#1 |
modder
home made all in one desktop
hello...i am a user of bit-tech and i see many awsome modd and scratch build and now i want to do my own all in one pc with touch screen
hardware in use mobo: rampage 3 gene cpu: socket 1366, i7 980 vga: evga gtx 460 1gb ddr5 ddr 3 : kingston 3x 4gb 1600mhz , 3x2gb 1600mhz hdd : 2x320 gb raid 0 , 2 tb WD cooling: corsair h100 psu : corsair tx 650M monitor in use is a lg 19" standard 1280x1024 with elo touch screen ![]() ![]()
#2 |
Tech-Kid
So, where are actual pictures, progress on the build etc.? This is not really a build log, but a proposed build.
#3 |
modder
![]() ![]() ![]() ![]() ![]() ![]() monitor frame is almoust done...now to test monitor to see if it work sorry for my bad english...i dont speak english for about 10 years now...
__________________
ASUS RAMPAGE 3 GENE, INTEL I7 980 CPU, 18GB DDR3 KINGSTON 1600MHZ, EVGA GTX460, 2X320 GB HDD RAID 0, 2TB HDD W.D.SATA 3 64 GREEN, CORSAIR TX650M , CORSAIR H100 CPU COOLER
#4 |
modder
testing monitor to see if anything is working...
#5 |
Minimodder
Looking good so far! I suspect weed2all's posts are stuck in a moderation queue.
I want to see how you mount the pc on the back of the screen
#6 |
modder
my ideea is to make a base for monitor and inside mount my pc...
#7 |
modder
i will use this pci-e extender on my project to put the video card to ocuppies a small space...
#8 |
modder
i will do anythyng tomorow
#9 |
modder
a litle update...i dont have much time to work on my project
an update to bottons control of the monitor ![]() spacers to install the motherboard ![]() ![]() ![]() ![]() ![]() ![]() installing motherboard ![]() ![]() video card supporte ![]()
#10 |
modder
#11 |
modder
that is all for now...update soon...i will mount de corsair h100 cpu cooler and hdd
then i will make a base to seat my pc... Last edited by weed2all; 19th Feb 2013 at 00:52. |
#12 |
modder
comment pls...any ideea...i wait for it.10x
#13 |
Supermodder
keep it up, you're going in the right direction, thought maybe you shpuld turn the gpu around so that it can get fresh air from the outside instead of pre-warmed air from the other components?
__________________
Works as a tool retailer, glad if i can help someone with tool questions! Hopes that i someday completes my first scratchbuild... |
#14 |
*learning english*
interesting project!
i'll grab some ideas for my next builds
__________________
10 re-plan "SuperBestBuild Of My Dream" 20 have a sleep 30 goto 10 |
#15 |
modder
hy there kelmannen...i have thinking that on the gpu, but it will occupies a lot of space because the pci-e extender...the right way a think is this...thought i will istall a few small fans maybe 60x60 or smallest for the air circulation
__________________
#16 |
modder
i want a computer smallest as i can take...
__________________
#17 |
Supermodder
yeye, got you there
the intake fans might be a good idea but 60mm fans do often have very bad noise levels :/
__________________
#18 |
What's a Dremel?
If you flip the GPU you should be able to mount some cross flow fans in the chassis that can be controlled by the GPU board to keep it cool. That way you could take the cover off and slim it down some. But like kelmannen said I'd definitely flip the GPU, even then you could show it off a little
#19 |
Modder
seems nice
and just a question, how well those riser cables work?
#20 |
modder
i will try on a 60mm and smallest like 40mm fan...after testing i will decide wich i use...for now i will resume to finish entire case...i think to use acrylic to make the protection of entire pc...
__________________
| Thread Tools | |
| View Mode | |
