebuilding it if its a C2D would be feasible - but not if its a P4D
__________________
Old 6th Feb 2013, 19:33   #16
atc95
Need help with scratchbuild!
atc95's Avatar
atc95 is almost as Godly as yodasarmpitatc95 is almost as Godly as yodasarmpitatc95 is almost as Godly as yodasarmpitatc95 is almost as Godly as yodasarmpitatc95 is almost as Godly as yodasarmpitatc95 is almost as Godly as yodasarmpitatc95 is almost as Godly as yodasarmpitatc95 is almost as Godly as yodasarmpitatc95 is almost as Godly as yodasarmpitatc95 is almost as Godly as yodasarmpitatc95 is almost as Godly as yodasarmpit
What about ditching the gpu and use trinity e.g. A10 5700, it won't be an incredible gaming machine but judging by op, gaming is the 2nd purpose.
__________________
i5 3550 // gigabyte g1 sniper m3 // xfx 7950 dd @ 1ghz // 2x4gb C. Vengeance // samsung 256gb 830 // 750gb scorpio black // silverstone tj08be // enermax ets t40 tb // ocz modXstream pro 700w // Dell u2412m // IBM 17" tft.
Xbox PC mod (nearly finished): a10 5800k @ 4.6ghz, h100i, msi fm2 a75ia, 8gb samsung greens, 256gb sandisk ultra!
atc95 is offline   Reply With Quote
Old 6th Feb 2013, 20:07   #17
IvanIvanovich
будет глотать вашу душу.
IvanIvanovich's Avatar
IvanIvanovich - may the hammer of Bindi be bestowed on youIvanIvanovich - may the hammer of Bindi be bestowed on youIvanIvanovich - may the hammer of Bindi be bestowed on youIvanIvanovich - may the hammer of Bindi be bestowed on youIvanIvanovich - may the hammer of Bindi be bestowed on youIvanIvanovich - may the hammer of Bindi be bestowed on youIvanIvanovich - may the hammer of Bindi be bestowed on youIvanIvanovich - may the hammer of Bindi be bestowed on youIvanIvanovich - may the hammer of Bindi be bestowed on youIvanIvanovich - may the hammer of Bindi be bestowed on youIvanIvanovich - may the hammer of Bindi be bestowed on you
Depends a lot on how old is the grandson, and what do they mean by games. Stuff like plants vs zombies or BF3... if the former it's quite easy, if the latter forget it. That budget is too small to have a good expierience with much beyond casual unless you get a lot of luck in the used market. Even still its a stretch and if you need a legit Windows, it's impossible as it's what a 1/3 the budget?
__________________
[end of line]
intel i5-750 | evga p55 sli | 8gb mushkin blackline | evga gtx670 | 240gb mushkin chronos dx
| creative titanium hd | mushkin 580w | gh60 custom | logitech mx revolution | achieva shimian qh270
IvanIvanovich is offline   Reply With Quote
Old 6th Feb 2013, 20:18   #18
Nealieboyee
Packaging Master!
Too much negativity here lol. He can do it! More info would be great though, such as monitor resolution, games list (as mentioned before), and Windows version.
Also, can you buy second hand?
__________________
Bonnie
Old 6th Feb 2013, 20:40   #19
fdbh96
I *am* a Dremel
fdbh96's Avatar
fdbh96 - it's over 9000!!!!!!!!1!1!1!!!fdbh96 - it's over 9000!!!!!!!!1!1!1!!!fdbh96 - it's over 9000!!!!!!!!1!1!1!!!fdbh96 - it's over 9000!!!!!!!!1!1!1!!!fdbh96 - it's over 9000!!!!!!!!1!1!1!!!fdbh96 - it's over 9000!!!!!!!!1!1!1!!!fdbh96 - it's over 9000!!!!!!!!1!1!1!!!fdbh96 - it's over 9000!!!!!!!!1!1!1!!!fdbh96 - it's over 9000!!!!!!!!1!1!1!!!fdbh96 - it's over 9000!!!!!!!!1!1!1!!!fdbh96 - it's over 9000!!!!!!!!1!1!1!!!
Now im not much of a console fan, but if your looking at "proper" games then its the best (and easiest) option.
http://www.currys.co.uk/gbuk/sony-su...aprxp&istBid=t
fdbh96 is offline   Reply With Quote
Old 6th Feb 2013, 21:15   #20
Nealieboyee
Packaging Master!
You're kidding right?
__________________
Bonnie
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
