Go Back   bit-tech.net Forums > Technology > Custom PC and bit-tech Folding Team
Reply
Thread Tools
Old 23rd Feb 2013, 09:28   #1
kirk46
Cheesecake Nom Nom
kirk46's Avatar
kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.
installing the kraken on oracle vm box
Hi all im trying to install the kraken on my oracle vm box
following the guide in the [H]ard forum,
when i get to step 4: install it and type:
cd thekraken*
i get:
-bash cd: thekraken: not a directory
as im not sure where the kraken files are on my pc i think thats why its doing it?
cheers
__________________
2x Xeon 5620 @ 3.8GHz under water
3770k @ 4.8GHz, Custom loop, 7970 OC'd
kirk46 is online now   Reply With Quote
Old 23rd Feb 2013, 09:47   #2
Votick
CHMOD bit-tech 777
Votick's Avatar
Votick - may the hammer of Bindi be bestowed on youVotick - may the hammer of Bindi be bestowed on youVotick - may the hammer of Bindi be bestowed on youVotick - may the hammer of Bindi be bestowed on youVotick - may the hammer of Bindi be bestowed on youVotick - may the hammer of Bindi be bestowed on youVotick - may the hammer of Bindi be bestowed on youVotick - may the hammer of Bindi be bestowed on youVotick - may the hammer of Bindi be bestowed on youVotick - may the hammer of Bindi be bestowed on youVotick - may the hammer of Bindi be bestowed on you
link to guide?
__________________
Folding stats
| AMD FX 8350 @ 4.0GHZ | Gigabyte GA-990FXA-UD5 | 16GB Corsair Vengeance DDR3 1600mhz |
| Corsair Force 3 120GB SSD X 2 RAID0| Corsair H100 | Samsung F3 1TB HDD | MSI GeForce GTX 680 SLI |
| Silverstone 1200W | Corsair 650D | LG IPS225V X 2 |
Votick is offline   Reply With Quote
Old 23rd Feb 2013, 11:18   #3
kirk46
Cheesecake Nom Nom
kirk46's Avatar
http://hardforum.com/showthread.php?t=1601608
guide is for native ubuntu ortho ive use vm player with no issues but that was a proper install
http://www.linuxforge.net/docs/crunc...ah-install.php
guide i used to set the vm up, but i didnt burn the iso to cd
__________________
Old 23rd Feb 2013, 11:56   #4
faugusztin
I *am* the guy with two left hands
faugusztin should be considered for presidentfaugusztin should be considered for presidentfaugusztin should be considered for presidentfaugusztin should be considered for presidentfaugusztin should be considered for presidentfaugusztin should be considered for presidentfaugusztin should be considered for presidentfaugusztin should be considered for presidentfaugusztin should be considered for presidentfaugusztin should be considered for presidentfaugusztin should be considered for president
That means you didn't extract it in step 3 :
Code:
tar xvf thekraken*.*
__________________
Cerberus Core i7-2600K Asus P8Z77-I Deluxe GSkill RipjawsX 2x8GB DDR3-1600CL9 watercooled EVGA GTX670 Samsung 830 256GB Bitfenix Prodigy Seasonic X-460 Windows 8 Pro
Prometheus Xeon E3-1235 Asus P8B WS GSkill RipjawsX 2x4GB DDR3-1333CL7+2x8GB DDR3-1333CL9 Coolink Corator DS Force 3 240GB+4xWD30EFRX+2xWD20EARS+6xWD20EARX Nanoxia DS1 Seasonic X-460 Ubuntu 12.04
faugusztin is online now   Reply With Quote
Old 23rd Feb 2013, 12:38   #5
kirk46
Cheesecake Nom Nom
kirk46's Avatar
hmmm im sure i did but when i try and do it now i get:
__________________
Old 23rd Feb 2013, 13:37   #6
Votick
CHMOD bit-tech 777
Votick's Avatar
Looks like your not un taring the .gz that you downloaded. But a folder instead.
Remove any folder referencing kraken and start again.
__________________
Folding stats
Old 23rd Feb 2013, 13:58   #7
kirk46
Cheesecake Nom Nom
kirk46's Avatar
im not clued up that much in linux :/
ive no idea where the folders are and i cant find anything with thekraken on my pc
EDIT:i wonder if its because ive already un tar'd it?
__________________
Old 23rd Feb 2013, 14:04   #8
faugusztin
Code:
rm -rf thekraken*
Then download it again and extract it again. And yes, you probably already untarred it.
__________________
Old 23rd Feb 2013, 14:28   #9
kirk46
Cheesecake Nom Nom
kirk46's Avatar
Originally Posted by faugusztin View Post
Code:
rm -rf thekraken*
right that worked but now its saying sudo: command not found not found when i 'sudo make install'
__________________
Old 23rd Feb 2013, 14:36   #10
faugusztin
What Linux distribution is that ?
Ubuntu/Debian:
Code:
apt-get install sudo
Fedora/Red Hat/CentOS :
Code:
yum install sudo
Arch Linux :
Code:
pacman -S sudo
Gentoo :
Code:
emerge sudo
__________________
Old 23rd Feb 2013, 14:59   #11
kirk46
Cheesecake Nom Nom
kirk46's Avatar
its none....
its from here http://linuxforge.net/docs/crunching/fah-virtualbox.php
im using the latest Linux64_FAH-1.5.0
ive always used vm player but the old 3.0.0 version wont work with an IB cpu so ive had to come up with something else and decided to give this a go
__________________
Old 23rd Feb 2013, 15:25   #12
faugusztin
Didn't notice you run as root. Well, then just remove sudo from the command, ie run only this :
Code:
make install
__________________
Old 23rd Feb 2013, 16:04   #13
kirk46
Cheesecake Nom Nom
kirk46's Avatar
hmmm now its saying 'make' command not found
__________________
Old 23rd Feb 2013, 16:58   #14
faugusztin
Well then you have to use a different distribution. It seems the one you downloaded is a bare linux install with minimal stuff, just to run what is installed there (in that image) and nothing else.
__________________
Old 23rd Feb 2013, 17:09   #15
kirk46
Cheesecake Nom Nom
kirk46's Avatar
yeah thats what im thinking
il do a proper install i think
thanks for all your help faugusztin
__________________
Old 23rd Feb 2013, 17:35   #16
faugusztin
I would suggest you to install Ubuntu in a virtual machine, it is really not that hard (if it asks you maybe 10 simple questions) and in a virtual machine there is nothing to screw up.
__________________
Old 24th Feb 2013, 07:53   #17
kirk46
Cheesecake Nom Nom
kirk46's Avatar
it is a VM,
ive installed 12.04 LTS server
how do i get the stats on the HFM as im not sure how to do it via the console
__________________
Old 24th Feb 2013, 09:15   #18
faugusztin
Sorry, i can help you with Linux questions, but not with folding application questions.
But maybe this helps ?
http://forums.bit-tech.net/showthread.php?t=228650
By the way, if you need an easier way to walk in the filesystem and edit files, then install Midnight Commander using :
Code:
apt-get install mc
And then run it when needed using :
Code:
mc
__________________
Old 25th Feb 2013, 12:26   #19
Scorpuk
Supermodder
Scorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run CrysisScorpuk can run Crysis
Where do you run HFM?
I run HFM on one of my windows computer and have my linux box setup to have the FAH folder as the web root. Then HFM can add a v6 client and point to its IP address as a web source.
I followed this guide:
http://www.overclock.net/t/1206894/h...ux-and-windows
Click on the Linux guide and then pick quick or comprehensive.
You are then looking for the part about HFM further down, which will be another + button to reveal.
So long as you dont need your vm for an apache server then you're good to go.
I got the link from here: http://forums.bit-tech.net/showpost....03&postcount=4
Hope that helps.
__________________
Folding stats
Folding Summary
Desktop: Corsair Carbide 400R; Asus Sabertooth X79; Intel i7-3930K; Hydro H100; EVGA GTX 580 772MHz; Corsair Vengeance 16GB DDR3 1600MHz; Corsair HX850W; Samsung 256GB 840 Pro; 2TB HDD; Windows 7 Ult. 64bit.
Scorpuk is offline   Reply With Quote
Old 25th Feb 2013, 16:48   #20
kirk46
Cheesecake Nom Nom
kirk46's Avatar
ive sorted it...
just was lazy and installed the desktop version
cheers tho
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
