Go Back   bit-tech.net Forums > Technology > Custom PC and bit-tech Folding Team
Reply
Thread Tools
Old 23rd Feb 2013, 14:49   #1
vasileioszografos
Modder
vasileioszografos's Avatar
vasileioszografos has yet to learn the way of the Dremel
Folding@home and room heating (+donations??)
Hey folks,
so since as they say the Devil finds work for idle hands, I have been considering a new folding-related small project to keep me busy.
Now I dont want to keep folding on the hexacore 4.5Ghz 3GPU PC I have (showoff!! ), so I was thinking of bulding a new, inexpensive small factor pc with some okayish CPU and one or two moderate gpus where I can do folding 24/7.
In particular I would like to build something that generates quite some heat that I can perhaps use as a passive room heater.
I would like to experiment with that to see if I can build some small, cheap, (relatively quietish), heat generating units that can be stacked together to heat a room while doing folding work. Ok so electricity for heat is not ideal but knowing that you are helping science should still make you feel good .
So my question is. Do you guys have any suggestions for cases, cpus, gpus and motherboards? I stress that I want something small and inexpensive. Preferrably second hand hardware.
Which brings me to my second point. If you guys have any old hardware to donate that can be used for my folding project please let me know. They will be more than welcome.
If it goes well I might build some kind of blog about it and describe the progress.
Many thanks
Vasileios
__________________
--- Ferramentis venit et vadit. Scientia manet ---
Folding stats
vasileioszografos is offline   Reply With Quote
Old 23rd Feb 2013, 20:10   #2
Christopher N. Lew
Folding in memory of my father
Christopher N. Lew's Avatar
Christopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for president
If you want a GPU that uses lots of power but still runs Folding@home, try a GTX 480. It may be a bit noisy for you, it's like having a fan heater running.
No, I don't have one spare.
__________________
Folding stats
Christopher N. Lew is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
