Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 19th Feb 2013, 11:41   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
MSI teases G Series gaming motherboards
Killer network chips, Gaming Device Ports.
http://www.bit-tech.net/news/hardwar...msi-g-series/1
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is offline   Reply With Quote
Old 19th Feb 2013, 11:59   #2
andrew8200m
Mod Master
andrew8200m's Avatar
andrew8200m is a Super Spamming Saiyanandrew8200m is a Super Spamming Saiyanandrew8200m is a Super Spamming Saiyanandrew8200m is a Super Spamming Saiyanandrew8200m is a Super Spamming Saiyanandrew8200m is a Super Spamming Saiyanandrew8200m is a Super Spamming Saiyanandrew8200m is a Super Spamming Saiyanandrew8200m is a Super Spamming Saiyanandrew8200m is a Super Spamming Saiyanandrew8200m is a Super Spamming Saiyan
Couple this with the pics I have and I am thinking it might actually look like a motherboard. Loving the teaser pic
__________________
Systems with parts from various manfacturers
andrew8200m is online now   Reply With Quote
Old 19th Feb 2013, 12:23   #3
damien c
Mad FPS Gamer
damien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyandamien c is a Super Spamming Saiyan
Have to say MSI are really getting better with there motherboards, to the point I am not looking at the old faithfull Asus boards for my systems.
The Killer cards though I have to say seem more of a gimmick to me, as the last one I used on a motherboard was on a Gigabyte X58 board and it was awfull, and then I tried the add in card and that was awfull to so unless there is a massive improvement then that would be a feature, I would not be interested in seeing on the boards.
__________________
I7 6700K, 32Gb Corsair 2400Mhz, MSI Z170 Gaming M7, 980Ti SLI, 840 Evo 500Gb, 2x 3TB WD Red, Corsair RM 1KW (White cables kit), Custom CPU Loop, Phanteks Enthoo Primo
damien c is offline   Reply With Quote
Old 19th Feb 2013, 12:40   #4
andrew8200m
Mod Master
Cant beat good old Intel NIC
__________________
Old 19th Feb 2013, 13:58   #5
law99
Custom User Title
law99's Avatar
law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.
I bought an 77 series MSI board for 120~ from what I remember and it had a voltage cap on overclocking of 1.35v. I'd not had such a limit on all my Asus boards before even when I only spent 70 with overclocking in mind.
In the interest of fairness though, this will be a premium board I'd imagine and not have such a restriction.
__________________
3570k WC @ 4.7giggles | 8gb Kingston 2133mhz | ASUS Sabertooth Z77 | soaking 1070 gtx | Seasonic x-660w | NZXT 810 switch | Crucial M4 128gb | 2x F3 1tb Raid 1 | NZXT Sentry 6ch 50w fan controller | BenQ bl3200pt 2560x1440p
law99 is offline   Reply With Quote
Old 19th Feb 2013, 13:59   #6
aLtikal
1338-One step infront of the pro's
aLtikal is a Super Spamming SaiyanaLtikal is a Super Spamming SaiyanaLtikal is a Super Spamming SaiyanaLtikal is a Super Spamming SaiyanaLtikal is a Super Spamming SaiyanaLtikal is a Super Spamming SaiyanaLtikal is a Super Spamming SaiyanaLtikal is a Super Spamming SaiyanaLtikal is a Super Spamming SaiyanaLtikal is a Super Spamming SaiyanaLtikal is a Super Spamming Saiyan
Actually this is a bit gimmicky tbh, you can change the polling rate of your USB mouse in some logitech settings and if you havn't got a logitech mouse - there is a program that allows you to do it (i cant remember its name - it might be a registry key you change? I cant remember)...I was doing it years ago when playing competitive counter-strike (as was every other player).
__________________
aLtikal's Rig...
| Antec P182 | Q6700 @ 3.1Ghz| Abit AB9 Pro | 5770 1Gb Vapor-X | 4GB 800mhz Geil BlackDragon 4-4-4-12 | XtremeMusic | Z-5500's | MX-518| Samsung 2232bw 2ms 1680x1050|
aLtikal is offline   Reply With Quote
Old 19th Feb 2013, 15:52   #7
Paradigm Shifter
de nihilo nihil fit
Paradigm Shifter's Avatar
Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.Paradigm Shifter is the Cheesecake. Relix smiles down upon them.
This.
When my Gigabyte EX58-UD5 bit the dust (for no apparent reason) I had a rush to replace it; ended up with one of the G1.Killer series boards... the 'Killer' NIC on it is utter junk. I picked up an Intel PCI-E NIC and all my problems vanished.
__________________
Core i7 5820K | 32GB Crucial DDR4 | Asus Rampage V Extreme | Titan X | 1TB SSD + 6TB HDD | 7680x1440 + 1920x1200
Paradigm Shifter is offline   Reply With Quote
Old 19th Feb 2013, 17:02   #8
phuzz
This is a title
phuzz's Avatar
phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.
Sure about that?
http://blog.krisk.org/2013/02/packets-of-death.html
phuzz is offline   Reply With Quote
Old 19th Feb 2013, 19:47   #9
mdshann
Modder
mdshann has yet to learn the way of the Dremel
How does someone 'crow'?
mdshann is offline   Reply With Quote
Old 19th Feb 2013, 20:21   #10
Gareth Halfacree
WIIGII!
bit-tech Staff
Easy: talk proudly about an achievement . Or, I dunno, glue feathers on yourself and caw.
__________________
Old 19th Feb 2013, 21:19   #11
ShinyAli
Supermodder
ShinyAli's Avatar
ShinyAli - it's over 9000!!!!!!!!1!1!1!!!ShinyAli - it's over 9000!!!!!!!!1!1!1!!!ShinyAli - it's over 9000!!!!!!!!1!1!1!!!ShinyAli - it's over 9000!!!!!!!!1!1!1!!!ShinyAli - it's over 9000!!!!!!!!1!1!1!!!ShinyAli - it's over 9000!!!!!!!!1!1!1!!!ShinyAli - it's over 9000!!!!!!!!1!1!1!!!ShinyAli - it's over 9000!!!!!!!!1!1!1!!!ShinyAli - it's over 9000!!!!!!!!1!1!1!!!ShinyAli - it's over 9000!!!!!!!!1!1!1!!!ShinyAli - it's over 9000!!!!!!!!1!1!1!!!
Yes it does seem gimmicky, what's the big deal about changing the polling rate of USB mice as these mobo's are aimed at gamers then any gamer buying one will almost certainly have a gaming mouse and most of them if not all of them come with driver software that allows much more configuration than just polling rates, pretty unrealistic to think that any gamer buying these mobo's is using some cheapo mouse
ShinyAli is offline   Reply With Quote
Old 19th Feb 2013, 22:15   #12
tad2008
Supermodder
tad2008 has yet to learn the way of the Dremel
It's 2013 and MSI want to triple the amount of gold plating they use for the PS/2 and USB 2.0 ports when they could have used USB 3.x
tad2008 is offline   Reply With Quote
Old 20th Feb 2013, 03:14   #13
Bindibadgi
Am I out of touch?
Bindibadgi's Avatar
Bindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming SaiyanBindibadgi is a Super Spamming Saiyan
Amen brother.
And didn't ASRock and Gigabyte do these features already? And how popular were G1's and Fatal1ty's in review?
Competition is always a good thing! But, if this is all there is, it's gonna be a good Haswell launch for ASUS
__________________
The bitterness of poor quality remains long after the sweetness of low price is forgotten.
Bindibadgi is offline   Reply With Quote
Old 21st Feb 2013, 00:16   #14
Anfield
I *am* a Dremel
Anfield's Avatar
Anfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming SaiyanAnfield is a Super Spamming Saiyan
I blame Intel and Amd for this influx of pointless features on mainboards.
Back in the old days before the memory controller and north bridge got moved to the cpu it actually mattered what mainboard you bought, but these days with so much having moved to the cpu mainboard manufacturers are desperate to somehow stand out from the masses and unfortunately that leads to attempts to charge extra for things like "killer" nic.
__________________
i7 6700k, Asus Maximus Gene VIII, 2x8GB Corsair Vengeance 3000 DDR4, Reference GTX 980Ti, 512GB Samsung 950 Pro, 4TB WD Black, Corsair H105, Corsair RM850i, Corsair Carbide Air 240.
Max Blackbird TKL Mech KB, Logitech G402, AOC U3477PQU (34" 21:9 ftw)
Anfield is offline   Reply With Quote
Old 23rd Feb 2013, 14:20   #15
EasterEEL
What's a Dremel?
EasterEEL has yet to learn the way of the Dremel
The embedded Killer E2200 would have to be a lot better than the embedded E2100 in my Gigabyte motherboard. It stops working (every time) with large file transfers over my LAN and loses network connectivity requiring a reboot. Plenty posting similar issues on Bigfoot the forum when it existed.
EasterEEL is offline   Reply With Quote
Reply
Tags
g series, gaming, gaming device port, gaming motherboard, killer e2200, motherboard, msi g series, pc gaming, qualcomm
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
