Reply
Thread Tools View Mode
Old 12th Feb 2013, 22:47   #1
Fruergaard
Minimodder
Fruergaard has yet to learn the way of the Dremel
White SG09 with power and watercooling
Hello, ones again
So my latestet build; Unobtainable was a great PC to build, and got a lot of positive feedback, Thanks guys and girls
First of I would once like to thanks Aquatuning.de for sponsoring this build with many great watercooling parts
And also thanks to Fractal Design for sponsoring the Newton R3 1000W White PSU.
But my eager to create something new, and also a (hopefully) better looking build.
So I will hope you will follow this build as well, and please; positive criticism is always welcome, so dont hold back
But to the main part; Building a kick ass looking SG09 with a lot of watercooling
So first of the SG09 case. A really small case produced by Silverstone, but still space enough for a mATX and SLI, and hopefully for my ideas of watercooling
Just a quick picture for you that haven't seen it yet (more to come later):
Most people doesn't really like the front of the case (which also seems why Silverstone have made SG10).
But I see opportunities, so hopefully it will turn out better after it have been painted.
And you guessed it right, there isn't sold any white SG09 case, so I will spray paint the hole case (because I like white cases ).
About the internal hardware, it's going to be a powerfull rig but not extreme (just yet).
It's going to be a Intel I7 3770k, 16gb of RAM, a Rog Maximus Gene IV Z some Intel SSD and of course two lovely GPU's;
Two nice Evga GTX 670 +SC 4gb cards. Reason that I chosed those two cards, you will understand later
All the watercooling blocks will come from EKWB, since I really like their continues CSQ design on all the blocks and that it's Plexi tops to see the water flow though and give a nice "show" effect.
I got almost all the parts, so the build can begin. However, my time is limited, so please be patient, I want this build done as fast as you (but still looking awesome).
Actually a nice big package came today from Aquatuning.de, but still missing one more
The package contains a lot of nice things;
Two nice D5 pumps with Plexi tops.
Reservoirs with a lot of lighting options
Some nice radiators from both Phobya (200mm) and two 120mm fra alphacool.
Thise will also get colored to fit the theme of white and Green (white frame and green fins).
Some tuping;
Really like these tupes, because the are really flexible which is nice in a small case
And a lot of other nice products from (temp sensor, lightning, pump silence and some radiator shrouds) that would get in this build;
It's a lot of hardware and watercooling to get into this small build, which means challenges, but I got a plan
So the next thing for this build is to recieve the last products (some watercooling parts and sleeving from MDPC-x), and then get going with installation and modding.
And then afterwards the painting of all the parts will begin to get the build look great and unique in the green and white theme
And I also got a little surprise, but more on that later on.
So hope you will follow and like the outcome, and if you got some feedback, please let me know
Fruergaard is offline   Reply With Quote
Old 12th Feb 2013, 23:58   #2
Maki role
Dale you're on a roll...
Maki role's Avatar
Maki role - may the hammer of Bindi be bestowed on youMaki role - may the hammer of Bindi be bestowed on youMaki role - may the hammer of Bindi be bestowed on youMaki role - may the hammer of Bindi be bestowed on youMaki role - may the hammer of Bindi be bestowed on youMaki role - may the hammer of Bindi be bestowed on youMaki role - may the hammer of Bindi be bestowed on youMaki role - may the hammer of Bindi be bestowed on youMaki role - may the hammer of Bindi be bestowed on youMaki role - may the hammer of Bindi be bestowed on youMaki role - may the hammer of Bindi be bestowed on you
I loved Unobtainable, it was a really exciting idea and beautifully executed. Definitely looking forward to seeing how this one turns out, that's some beautiful gear you're putting in that box.
Subbed.
__________________
Project Azure - MotM Februaray 2013 Nominee
Maki role is offline   Reply With Quote
Old 21st Feb 2013, 10:05   #3
Fruergaard
Minimodder
Subbed.
Thanks, Unobtainable was really something speciel with that Shuttle motherboard, but even though the end result was great, it just wasn't me.. If you understand
So a bit of update, again it's a bit slow cause of my limited time, but I will get there with an awesome end result, promise
First of the GPU's got them a make over:
The card alone. A really small card but still very powerfull.
One card
Two cards
And from the back with the back plates.
Now imagine that these get colored white and the rings becomes green
And green water running though those nice looking EKWB plexi nickel blocks
I also got a nice package from Nils at MDPC-X inculding some sleeving, pre-cut heat shrink and a crimping tool.
Some really nice looking sleeving, looking forward to get going with it
The last shipment from Aquatuning.de should come soon, just waiting for those good looking Monsoon fittings
Old 21st Feb 2013, 10:31   #4
Mankz
________
Mankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on you
That green and white looks pweety.
Mankz is offline   Reply With Quote
Old 21st Feb 2013, 11:06   #5
dreps
Multimodder
dreps has yet to learn the way of the Dremeldreps has yet to learn the way of the Dremeldreps has yet to learn the way of the Dremeldreps has yet to learn the way of the Dremeldreps has yet to learn the way of the Dremeldreps has yet to learn the way of the Dremeldreps has yet to learn the way of the Dremeldreps has yet to learn the way of the Dremel
love the case and colors you're going for
dreps is offline   Reply With Quote
Old 22nd Feb 2013, 22:22   #6
sixfootsideburns
modeteer
sixfootsideburns has yet to learn the way of the Dremelsixfootsideburns has yet to learn the way of the Dremel
I see lots of hardware and no modding... what gives! Get a move on!
sixfootsideburns is offline   Reply With Quote
Old 23rd Feb 2013, 15:51   #7
Fruergaard
Minimodder
Yeap, they look a lot better then the last sleeving i used.
Thanks, really like the white and green themed builds, but so few of them :-/
He, well I would like this done as fast as you guys , but still my time is limited.
Old 24th Feb 2013, 01:31   #8
Hanoken
Modder
Hanoken has yet to learn the way of the Dremel
i see... interesting, are you using smaller length cards to fit the reservoirs in? And I loved the Unobtainable mod, being able to fit the x79 platform in small form is indeed one hellavua mod
__________________
Current Rig: i7 920 oc @ 3.5 GHZ, Evga X58 SLI FTW3, 24 Gb G Skill Sniper Ram @ 1600 Mhz
Evga 670 GTX FTW SLI
Need to build something new soon... I'm thirsting for a new build
Hanoken is offline   Reply With Quote
Old 24th Feb 2013, 05:31   #9
sixfootsideburns
modeteer
Well until your time frees up this really belongs in a different forum. Give us some work mate!
Old 24th Feb 2013, 06:51   #10
Bindibadgi
Omnipwntent
Bindibadgi's Avatar
Bindibadgi is definitely a rep cheat.Bindibadgi is definitely a rep cheat.Bindibadgi is definitely a rep cheat.Bindibadgi is definitely a rep cheat.Bindibadgi is definitely a rep cheat.Bindibadgi is definitely a rep cheat.Bindibadgi is definitely a rep cheat.Bindibadgi is definitely a rep cheat.Bindibadgi is definitely a rep cheat.Bindibadgi is definitely a rep cheat.Bindibadgi is definitely a rep cheat.
MOAR!
__________________
Slash88: That kettle video just made me go death thanks.
Fizzban: And it is being panda'd to..lame.
Bindibadgi is offline   Reply With Quote
Old 24th Feb 2013, 07:07   #11
Scirocco
Boobs, I have them, you lose.
Scirocco's Avatar
Scirocco - it's over 9000!!!!!!!!1!1!1!!!Scirocco - it's over 9000!!!!!!!!1!1!1!!!Scirocco - it's over 9000!!!!!!!!1!1!1!!!Scirocco - it's over 9000!!!!!!!!1!1!1!!!Scirocco - it's over 9000!!!!!!!!1!1!1!!!Scirocco - it's over 9000!!!!!!!!1!1!1!!!Scirocco - it's over 9000!!!!!!!!1!1!1!!!Scirocco - it's over 9000!!!!!!!!1!1!1!!!Scirocco - it's over 9000!!!!!!!!1!1!1!!!Scirocco - it's over 9000!!!!!!!!1!1!1!!!Scirocco - it's over 9000!!!!!!!!1!1!1!!!
I do like Silverstone cases. No doubt you'll be great with this one. The color scheme will be hawt!
__________________
"If she were any more of a bitch, she'd have puppies!" Victoria Chase, Hot in Cleveland.
Current project: La Fée Verte
Scirocco is offline   Reply With Quote
Old 24th Feb 2013, 12:10   #12
KoSoVaR^
Professional Sleever & Modder
KoSoVaR^'s Avatar
KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.KoSoVaR^ is a hoopy frood who really knows where their towel is.
ohhh yeeah
Looking forward to this!
SUBBED!
KoSoVaR^ is offline   Reply With Quote
Old 24th Feb 2013, 13:50   #13
Fruergaard
Minimodder
Perhaps, but you will find out later ;-)
Yes Unobtainable was quite a hit, many asked for the mobo to create something smilar ;-)
He, I will. Next week i got a bit mroe time ;-)
They do provide us with some great cases, and innovative once to
Old 9th Mar 2013, 09:45   #14
Fruergaard
Minimodder
First installation of the hardware and pumps in the case
There isn't that much to say. You should begin to see what my plan is with this build according to fitting it all in that small case
IT FITS!
yea, I was worried about fitting the pumps like this, but with a few mm to spare, that was no problem.
Really love those pumps, but I might change the top to plexi EKWB CSQ, to fit the theme of CSQ blocks.
But, many things can still happen. Might even change the GPU's to something stronger
At the left 120mm fan one of the alphacool radiator will be installed.
The 200mm Phobya radiator will get installed un top of the 180mm fan. So it's going to be outside the case.
The left side of the case (the one you see from on the above picture) will get as much window as possible to show of this nice view
So here some more detailed pics:
My plan was to watercool the RAM aswell, however that may not be possible, since it will get to high and block for the reservoirs :-/
And the backplates;
Really looking forward getting them painted. They will look so nice
A sad story though; I will be away from the build the next month
However, when I return, I got more time to work on this build
I will still answer to any of your questions, and keep you updated if the plan for the hardware change
Old 9th Mar 2013, 11:18   #15
ProZac
What's a Dremel?
ProZac has yet to learn the way of the Dremel
Maybe im blind, but can't really see where the cables from the PSU will go out as there is a wall on both sides on it (top/bottom) or are there room enough between the PSU and the back plate?
ProZac is offline   Reply With Quote
Old 9th Mar 2013, 15:48   #16
Evenge
Hypermodder
Evenge's Avatar
Evenge has yet to learn the way of the DremelEvenge has yet to learn the way of the Dremel
Watercooling squeezed into small case. I'll be watching this closely!
__________________
Project: Discovery
Project: Strobe
Main: i5 2500K - 8GB - GTX570 - Win 7
Laptop: Asus U36SD - i5 2430M - 4GB - Win 8 Pro
Evenge is offline   Reply With Quote
Old 10th Mar 2013, 15:49   #17
Fruergaard
Minimodder
There is a bit of room all around. Enough to make it possible ;-)
http://www.google.com/imgres?imgurl=...9QEwAw&dur=608
Thank you. Hope this will turn out better than Unobtianable
Old 10th Mar 2013, 20:14   #18
Lehani
Multimodder
Lehani's Avatar
Lehani has yet to learn the way of the DremelLehani has yet to learn the way of the DremelLehani has yet to learn the way of the DremelLehani has yet to learn the way of the DremelLehani has yet to learn the way of the DremelLehani has yet to learn the way of the Dremel
Wow, another mod from you mate
You keep doing the nodding going well how are the plastic EK parts??
Are they better or worse than the rest of EK's products?
__________________
Why did you buy that? - because i can
Mods: Watered Shadey
Lehani is offline   Reply With Quote
Old 18th Mar 2013, 15:37   #19
Fruergaard
Minimodder
Yeap, can't help it
I have actually only been using the plexi blocks (if that's what you mean with plastic?), så I can't tell you if there is a difference, except I believe the look way better ;-)
Old 18th Mar 2013, 16:48   #20
Axoxenon
Do it right the first time
Axoxenon has yet to learn the way of the Dremel
Hells yes! Subbed
Axoxenon is offline   Reply With Quote
Reply
Tags
modded, sg09, silverstone, watercooling, white
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
