Old 17th Feb 2013, 09:22   #1
Chicken76
Hypermodder
Chicken76's Avatar
Chicken76 - it's over 9000!!!!!!!!1!1!1!!!Chicken76 - it's over 9000!!!!!!!!1!1!1!!!Chicken76 - it's over 9000!!!!!!!!1!1!1!!!Chicken76 - it's over 9000!!!!!!!!1!1!1!!!Chicken76 - it's over 9000!!!!!!!!1!1!1!!!Chicken76 - it's over 9000!!!!!!!!1!1!1!!!Chicken76 - it's over 9000!!!!!!!!1!1!1!!!Chicken76 - it's over 9000!!!!!!!!1!1!1!!!Chicken76 - it's over 9000!!!!!!!!1!1!1!!!Chicken76 - it's over 9000!!!!!!!!1!1!1!!!Chicken76 - it's over 9000!!!!!!!!1!1!1!!!
v7 Linux client question
How do you access the information about the current work unit as you could with the v6 client through the unitinfo.txt file ? I've looked through all the files, and there isn't an equivalent of that file in v7. I'm more interested in reading the download and due time of the current work unit.
I should mention that I've installed the tar.gz bare client.
__________________
Folding stats
Chicken76 is offline   Reply With Quote
Old 18th Feb 2013, 20:15   #2
Chicken76
Hypermodder
Chicken76's Avatar
Second question: when run with --max-units=1 the client remains active (after finishing a WU) although not processing anything. It has to be killed manually, otherwise it triggers the "database is locked" error.
Any way to make it quit after processing the number of WUs supplied by the --max-units argument?
__________________
Folding stats
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
