Reply
Thread Tools View Mode
Old 18th Feb 2013, 18:14   #1
Pranja
Fenrir The Wolf
Pranja's Avatar
Pranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for presidentPranja should be considered for president
Arya-update 14.5.
For the last three months I have been planning a small office/multimedia PC made of wood.
I was waiting to finish my semester at college and now,when it is over-I presend you my project-Arya.
Here are rendered images of Arya.
Yesterday, my friend brought me box containing the laser-cut wooden parts.
And today,after some playing with the parts:
__________________
_Cosmos S Reaper_ _L.R.E.C._ _Scorpio_
_Arya_-under construction _ROG Crawler_
Pranja is offline   Reply With Quote
Old 18th Feb 2013, 21:03   #2
tekonivel
Multimodder
tekonivel - it's over 9000!!!!!!!!1!1!1!!!tekonivel - it's over 9000!!!!!!!!1!1!1!!!tekonivel - it's over 9000!!!!!!!!1!1!1!!!tekonivel - it's over 9000!!!!!!!!1!1!1!!!tekonivel - it's over 9000!!!!!!!!1!1!1!!!tekonivel - it's over 9000!!!!!!!!1!1!1!!!tekonivel - it's over 9000!!!!!!!!1!1!1!!!tekonivel - it's over 9000!!!!!!!!1!1!1!!!tekonivel - it's over 9000!!!!!!!!1!1!1!!!tekonivel - it's over 9000!!!!!!!!1!1!1!!!tekonivel - it's over 9000!!!!!!!!1!1!1!!!
You have found your style. Will be following.
__________________
Completed : Bulky
tekonivel is offline   Reply With Quote
Old 18th Feb 2013, 21:11   #3
Pranja
Fenrir The Wolf
Pranja's Avatar
Thanks. Although, I don't understand-what do you mean when you say "You have found your style."?
__________________
Old 18th Feb 2013, 21:17   #4
tekonivel
Multimodder
I mean this has similar construction style as scorpio. and they both look awesome.
__________________
Completed : Bulky
Old 18th Feb 2013, 21:25   #5
Pranja
Fenrir The Wolf
Pranja's Avatar
I see-thanks for explanation. They are similar construction because my friend's CNC machine only have two axes. If we had CNC with three axes, construction would be different a lot.
__________________
Old 19th Feb 2013, 17:52   #6
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate is the Cheesecake. Relix smiles down upon them.Cheapskate is the Cheesecake. Relix smiles down upon them.Cheapskate is the Cheesecake. Relix smiles down upon them.Cheapskate is the Cheesecake. Relix smiles down upon them.Cheapskate is the Cheesecake. Relix smiles down upon them.Cheapskate is the Cheesecake. Relix smiles down upon them.Cheapskate is the Cheesecake. Relix smiles down upon them.Cheapskate is the Cheesecake. Relix smiles down upon them.Cheapskate is the Cheesecake. Relix smiles down upon them.Cheapskate is the Cheesecake. Relix smiles down upon them.Cheapskate is the Cheesecake. Relix smiles down upon them.
OOOH! You should have added a little extra material so you could sand the whole thing round.
Cheapskate is offline   Reply With Quote
Old 19th Feb 2013, 19:13   #7
Pranja
Fenrir The Wolf
Pranja's Avatar
You mean because the black stuff? I actualy like it that way. It shows the shape of case little bit better.
Todays progress-side panels assembled.
__________________
Old 20th Feb 2013, 15:26   #8
Pranja
Fenrir The Wolf
Pranja's Avatar
Today I continued my work on Arya.
Second side panel is finished.
I received brown paracord and golden power button.
One meter long steel rod+saw=
Assembly of top and bottom of the case.
Top and bottom mounted on the case.
Mockup with side panel.
__________________
Old 21st Feb 2013, 19:16   #9
Pranja
Fenrir The Wolf
Pranja's Avatar
New and better pics of Arya.
__________________
Old 21st Feb 2013, 23:53   #10
faxiij
Multimodder
faxiij's Avatar
faxiij has yet to learn the way of the Dremelfaxiij has yet to learn the way of the Dremelfaxiij has yet to learn the way of the Dremel
I knew it seemed familiar somehow...
http://www.tuvie.com/lfrit-toaster-d...simple-button/
Like your adaptation though, will be interesting to see how it looks finished!
faxiij is offline   Reply With Quote
Old 22nd Feb 2013, 00:21   #11
Pranja
Fenrir The Wolf
Pranja's Avatar
That is nice design.
But this mod is not related to it in any way.
Thanks for the link.
__________________
Old 22nd Feb 2013, 16:28   #12
Pranja
Fenrir The Wolf
Pranja's Avatar
Today work on the project continued.
Golden power switch with brown paracord on cable.
Front panel had too long cables and too many connectors.
USB connectors are placed on mini PCB's with extended cables.
__________________
Old 23rd Feb 2013, 20:38   #13
Pranja
Fenrir The Wolf
Pranja's Avatar
New parts arrived an hour ago.
Front part covered with leather, rear part and new spacers.
I will post better pics tomorrow.
__________________
Old 24th Feb 2013, 17:12   #14
Pranja
Fenrir The Wolf
Pranja's Avatar
Today I placed fornt USB connectors and I/O shield. You can see the size od Arya compared to that I/O shield.
__________________
Old 24th Feb 2013, 18:39   #15
jokkos
Belgian beer modder
jokkos's Avatar
jokkos has yet to learn the way of the Dremeljokkos has yet to learn the way of the Dremel
Looking good. I like the look of the front piece with the leather, combined with the wood.
__________________
Der_Meister: 100% completed, again... project log here.
jokkos is offline   Reply With Quote
Old 24th Feb 2013, 19:42   #16
Waynio
Keep calm & mod on. =)
Waynio's Avatar
Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.Waynio is the Cheesecake. Relix smiles down upon them.
This is really nice, got to love layers, enables complex shapes & retains strength.
Waynio is offline   Reply With Quote
Old 24th Feb 2013, 20:38   #17
Pranja
Fenrir The Wolf
Pranja's Avatar
Thanks jokkos. I am actually thinking of using more leather on Arya-maybe I cover this bottom ring with leather.
Thanks Waynio. Layers are nice,but they are PITA to put together.
__________________
Old 24th Feb 2013, 21:09   #18
Asouter
Tremendously Difficult Lifestyle
Asouter's Avatar
Asouter is the Cheesecake. Relix smiles down upon them.Asouter is the Cheesecake. Relix smiles down upon them.Asouter is the Cheesecake. Relix smiles down upon them.Asouter is the Cheesecake. Relix smiles down upon them.Asouter is the Cheesecake. Relix smiles down upon them.Asouter is the Cheesecake. Relix smiles down upon them.Asouter is the Cheesecake. Relix smiles down upon them.Asouter is the Cheesecake. Relix smiles down upon them.Asouter is the Cheesecake. Relix smiles down upon them.Asouter is the Cheesecake. Relix smiles down upon them.Asouter is the Cheesecake. Relix smiles down upon them.
Ohh the joys of using layers, they are a pain aren't they The spacers make it a lil easier, how many times did you forget to use one and have to take it apart again ?
__________________
Finished Project : D33P THOUGHT
Finished Project : THING
Current Project : Mini Moto Mayhem
Asouter is online now   Reply With Quote
Old 24th Feb 2013, 21:12   #19
Pranja
Fenrir The Wolf
Pranja's Avatar
I didn't forgot any spacers,but few times rod fell out from hole and I had to put everything back.
__________________
Old 25th Feb 2013, 18:14   #20
Pranja
Fenrir The Wolf
Pranja's Avatar
Today I worked on the electronics again-this time it was the RGB LED's with remote control (now you know what the smallest hole in front serves for ).
Of course I didn't like the look and size of the controller, so I mod it a "little". XD
PCB is insulated.
And now the fun part.
And small video of me playing with controller.
__________________
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
