#1 |
Master Modder
F@H has crashed daily, help!
I am folding SMP only. My system specs Xeon 1245v2, 32GB 1600mhz, Samung 840Pro, ASRock Extrme 4M, Highpoint SAS Raid, 5 hard disks, Quadro 2000 and 620w Seasonic psu. All latest updates from microsoft, etc. and that may even be it. It updated last week and has crashed in the night every day. I set the system to not restart so I get a chance to see the error. Im not sure how to figure out what part of the update could have screwed it up, if that is it. Everything else has run fine on it and error logs show F@H is indeed crashing and causing the restart.
Anybody have any ideas?
__________________
JAllen Labs GT1000- 3770K, 32GB Dominators, MSI 570GTX, Samsung 840 Pro 256GB SSD, 4 drive RAID 0 and 3TB storage in a Silverstone Fortress GT03, Logitech G9X Gaming mouse on Razer eXact Mat, Custom built Fostex studio monitors, Yamaha amp, Onkyo Tuner and Garrad turn table. |
#2 |
Master Modder
I updated the MB Bios as well as a few other things and it made it through the night...and then crashed this evening. This time it was not a BSOD though. Here is the error-
C:\Users\JAllen Labs GT1000N\AppData\Local\Temp\WER2711.tmp.WERInternal Metadata.xml C:\Users\JAllen Labs GT1000N\AppData\Local\Temp\WER3B6C.tmp.appcompat.t xt C:\Users\JAllen Labs GT1000N\AppData\Local\Temp\WER3B7D.tmp.hdmp I have no idea what that means. Only F@H crashes, temps are great and everything seems to be as it should be. Although it brought up the error screen that it crashed, it kept on folding? Ideas?
__________________
#3 |
Supermodder
Those files might just be the crash report going by this link.
Do you get any other messages? Have you installed any other software prior to this problem? Can you also do a quick check if uninstalling, wiping out any data, and reinstalling helps at all? Maybe best to try and let the current wu finish, if it can, before you do this.
__________________
Folding Summary Desktop: Corsair Carbide 400R; Asus Sabertooth X79; Intel i7-3930K; Hydro H100; EVGA GTX 580 772MHz; Corsair Vengeance 16GB DDR3 1600MHz; Corsair HX850W; Samsung 256GB 840 Pro; 2TB HDD; Windows 7 Ult. 64bit. |
#4 |
Hypermodder
Have a look at the update history. Are any of the ones installed lately hardware related?
__________________
#5 |
Master Modder
Net Framework 4 updates and security updates only. It has run overnight the last to nights under light load with no crashes. I am going to re install F@H and try it tonight.
__________________
| Thread Tools | |
