Go Back   bit-tech.net Forums > Technology > Custom PC and bit-tech Folding Team
Reply
Thread Tools
Old 24th Feb 2013, 23:58   #1
vasileioszografos
Modder
vasileioszografos's Avatar
vasileioszografos has yet to learn the way of the Dremel
From a piece of crap to a....slightly less piece of crap
So, I have a GeForce 9600 GS card in my build (as well as 2 GTX560Tis) running PhysX only.
And since there are virtually no PhysX supporting games plus the fact that I dont use my CPU and main GPUs for folding I decided to use the 9600 GS for 24/7 folding.
I inherited that card from someone and it is okayish for folding. Will clock something near 1900 PPD with default settings.
So I decided to slightly overclock it. Cranked up the GPU clock to 750 and the memory clock to 529 which gave a shader of 1900 (the 560ti has a shader of 1645 btw. ok different number of shaders but just as a reference).
So now it clocks upwards of 2600 PPD (on the same project).
Not too bad for a piece of **** I wont care twice if it melts.
It keeps a reasonable 62C and the fan is quite silent.
Nice one
By the way. If you havent seen or havent heard of a 9600 GS before I dont blame you.
It is some OEM card that used to come in various vendor builds etc.
Looks like that
__________________
--- Ferramentis venit et vadit. Scientia manet ---
Folding stats
vasileioszografos is offline   Reply With Quote
Old 25th Feb 2013, 06:33   #2
mikemaher205
Multimodder
mikemaher205 has yet to learn the way of the Dremel
Every little counts.
__________________
Folding stats
mikemaher205 is offline   Reply With Quote
Old 25th Feb 2013, 09:53   #3
vasileioszografos
Modder
as a reference a quad core Xeon 3.2 can manage something like 1400 ppd
__________________
Folding stats
Old 25th Feb 2013, 11:34   #4
mikemaher205
Multimodder
1400? Do you mean 14,000? What Xeon are you talking about here, I was looking at getting a Xeon 5450 folding for extra points...
__________________
Folding stats
Old 25th Feb 2013, 17:42   #5
vasileioszografos
Modder
Depends on the project I suppose. It ranges from 10K to 1.4k ppd.
W3565
__________________
Folding stats
Old 3rd Mar 2013, 10:28   #6
vasileioszografos
Modder
And here is a tip.
If you are going to overclock a piece of hardware, especially if it is old, replace the thermal paste.
The temps of the 9600GS at full blast --->65-69 degrees
After replacing the thermal paste ---> 54 degrees
The old one had almost solidified
__________________
Folding stats
Old 3rd Mar 2013, 10:47   #7
kirk46
Cheesecake Nom Nom
kirk46's Avatar
kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.kirk46 is the Cheesecake. Relix smiles down upon them.
Originally Posted by vasileioszografos View Post
And here is a tip.
any 2nd hand gpu i buy i always apply new TIM
__________________
2x Xeon 5620 @ 3.8GHz under water
3770k @ 4.8GHz, Custom loop, GTX680 OC'd
kirk46 is online now   Reply With Quote
Old 3rd Mar 2013, 10:49   #8
vasileioszografos
Modder
Good idea.
It is a small thing, but people (including myself) always forget. And it can make such a big difference.
Which is probably the same as saying, if you keep your hardware for a few years, replace the thermal paste once in a while.
__________________
Folding stats
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
