View Poll Results: Coolant colour?
Blue 10 10.42%
Green 7 7.29%
Yellow 5 5.21%
Pink (Raspberry Colour) 59 61.46%
Red 16 16.67%
Purple 6 6.25%
Multiple Choice Poll. Voters: 96. You may not vote on this poll
Reply
Thread Tools View Mode
Old 19th Feb 2013, 15:48   #1
Phame
CNC mad!
Phame's Avatar
Phame - it's over 9000!!!!!!!!1!1!1!!!Phame - it's over 9000!!!!!!!!1!1!1!!!Phame - it's over 9000!!!!!!!!1!1!1!!!Phame - it's over 9000!!!!!!!!1!1!1!!!Phame - it's over 9000!!!!!!!!1!1!1!!!Phame - it's over 9000!!!!!!!!1!1!1!!!Phame - it's over 9000!!!!!!!!1!1!1!!!Phame - it's over 9000!!!!!!!!1!1!1!!!Phame - it's over 9000!!!!!!!!1!1!1!!!Phame - it's over 9000!!!!!!!!1!1!1!!!Phame - it's over 9000!!!!!!!!1!1!1!!!
Raspberry Pi Competition - The 'Golden' Wet Pi. *Finished with final Pictures*
Hello guys,
I will be building a scratch case for the RPi and also watercooling it. The block will span across the three main hot spots of the board. I also know there is no need to watercool it, but I like to do something alittle different and hopefully have a Pi to put in it!
Why am I doing this project?
I hadn't been on bit-tech forum for a while, and was one day browsing the site looking for inspiration to get me to mod/build a new case. I came across Combatus post about the competition, the first thing that came to mind was... "why not watercool this thing?" - That became a problem, as I started to look at jrs77 (thanks by the way) model of the RPi and throw some modelling ideas on CAD, it quickly became apparent that the thing was alot smaller then I first anticipated. Not to worry I thought, il give it ago so thats where we are.
Things to be done:
- Re machine the new designed for waterblock. DONE
- Polish the acrylic for the top of res. DONE
- Cut the acrylic for the top of waterblock. DONE
- Polish the waterblock and res with 1500, 2000, 2500 grit WnD. DONE
- Cut the Pi board holders. DONE
- Tap the waterblock M1.6. DONE
- Turn down some hose fittings DONE
- Gold plate all the aluminium DONE
- Powder Coat the Raspberry Pi holders DONE
- Assemble and test DONE
- COMPLETE THE WET PI. DONE
--------------------------------------------Raspberry Pi--------------------------------------------
Watercooled Raspberry Pi
Hopefully the first one in the world?
Waterblock:
Here's a picture of the waterblock, latest picture!
Radiator:
Water tight test.
The dims for the block are: 98.5 x 70.0 x 17.0mm and made of Aluminium and acrylic. I will be gold plating the Aluminium on both the rad and waterblock.
Pump:
This is the pump that will be used for this build, http://www.micropumps.co.uk/
__________________
'You had my curiosity, now you have my attention'
Work in the pipeline *Server*
Completed Projects. *Orange and Black* and *The Wet Pi*
Phame is offline   Reply With Quote
Old 19th Feb 2013, 15:50   #2
Shirty
Good news everyone!
Shirty's Avatar
Shirty can't run CrysisShirty can't run CrysisShirty can't run CrysisShirty can't run CrysisShirty can't run CrysisShirty can't run CrysisShirty can't run CrysisShirty can't run CrysisShirty can't run CrysisShirty can't run CrysisShirty can't run Crysis
How deliciously extravagant.
I assume you've already watercooled your smartphone?
I'll be watching this one eagerly.
__________________
2500K | Corsair H55 | HIS 7950 | 8GB XMS3 | 128GB Crucial M4 | Samsung 2TB | ASRock H77M-ITX | Corsair CX500M | White Bitfenix Prodigy | Dell U2311H | Creative T6060s | Ducky G2 Pro TKL (Reds) | Logitech G500
Why.
Shirty is online now   Reply With Quote
Old 19th Feb 2013, 15:58   #3
Phame
CNC mad!
Phame's Avatar
That was a quick reply!
Cheers dude!
__________________
Old 19th Feb 2013, 16:12   #4
kelmannen
Supermodder
kelmannen has yet to learn the way of the Dremelkelmannen has yet to learn the way of the Dremelkelmannen has yet to learn the way of the Dremelkelmannen has yet to learn the way of the Dremel
a watercooled pi? this is awesomely riduculus but i'll watch for sure!
__________________
Works as a tool retailer, glad if i can help someone with tool questions!
Hopes that i someday completes my first scratchbuild...
kelmannen is offline   Reply With Quote
Old 19th Feb 2013, 16:24   #5
White-Fox
Modder
White-Fox's Avatar
White-Fox is a hoopy frood who really knows where their towel is.White-Fox is a hoopy frood who really knows where their towel is.White-Fox is a hoopy frood who really knows where their towel is.White-Fox is a hoopy frood who really knows where their towel is.White-Fox is a hoopy frood who really knows where their towel is.White-Fox is a hoopy frood who really knows where their towel is.White-Fox is a hoopy frood who really knows where their towel is.White-Fox is a hoopy frood who really knows where their towel is.White-Fox is a hoopy frood who really knows where their towel is.White-Fox is a hoopy frood who really knows where their towel is.White-Fox is a hoopy frood who really knows where their towel is.
holy s**t dude i am truly waiting more from this! good job.
White-Fox is offline   Reply With Quote
Old 19th Feb 2013, 16:29   #6
Phame
CNC mad!
Phame's Avatar
Cheers guys!
Won't let ya down!
__________________
Old 19th Feb 2013, 16:41   #7
Achron
Cad Pro Quo
Achron's Avatar
Achron has yet to learn the way of the DremelAchron has yet to learn the way of the DremelAchron has yet to learn the way of the DremelAchron has yet to learn the way of the DremelAchron has yet to learn the way of the DremelAchron has yet to learn the way of the Dremel
How exactly is the radiator removing the heat from the loop? It looks just like another water block.
__________________
Completed: Acronym
Achron is offline   Reply With Quote
Old 19th Feb 2013, 16:48   #8
Phame
CNC mad!
Phame's Avatar
Its similar to having another waterblock but with an added heatsink type configuration machined into the back with possibly a fan to deplace the heat, if there is any!
Loved Acronym by the way!
__________________
Old 19th Feb 2013, 17:17   #9
jrs77
theorycrafting
jrs77's Avatar
jrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for presidentjrs77 should be considered for president
Let's talk about overkill
__________________
...and allways remember, that the world is an orange!
Define Mini Black [Gigabyte Z77MX-D3H | intel i5-3450 | Kingston HyperX DDR3-1600 8GB | Gigabyte GTX660OC Windforce2 | intel 330 120GB | WD AV GP 1TB]
jrs77 is offline   Reply With Quote
Old 19th Feb 2013, 17:43   #10
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for president
-All for a prize that costs less than a meal at the local fast-food shop.
That's the kind of crazy, gung-ho, madcap thinking that brought me here in the first place. Glorious!
Cheapskate is offline   Reply With Quote
Old 19th Feb 2013, 18:37   #11
elAwesome
Multimodder
elAwesome's Avatar
elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.
Hoooooooooly sh*t.
This is the pure meaning of overkill.
But this is gonne be awesome
You could try to overclock it, the cooling should be fine :P
elAwesome is offline   Reply With Quote
Old 19th Feb 2013, 18:56   #12
Phame
CNC mad!
Phame's Avatar
- Cheers for the time you took to do that model dude.
I know its only cheap but being eXtreme is why we enjoy doing these things right?
I think the gold plating is going to be more expensive then alot of Pi's.
Originally Posted by elAwesome View Post
Hoooooooooly sh*t.
Thanks dude, I will overclock it just for you
__________________
Old 19th Feb 2013, 19:09   #13
elAwesome
Multimodder
elAwesome's Avatar
Yaaaay
A 5Ghz Raspberry...
Old 20th Feb 2013, 06:46   #14
tekonivel
Multimodder
tekonivel - it's over 9000!!!!!!!!1!1!1!!!tekonivel - it's over 9000!!!!!!!!1!1!1!!!tekonivel - it's over 9000!!!!!!!!1!1!1!!!tekonivel - it's over 9000!!!!!!!!1!1!1!!!tekonivel - it's over 9000!!!!!!!!1!1!1!!!tekonivel - it's over 9000!!!!!!!!1!1!1!!!tekonivel - it's over 9000!!!!!!!!1!1!1!!!tekonivel - it's over 9000!!!!!!!!1!1!1!!!tekonivel - it's over 9000!!!!!!!!1!1!1!!!tekonivel - it's over 9000!!!!!!!!1!1!1!!!tekonivel - it's over 9000!!!!!!!!1!1!1!!!
Awesome! I was just thinking that some one should do watercooled Pi. And I start browsing the forums and here it is. Will be following this like a hawk.
Also good luck for the competition.
__________________
Completed : Bulky
tekonivel is offline   Reply With Quote
Old 21st Feb 2013, 17:24   #15
Phame
CNC mad!
Phame's Avatar
Yaaaay
A 5Ghz Raspberry...
I think the max is 1GHz but il have a go!
Thats what I was thinking when I first saw the Pi comp. Thankyou dude..
Loving Bulky by the way looks scchweeeet!
Little update ive changed the Rad/Res render below.
Will be machining this up in abit when the CNC has finished cutting a tool.
__________________
Old 21st Feb 2013, 17:57   #16
NoobNeb
Herp a derp
NoobNeb's Avatar
NoobNeb has yet to learn the way of the Dremel
New design is much more apt enough renders already though let's see some metal action
__________________
bedibop
NoobNeb is offline   Reply With Quote
Old 21st Feb 2013, 18:45   #17
Scirocco
Boobs, I have them, you lose.
Scirocco's Avatar
Scirocco - it's over 9000!!!!!!!!1!1!1!!!Scirocco - it's over 9000!!!!!!!!1!1!1!!!Scirocco - it's over 9000!!!!!!!!1!1!1!!!Scirocco - it's over 9000!!!!!!!!1!1!1!!!Scirocco - it's over 9000!!!!!!!!1!1!1!!!Scirocco - it's over 9000!!!!!!!!1!1!1!!!Scirocco - it's over 9000!!!!!!!!1!1!1!!!Scirocco - it's over 9000!!!!!!!!1!1!1!!!Scirocco - it's over 9000!!!!!!!!1!1!1!!!Scirocco - it's over 9000!!!!!!!!1!1!1!!!Scirocco - it's over 9000!!!!!!!!1!1!1!!!
Ha! Love it!
__________________
"If she were any more of a bitch, she'd have puppies!" Victoria Chase, Hot in Cleveland.
Current project: La Fée Verte
Scirocco is offline   Reply With Quote
Old 21st Feb 2013, 19:42   #18
siliconfanatic
Car lover and Speed Junkie
siliconfanatic's Avatar
siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.siliconfanatic is definitely a rep cheat.
From the rad i thought you were gonna use orang and blacks loop to cool it. That wouldve proven to be quite interesting
Overkill is awesome
__________________
Originally Posted by quizz_kid View Post
Blackalize it!
I *am* the guy who loves too many threads to bump them all.
siliconfanatic is offline   Reply With Quote
Old 21st Feb 2013, 23:49   #19
faxiij
Multimodder
faxiij's Avatar
faxiij has yet to learn the way of the Dremelfaxiij has yet to learn the way of the Dremelfaxiij has yet to learn the way of the Dremel
yup, couldn't agree more.
looks like we have a winner for the comp now...given you finish this.
completely insane, completely stupid and nuts, totally overkill, fully bonkers. and thus....completely awesome.
faxiij is offline   Reply With Quote
Old 22nd Feb 2013, 01:37   #20
siliconfanatic
^this^
__________________
Blackalize it!
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
