Old 22nd Feb 2013, 17:54   #1
johnim40
Multimodder
johnim40 has yet to learn the way of the Dremel
260gtx not receiving work
hi guys
my 260gtx is not receiving work any more if i delete the work folder and other stuff it will work for a few the stop getting more work
im using 6.23 console
what would be best to use now client wise
i have tried other 260s as i have 4 spare and get the same when i upgraded to my 3 460s which are working fine
im using winxp sp3 on the rig
thanks john
__________________
MAIN:i5 2500k@3.3:660GTXGAME:i5 750@2.6:P7P55DPRO:2x460GTXGAME2:i5 750@2.6:P7P55D-E:460GTXF1:E5200@2.5:P5N-E SLI:260GTX
Folding stats
johnim40 is offline   Reply With Quote
Old 22nd Feb 2013, 18:40   #2
kirk46
Cheesecake Nom Nom
kirk46's Avatar
kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.
Maybe install the V7 client?
Sent from my BlackBerry 8520 using Tapatalk
__________________
2x Xeon 5620 @ 3.8GHz under water
3770k @ 4.8GHz, Custom loop, 7970 OC'd
kirk46 is online now   Reply With Quote
Old 22nd Feb 2013, 20:16   #3
Christopher N. Lew
Folding in memory of my father
Christopher N. Lew's Avatar
Christopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for president
Have you checked the assignment server is running?
__________________
Folding stats
Christopher N. Lew is offline   Reply With Quote
Old 22nd Feb 2013, 20:18   #4
johnim40
Multimodder
hi chris how do i check that
i have installed the latest f@h software and still not finding work
__________________
Folding stats
Old 23rd Feb 2013, 00:01   #5
Christopher N. Lew
Google is your friend, or you could try looking in the Stanford Folding Forum.
Go straight to the second page http://foldingforum.org/viewtopic.php?f=18&t=23759
__________________
Folding stats
Old 23rd Feb 2013, 10:05   #6
houch
Multimodder
houch's Avatar
houch - it's over 9000!!!!!!!!1!1!1!!!houch - it's over 9000!!!!!!!!1!1!1!!!houch - it's over 9000!!!!!!!!1!1!1!!!houch - it's over 9000!!!!!!!!1!1!1!!!houch - it's over 9000!!!!!!!!1!1!1!!!houch - it's over 9000!!!!!!!!1!1!1!!!houch - it's over 9000!!!!!!!!1!1!1!!!houch - it's over 9000!!!!!!!!1!1!1!!!houch - it's over 9000!!!!!!!!1!1!1!!!houch - it's over 9000!!!!!!!!1!1!1!!!houch - it's over 9000!!!!!!!!1!1!1!!!
i have the 7.2.9 and it just isnt doing anything at the moment
__________________
folding my pov gtx 275
houch is offline   Reply With Quote
Old 23rd Feb 2013, 14:42   #7
johnim40
Multimodder
thanks chris i will have to retire the 260s then and set some 650tis
__________________
Folding stats
Old 23rd Feb 2013, 20:02   #8
Christopher N. Lew
Latest - by Joe_H » Sat Feb 23, 2013 6:31 pm
As of about 8 AM PST, one of the VSP07 servers is back online, 171.67.108.21, and is accepting returns and giving out new assignments. 171.67.108.11 is no longer down, but is not yet accepting connections. I assume that means it needs more work to get it back online, but don't have any idea how long that will take.
It was just a server issue at Stanford - there is no need to change your cards!
__________________
Folding stats
Old 23rd Feb 2013, 21:09   #9
johnim40
Multimodder
thanks chris i went and got a 650ti tiny card and added to a machine then i went to swap out the 260 with the swapped 460 and found the thing was running again
never mind i wont notice the extra power used but will bump my ppd cheers for the help
__________________
Folding stats
Old 28th Feb 2013, 15:44   #10
johnim40
Multimodder
i changed the 260 for a 660 even better
__________________
Folding stats
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
