Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 13th Feb 2013, 10:45   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree should be considered for presidentGareth Halfacree should be considered for presidentGareth Halfacree should be considered for presidentGareth Halfacree should be considered for presidentGareth Halfacree should be considered for presidentGareth Halfacree should be considered for presidentGareth Halfacree should be considered for presidentGareth Halfacree should be considered for presidentGareth Halfacree should be considered for presidentGareth Halfacree should be considered for presidentGareth Halfacree should be considered for president
Unigine launches Heaven 4.0 benchmark
Includes new 'Advanced' edition.
http://www.bit-tech.net/news/bits/20...ine-heaven-4/1
__________________
Co-author, Raspberry Pi User Guide, Meet the Raspberry Pi | gareth.halfacree.co.uk | twitter
bit-tech news correspondent, Custom PC columnist
I'm a filthy freelancer! Hire me!
Gareth Halfacree is offline   Reply With Quote
Old 13th Feb 2013, 12:09   #2
damien c
Mad FPS Gamer
damien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for president
Look's interesting will run it tonight to see if there is anything different in terms of scores.
__________________
Core I7 3930K, Rampage IV Extreme, 16GB Corsair Vengance 1600mhz, GTX 680 SLI, Corsair Force 3 250Gb SSD, Creative Sound Blaster X-Fi Titanium, NZXT Switch 810, XSPC RX 360mm + Alphacool 240mm All Copper, 10x Scythe Kazi Jyuni 1900rpm 5v & And It's Silent!!!!!!!!! .
Market Place Feedback
http://forums.bit-tech.net/showpost....&postcount=104
damien c is offline   Reply With Quote
Old 13th Feb 2013, 15:18   #3
The_Crapman
MD of Mutant Zombie Armies Inc
The_Crapman's Avatar
The_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpitThe_Crapman is almost as Godly as yodasarmpit
It's a little hard to compare results, as the settings are slightly different different from v3. However, seems like it's a fait bit tougher. On my rig-sig with everything at stock i got with the settings as close as I can make out:
1119, 21.3min, 113max and 44.4avg fps on v3
890, 7.5min, 85.7max and 35.3avg fps on v4
There's a couple of places in v4 where the fps bombs for a fraction of a second. Will run again and confirm where.
EDIT: Did 2 further runs, both had a small dip at the very beginning of scene 19 (on my first run it happened at halfway through 18 then start of 19), but nowhere near as dramatic as in my first run. Run No.2 went from 21.2 to 17.4 and run No.3 went from 21.3 to 17.1. First run must have been an anomaly.
__________________
Project: RAt MoD - Updated 16th June '13
i5 3570K, ASUS Maximus 5 Gene, Gainward GTX 670 Phantom, Modded Antec Kuhler 620, 4GB 1600MHz G.Skill RipjawsX CL6, Enermax Revolution 1050W, WD Raptor 150GB , Antec P182
How to Get a FREE (sort of) Hard Drive and Other Small Parts.[/b]
The_Crapman is offline   Reply With Quote
Old 14th Feb 2013, 12:27   #4
LightningPete
Diagnosis: ARMAII-Holic
LightningPete has yet to learn the way of the Dremel
If there was anything that could blue screen your overclocked GPU that was stable at windows, this is it
I find V3 was most effective for gaming when clocking the sheer nuts off a Core2Duo E6600 and GTX285 - managed to get 80mhz on the GPU chip stable with circa 230mhz mem whilst performing Uni benchies
LightningPete is offline   Reply With Quote
Old 14th Feb 2013, 12:49   #5
tozsam
Multimodder
tozsam has yet to learn the way of the Dremel
I originally set up my gfx card OC using heaven, which hit a max temp of 75ish, even on the new version. However Far Cry 3 has been burning a hole in my gfx card, hitting temps of 90+, but no crashes ingame. If this is a stress test/benchmark, why isnt it giving me the max temp of my card?
What prog can I use to find the max temp so I can clock my gfx card down a bit? I've heard my card clocks down itself (580gtx) with Furmark, so you dont get a realistic result.
tozsam is offline   Reply With Quote
Reply
Tags
benchmark, benchmarking tool, directx, gpu benchmark, heaven 4.0, linux, opengl, os x, unigine, unigine heaven, unigine heaven 4.0, windows
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
