Reply
Thread Tools View Mode
Old 19th Feb 2013, 22:27   #1
elAwesome
Multimodder
elAwesome's Avatar
elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.elAwesome is a hoopy frood who really knows where their towel is.
El's Deskintosh - Final pictures
FINALLY FINISHED!
Head over to page 2 for the other final pictures
Hey guys,
I've been visiting this forum for quite some time now, and I've been planning my own mod for a few months now while getting inspiration from here.
My biggest inspiration was l3p's d3sk, I absolutely love it.
So I decided to build something similar
The name is made up from desk and Macintosh (Macintosh because I'm gonna dual-boot Win7 and OS X from it), just in case you wonder.
Further down in this post you'll see an image of the desk where I'm going to place all the stuff.
What do I want?
-It has to be silent. Really silent. That's why I'm spending all this money on a water cooling setup.
-It has to be really good looking. Another reason why I spent all this money on a water cooling setup.
-It has to be really fast. I'm a semi-professional graphic designer, so I'm doing a lot of video editing, which takes up every bit of power you can throw at it. Another reason why I spent all this money on a water cooling setup, to overclock the last little bit out of it LGA2011 wasn't worth the money for me, Ivy Bridge will do fine. I rather got an excellent GPU for some nice gaming evenings
-It's gotta run OS X on it - For working, I really prefer it over Windows. And even running on a PC's hardware, it's more stable than Windows...
This is the first time that I build a PC by myself, I've only been using Macs before. So please be kind
So, let's begin:
First package arrived, with some hardware in it:
Intel i7 3770k
ASUS Sabertooth Z77
EVGA GTX680 SuperClocked
2x Corsair Dominator 1600MHZ 8GB (16 in total)
2x Samsung 830 128GB SSD
Seasonic X-750 750W power supply
Had 3 WD 1TB drives and a slot-load DVD drive previously used.
Quickly installed everything to boot it up for the first time
Building a PC is far easier than I thought.
Next package from AquaTuning Switzerland:
A hell lot of stuff....
Water blocks:
EK Supremacy Plexi CSQ
Ek Dominator Plexi CSQ
EK FC-680 GTX+ Plexi CSQ
Rest:
Phobya Xtreme 1080 NOVA radiator (lol, huge thing)
Alphacool D5 with preinstalled pump top
Phobya 250mm reservoir
2x BeQuiet SilentWing2 fans
4x Phobya 180mm Slim fans for the rad
Some tubing and a few fittings, some sleeve and sleeving tools
And a lot of cables..
Another package arrived:
I orded a Lian Li PC-7HX to strip and reuse its internal parts.
Stripping was done quickly:
Looks pretty naked
___________________________________________
Let's get to the building!!
I started off installing the rad and the pump. For this, I'm going to use a spare PowerMac G5 case as an external radiator housing, to save some space in the desk.
Radiator with fans and pump:
Fits like a glove! Didn't had to screw/glue anything, just firmly push the pump inside, and everything sits perfectly. Made my evening
No metalwork necessary at all
The G5 is still by far the most beautiful case out there...
Moving on:
This is where I will put the hardware.
Those are two pieces of glass, extra stable ones. I'm going to install it in the lower left corner, already placed the stuff in the picture. In the front, I'm going to insert another piece of glass, while on the sides and the back I'm place some black mesh metal.
More on that to follow. Just for you to know what this is all about.
Also did some other small things:
The Lian Li HDD rack:
And after 15min of working, it's now equipped with a spare 120mm fan:
And installed HDDs:
I was amazed how much the fan improved my HDD temps, they used to be something like 35-40°C, now they dropped to about 30°. The fans is running at about 800RPM, you can't really hear it.
Started to sleeve some cables:
First time ever that I sleeved a cable, I'm actually quite happy with it.
With a spare MacBook power button, I pmrovised a little power button for this rig:
I find it much nicer than the usual Lamptron vandal switches (I've got one) and it also feels nicer. Just a small detail, I know...
Next, the mobo tray was on my list:
I took it form the Lian Li case, and glues some nice feet on it.
I think it looks really cool!
And last but not least, I installed all the waterblocks on their components:
Started with the GPU:
Also installed the backplate:
CPU followed:
And RAM:
I'm really in love with EKWB's Plexi CSQ blocks!
I think they look totally awesome!
I have some Mayhems Pastel Blue, it's going to look pretty cool
I really want to thank AquaTuning Switzerland for the outstanding support!!
That's it for now, thanks for watching!
As I said, it's my first mod, but until now, things went quite well...
See you!
elAwesome is offline   Reply With Quote
Old 20th Feb 2013, 16:32   #2
elAwesome
Multimodder
elAwesome's Avatar
Small update:
Mounted the SSDs on the HDD rack. I wanted to mount them on top, but there weren't any screwholes, so I just took a strip of extra strong mounting tape on both sides, and it worked perfectly.
I need to re-sleeve those cables :/
Fits nice
Overall I wasn't quite happy with the result, so I took everything apart and rebuild the cage, but differently. I put the fan on the bottom on four nice little feet, then turned the cage vertical and mounted the SSDs in front:
Looks much nicer now, doesen't it?
Also placed a little Apple sticker on one of the SSDs, not just for the optics, but when I remove them I know which OS is installed on which SSD.
HDD rack in place, also test-fitted the res:
Hopefully I get to the plumbing tomorrow. I wanted to do that today, but other things took too much of my time...
See you & thanks for watching!
Old 21st Feb 2013, 17:18   #3
elAwesome
Multimodder
elAwesome's Avatar
Almost 1.5k views and not a single reply? Hm :/
Anyway, here's the next update:
I bended the copper tubes today. It was way harder than I imagined, and my father had to help me a little
But anyway, I like the result. I haven't leak-tested it yet, I hope it's fine...
Pictures:
Put it into place and took some nice photos:
LED strips arrive tomorrow together with some more sleeving material
See you!
Old 22nd Feb 2013, 15:51   #4
elAwesome
Multimodder
elAwesome's Avatar
Still not a single reply? Is it that bad?
Doing the leak test at the moment. Had a small leak at the CPU block, but just because I didn't screw in one of the fittings correctly. Works now.
I'm a little worried with the pump: It seems that the water is flowing, but the pump is unbelievably loud! There is still a lot of air in the loop, could that be the reason?
I'm adding pictures later.
Old 22nd Feb 2013, 16:37   #5
Maki role
Dale you're on a roll...
Maki role's Avatar
Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.
Well to be fair, it seems the last half of this week has been very slow in this section, both progress and comment wise. Loving the piping, I'm a real sucker for rigid tubing, just makes everything look clean and direct.
Pump noise, as you pointed out, is likely because of the air still present. It'll quieten down significantly once all the bubbles have dissipated. Desks are certainly the in thing eh? Must say I wouldn't mind doing one myself, although a full tower is impractical to move around as it is, might wait until life has settled before I do that.
__________________
Finished Builds: Azure, Vesper, Loramentum, Aetos, Exsectus (Tt UK Modding Trophy 1st Place)
Work in Progress: Cheers Luv!
Website: http://www.praetex-design.com Twitter: @Maki_Role Instagram: @Maki_Role
Maki role is offline   Reply With Quote
Old 22nd Feb 2013, 17:39   #6
jrs77
theorycrafting
jrs77's Avatar
jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.
To be fair, I haven't commented on this one yet, as I don't see where this one is going, so I just observe for the time being.
Did you use brute force to bend those pipes, or do you have a pipebending-tool at hand? The pipes look like they collapsed.
__________________
...and allways remember, that the world is an orange!
Cooltek/Jonsbo U1 | Silverstone SX500-LG | Noctua NF-R8 Redux 1200
Gigabyte H97N-WiFi | intel i7-5775C | Noctua NH-D9L | Crucial Ballistix 16GB DDR3L1600 | Crucial MX200 250GB | 2.5" WD AV 1TB
jrs77 is offline   Reply With Quote
Old 23rd Feb 2013, 22:09   #7
elAwesome
Multimodder
elAwesome's Avatar
Thanks for the comments!
I agree on the nice look of metal pipes, but I'm sure I'm notgoing to do that again. It's really difficult. I had a pipe bender, but it was very low quality, so sometimes I had to improvise with other tools to get it fitting.
I can understand that for a reader is might be pretty messy, as from the beginning on several things crashed my plans for this build. But I think I'm on a good way.
I wanted to continiue working today, but Friday night striked me and today I wasn't able to do anything...
Tomorrow I'll have some time...
Old 24th Feb 2013, 03:44   #8
KithKhan
A dremel is all you need.
KithKhan's Avatar
KithKhan has yet to learn the way of the Dremel
Beautiful choice in reservoirs!
It'd be awesome to get a complete system inside a mid-tower with that massive reservoir INSIDE too. I love compact builds with surprising components.
I know nothing about pipe bending. I figured it was like glass and you heat it with a propane torch. This is apparently not the case?
KithKhan is offline   Reply With Quote
Old 4th Mar 2013, 18:03   #9
elAwesome
Multimodder
elAwesome's Avatar
Thanks.
Well, bending metal pipes is quite different. You don't heat it, bu you've got a special tool where you put a straight piece of tube inside, then apply some force and it will bend around a curve. The tool is (obviously) called a pipe bender. Depending on its quality, the bends get good, or not.
I'm currently waiting for some LED stuff to arrive, so I can't to a lot now., I'll hav to take it apart anyway again.
Anway, here are some pictures of how I leak-tested everything:
The loop is already drained again. I'm going to use Mayhems Pastel next time
Meanwhile, I place the parts where I want to have them to check if everything works out so far. It did.
On both sides, I will have BeQuiet 140mm fans pushing air through the case.
On the left, I'll have the mobo, HDD cage and res in the middle, PSU and drive bay on the right hand side.
This is all done very roughly, when I'm gonna do the final assembly, I will hide the stuff better!
I hope to be able to deliver you more updates soon!
See you!
Old 4th Mar 2013, 18:43   #10
kinghong1970
Just a Clumsy Ape
kinghong1970's Avatar
kinghong1970 has yet to learn the way of the Dremel
you might wanna try inserting some springs prior to bending so you can keep it from collapsing..
i too see it collapsed... especially the link between cpu and ram block and ram block to...
but otherwise... nice progress!
kinghong1970 is offline   Reply With Quote
Old 4th Mar 2013, 18:47   #11
elAwesome
Multimodder
elAwesome's Avatar
Thanks for the hint! Very good idea, I'll try to remember that one..
The RAM bends are a bit flatter, but not collapsed. It might look like on the photos. I checked that, the water can flow fine through the bends.
and thanks
Old 4th Mar 2013, 20:18   #12
nagyizom
Supermodder
nagyizom's Avatar
nagyizom has yet to learn the way of the Dremelnagyizom has yet to learn the way of the Dremelnagyizom has yet to learn the way of the Dremelnagyizom has yet to learn the way of the Dremel
Ok, this is gonna be something different from the other mods but I'm waiting for the followings.
__________________
Current projects: Tydirium is on the way!
Previous mods: |Sandcrawler Mod| |Illuminated Mind| |Graphite5|
Follow me on Facebook
nagyizom is offline   Reply With Quote
Old 4th Mar 2013, 21:09   #13
Zsolt Guriga
Multimodder
Zsolt Guriga's Avatar
Zsolt Guriga is a hoopy frood who really knows where their towel is.Zsolt Guriga is a hoopy frood who really knows where their towel is.Zsolt Guriga is a hoopy frood who really knows where their towel is.Zsolt Guriga is a hoopy frood who really knows where their towel is.Zsolt Guriga is a hoopy frood who really knows where their towel is.Zsolt Guriga is a hoopy frood who really knows where their towel is.Zsolt Guriga is a hoopy frood who really knows where their towel is.Zsolt Guriga is a hoopy frood who really knows where their towel is.Zsolt Guriga is a hoopy frood who really knows where their towel is.Zsolt Guriga is a hoopy frood who really knows where their towel is.Zsolt Guriga is a hoopy frood who really knows where their towel is.
@ elAwesome
those tubes are driving me crazy,I'll be follow for sure how the works are progressing
well done
Zsolt Guriga is offline   Reply With Quote
Old 4th Mar 2013, 21:15   #14
elAwesome
Multimodder
elAwesome's Avatar
Originally Posted by Zsolt Guriga View Post
@ elAwesome
well done
Haha thanks guys, nice to hear!
Old 30th Mar 2013, 11:38   #15
elAwesome
Multimodder
elAwesome's Avatar
Hey guys,
I finally found some time over the holidays to continiue working on this. Had some trouble with the LEDs before, which had cost me a lot of time.
I'm going to post an update later on.
Just one thing I saw:
My CPU block looks somehow strange - it stayed for quite a while now almost empty. I leak-tested it with distilled water, and afterwards drained the loop again. While draining, I only got most of the water out of the loop, not all water. I left it lake that for about 3 weeks now (since the last update). Maybe this is just trapped evaporated water, but I'm worried that there is some kind of damage on the block? It didn't leak there, and I installed the block exaclte as shown in the instructions, I didn't open it or anything else.
Could you help me a little?
Here a picture:
Thanks guys!
Old 30th Mar 2013, 13:36   #16
Asouter
Asouter's Avatar
Asouter is definitely a rep cheat.Asouter is definitely a rep cheat.Asouter is definitely a rep cheat.Asouter is definitely a rep cheat.Asouter is definitely a rep cheat.Asouter is definitely a rep cheat.Asouter is definitely a rep cheat.Asouter is definitely a rep cheat.Asouter is definitely a rep cheat.Asouter is definitely a rep cheat.Asouter is definitely a rep cheat.
It could be condensation, is the loop open ? it could be algae .... it might be worth flushing your system again to see if the haze clears, The block isn't damaged, it might be dirty but not damaged.
__________________
Finished Projects : D33P THOUGHT : THING : Mini Moto Mayhem
Current Project : BITZA
Asouter is offline   Reply With Quote
Old 30th Mar 2013, 13:36   #17
Asouter
Asouter's Avatar
Ohh looking good by the way it's progressing nicely
__________________
Old 30th Mar 2013, 14:41   #18
elAwesome
Multimodder
elAwesome's Avatar
Thank you! That helped. Yeah, the loop is open at one end of the RAM block right next to it. I just got a friend to take a look at it, and we both think it's just condensation. phew...
And thanks, I admire your builds by the way! D33P THOUGHT was oustanding!
Old 30th Mar 2013, 16:08   #19
Asouter
Asouter's Avatar
Glad to be of help, ohh and thanks for the compliment.
__________________
Old 1st Apr 2013, 02:19   #20
Dragulax99
Minimodder
Dragulax99 has yet to learn the way of the Dremel
wow! first build and already bending pipes..you sure hit the ground running..nice job keep up the good work
__________________
"Has the whole world gone mad!"..
Dragulax99 is offline   Reply With Quote
Reply
Tags
build, desk, desktintosh, mod, pc
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
