Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 25th Feb 2013, 19:43   #41
true_gamer
Cheesecake anyone?©
true_gamer's Avatar
true_gamer is the Cheesecake. Relix smiles down upon them.true_gamer is the Cheesecake. Relix smiles down upon them.true_gamer is the Cheesecake. Relix smiles down upon them.true_gamer is the Cheesecake. Relix smiles down upon them.true_gamer is the Cheesecake. Relix smiles down upon them.true_gamer is the Cheesecake. Relix smiles down upon them.true_gamer is the Cheesecake. Relix smiles down upon them.true_gamer is the Cheesecake. Relix smiles down upon them.true_gamer is the Cheesecake. Relix smiles down upon them.true_gamer is the Cheesecake. Relix smiles down upon them.true_gamer is the Cheesecake. Relix smiles down upon them.
Originally Posted by Si_the-dude View Post
Got to love the 7970 X-fire to 580 SLI, to 670 SLI in a month! LOLOLOL. Keep it up dude, you're like my role model!
Have I really bought 7 graphic cards in less than a month? WOW! I think I have shocked myself too!...
__________________
i7 3930K @ 4.7GHz - ASUS Rampage IV Extreme - 16GB Corsair 2400MHz 10 12 12 31 - 3x EVGA GTX 670 F.T.W 4GB Tri SLI with AquagraFX waterblocks Cores: 1306MHz Memory's: 7114MHz - 128GB OCZ Vector SSD - PNY Prevail 120GB SSD - 2TB WD Black Caviar - Silverstone TJ07 - Silverstone Strider 1KW - Samsung DVD/RW - Custom Waterloop - U2713HM 2560x1440 @ 90Hz Overclocked
ORIGIN username: wipeyourarse - Steam ID: true_gamer - UPLAY ID: true_gamer
My Crysis 3 Ultra Config My Crysis 1 ultra Config
true_gamer is offline   Reply With Quote
Old 25th Feb 2013, 19:47   #42
true_gamer
Cheesecake anyone?©
true_gamer's Avatar
Originally Posted by JoshH View Post
Awesome, I run just 1 of these cards so 3 will be insane!
Good man!
Thanks.
Originally Posted by Spreadie View Post
Counting the pennies, as ever, Simon?
I salute you, sir!
you frikkin nutter
As always good Sir!
__________________
Old 25th Feb 2013, 20:52   #43
spolsh
Multimodder
spolsh's Avatar
spolsh has yet to learn the way of the Dremelspolsh has yet to learn the way of the Dremelspolsh has yet to learn the way of the Dremelspolsh has yet to learn the way of the Dremelspolsh has yet to learn the way of the Dremel
Are you going to try them on air before switching to water ? just to see what the actual difference is ?
or .. are you just gonna put it together how it'll stay for at least a week first time ?
spolsh is online now   Reply With Quote
Old 25th Feb 2013, 20:57   #44
debs3759
Was that a warranty I just broke?
debs3759's Avatar
debs3759 is almost as Godly as yodasarmpitdebs3759 is almost as Godly as yodasarmpitdebs3759 is almost as Godly as yodasarmpitdebs3759 is almost as Godly as yodasarmpitdebs3759 is almost as Godly as yodasarmpitdebs3759 is almost as Godly as yodasarmpitdebs3759 is almost as Godly as yodasarmpitdebs3759 is almost as Godly as yodasarmpitdebs3759 is almost as Godly as yodasarmpitdebs3759 is almost as Godly as yodasarmpitdebs3759 is almost as Godly as yodasarmpit
How ya doing on the bot with all this new hardware?
debs3759 is offline   Reply With Quote
Old 25th Feb 2013, 21:11   #45
true_gamer
Cheesecake anyone?©
true_gamer's Avatar
Nah, just build it all at once with the water blocks. Anyone with the same card on air can compare. I've had enough experience in watercooling to see great results with low temps.
A? You've lost me.
__________________
Old 25th Feb 2013, 21:21   #46
debs3759
debs3759's Avatar
Originally Posted by true_gamer View Post
A? You've lost me.
Don't you submit overclocking benchmarks on hwbot? With all the hardware you buy, you could be quite competitive on there
Old 25th Feb 2013, 21:28   #47
true_gamer
Cheesecake anyone?©
true_gamer's Avatar
I'm with you now. I did years ago. I will have to get back into it and post my benchmarks again.
Thanks for reminding me, I forgot all about it.
__________________
Old 25th Feb 2013, 21:33   #48
Margon
Margon Man
Margon's Avatar
Margon is the Cheesecake. Relix smiles down upon them.Margon is the Cheesecake. Relix smiles down upon them.Margon is the Cheesecake. Relix smiles down upon them.Margon is the Cheesecake. Relix smiles down upon them.Margon is the Cheesecake. Relix smiles down upon them.Margon is the Cheesecake. Relix smiles down upon them.Margon is the Cheesecake. Relix smiles down upon them.Margon is the Cheesecake. Relix smiles down upon them.Margon is the Cheesecake. Relix smiles down upon them.Margon is the Cheesecake. Relix smiles down upon them.Margon is the Cheesecake. Relix smiles down upon them.
you would have SO many points purely because of the amount of hardware you get through.
__________________
i7 920 - 12GB - 5870
Keycool 87 Modded Clears - Cougar Attack Reds - KBT Oni Browns - Ducky DK1087 Blues - Cherry G80-3700 Blacks
Margon is offline   Reply With Quote
Old 25th Feb 2013, 21:40   #49
BennieboyUK
CPC Folder of the Month Sep 2011
BennieboyUK's Avatar
BennieboyUK should be considered for presidentBennieboyUK should be considered for presidentBennieboyUK should be considered for presidentBennieboyUK should be considered for presidentBennieboyUK should be considered for presidentBennieboyUK should be considered for presidentBennieboyUK should be considered for presidentBennieboyUK should be considered for presidentBennieboyUK should be considered for presidentBennieboyUK should be considered for presidentBennieboyUK should be considered for president
Good stuff mate, I can't wait to get my 680's classy's. Shame I can only get 2 16's on my PCIe lanes or I might be tempted to get another one, but fear running 8\8\16 would bottleneck?
Thoughts?
__________________
i7 980x @ 4.4Ghz|12GB Dominator GT 2133mhz|Rampage III|4gb GTX 680 Classified's SLI|830 256GB|Antec 1200w|PF1000|R3|U2711 Hyper-V 2012: Dell 1900 | Dual Xeon E5320 | 32GB DDR2 ECC | LSI @ Raid5 5.452tb WHS: 8gb HP N40L 10tb x8 WD 2tb RED's Raid 6+1 on SRCSASBB8I with BBU
BennieboyUK is offline   Reply With Quote
Old 25th Feb 2013, 21:47   #50
dead beat
Rippin six 4 life
dead beat's Avatar
dead beat should be considered for presidentdead beat should be considered for presidentdead beat should be considered for presidentdead beat should be considered for presidentdead beat should be considered for presidentdead beat should be considered for presidentdead beat should be considered for presidentdead beat should be considered for presidentdead beat should be considered for presidentdead beat should be considered for presidentdead beat should be considered for president
Unfortunately with the 6XX series, watercooling doesn't get you anywhere near the sorts of gains it did with the 5XX series. Infact I couldn't achieve any higher overclock on my 680's when using water to that of the standard coolers.
That said, the temps are a bit lower and they're less noisy.
__________________
ASUS ROG Maximus IV Extreme-Z68 | Intel i7 2600K @ 5.1Ghz | 2x EVGA GTX680's SLI (water) | 8GB Corsair Dominator GT RAM @ 1866Mhz | Corsair AX1200 PSU | Crucial M4 256GB SSD | 2 x Samsung Spinpoint F3 HDD's | Dimastech Easy bench Dual V2.5 | Dell 3007 WFP-HC 30" monitor | Custom dual radiator waterloop
Photography gear: Nikon D800 | Nikkor 24-70mm f2.8 | Nikkor 70-200mm f2.8 VRII | Nikkor 35mm F2/D | Nikkor 50mm 1.8D | Nikkor 85mm 1.8G | Nikon TC-14E II | SB-700 Speedlight
dead beat is offline   Reply With Quote
Old 25th Feb 2013, 21:57   #51
true_gamer
Cheesecake anyone?©
true_gamer's Avatar
Thoughts?
Check this out when I compared Tri SLI GTX 580 1.5GB cards on Skt 1366 and Skt 2011http://forums.bit-tech.net/showpost....&postcount=160
A tough call really!
__________________
Old 25th Feb 2013, 22:06   #52
true_gamer
Cheesecake anyone?©
true_gamer's Avatar
I guess its down to the quality of the chip.As these cards start to throttle at 70C,
__________________
Old 25th Feb 2013, 23:44   #53
dead beat
Rippin six 4 life
dead beat's Avatar
Well the problem is that they're voltage locked, so they reach their mechanical limit way before they hit their thermal limit.
__________________
Old 26th Feb 2013, 08:25   #54
davefelcher
Multimodder
davefelcher can run Crysisdavefelcher can run Crysisdavefelcher can run Crysisdavefelcher can run Crysisdavefelcher can run Crysisdavefelcher can run Crysisdavefelcher can run Crysisdavefelcher can run Crysisdavefelcher can run Crysis
I have a mental image of a mechanical GPU :-)
davefelcher is offline   Reply With Quote
Old 26th Feb 2013, 09:50   #55
Somer_Himpson
Hypermodder
Somer_Himpson's Avatar
Somer_Himpson should be considered for presidentSomer_Himpson should be considered for presidentSomer_Himpson should be considered for presidentSomer_Himpson should be considered for presidentSomer_Himpson should be considered for presidentSomer_Himpson should be considered for presidentSomer_Himpson should be considered for presidentSomer_Himpson should be considered for presidentSomer_Himpson should be considered for presidentSomer_Himpson should be considered for presidentSomer_Himpson should be considered for president
TG is a complete animal
Sent from my Galaxy Nexus using Tapatalk 2
__________________
System:
Case: Corsair Carbide 500R C MB: MSI Z77A-G45 CPU: i5 3570K CPU Cooler: SilverStone Argon AR01: GPU:2X MSI GTX 660OC: PSU: Be Quiet! 630 Watt Pure Power L8 80 Plus Bronze Modular Memory: Geil Black Dragon 16GB (2x8GB) DDR3 1600MHz[b] SSD 2X128GB Samsung 830 & 250 GB Samsung 840: Audio Creative SoundCore 3D Mouse Mionix Saiph 3200 Keyboard SteelSeries 6GV2 Fan Controller NesteQ Fan Max
Somer_Himpson is online now   Reply With Quote
Old 26th Feb 2013, 10:08   #56
damien c
Mad FPS Gamer
damien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for presidentdamien c should be considered for president
Wow didn't see that post, but this has me thinking that maybe in April I would be better upgrading from my 2700K to a 3930K instead of buying a Corsair Obsidian 900D and new watercooling kit.
I still cannot decide as I really want to see information Ivy Bridge E, especially if the rumours are true of a 10 to 15 core monster.
__________________
Core I7 3930K, Rampage IV Extreme, 16GB Corsair Vengance 1600mhz, GTX 680 SLI, Corsair Force 3 250Gb SSD, Creative Sound Blaster X-Fi Titanium, NZXT Switch 810, XSPC RX 360mm + Alphacool 240mm All Copper, 10x Scythe Kazi Jyuni 1900rpm 5v & And It's Silent!!!!!!!!! .
Market Place Feedback
http://forums.bit-tech.net/showpost....&postcount=104
damien c is offline   Reply With Quote
Old 26th Feb 2013, 12:07   #57
true_gamer
Cheesecake anyone?©
true_gamer's Avatar
Yeah, I agree. But with 3 cards bucked tight together, the thermal limit would be easier to reach on default coolers. So this is where watercooling them will give them an advantage, and give a higher OC.
Thanks!
If your running multiple cards, then yes it's worth it, if not, then the Z77 is more than capable.
I should have got another HD7970 for Tri Fire to compare with STU@MSD, as I'm sure his board is really limiting him.
I would rather have 6 faster cores, then running 10 - 15 cores, as nothing will utilize that for a few years to come.
__________________
Old 26th Feb 2013, 12:15   #58
MrDomRocks
Co-Mumble Ruler!!
MrDomRocks's Avatar
MrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for presidentMrDomRocks should be considered for president
I take my hat off to you True Gamer, you sir have more money than sense.
How does one get employed doing your job?
__________________
i5 2500k @ 4.5ghz | P8P67 | 8gb Corsair Vengeance 1866mhz | EVGA GTX670 SC | LGIPS231 | K/B Filco Majestouch 2 | Mouse R.A.T 3 | Phones Sennheiser HD 598
MrDomRocks is online now   Reply With Quote
Old 26th Feb 2013, 12:20   #59
j_jay4
CPC refugee
j_jay4's Avatar
j_jay4 is a hoopy frood who really knows where their towel is.j_jay4 is a hoopy frood who really knows where their towel is.j_jay4 is a hoopy frood who really knows where their towel is.j_jay4 is a hoopy frood who really knows where their towel is.j_jay4 is a hoopy frood who really knows where their towel is.j_jay4 is a hoopy frood who really knows where their towel is.j_jay4 is a hoopy frood who really knows where their towel is.j_jay4 is a hoopy frood who really knows where their towel is.j_jay4 is a hoopy frood who really knows where their towel is.j_jay4 is a hoopy frood who really knows where their towel is.j_jay4 is a hoopy frood who really knows where their towel is.
I know this cause I had 3x 256GB SSD in my alienware laptop.
What happened to that laptop? How much did you get for it?
__________________
ASUS P8P67, Intel 2500K, G.Skill 8GB RipjawsX, MSI GTX 460 @ 725/1450 Mhz, Be Quiet! Dark Power Pro 750 W, Samsung 830 256GB and F1 1TB
j_jay4 is offline   Reply With Quote
Old 26th Feb 2013, 12:34   #60
true_gamer
Cheesecake anyone?©
true_gamer's Avatar
Haha, thanks!
Years of experience, and knowing the right people, to get the better paid jobs.
Sold it due to changing my job and being home everyday day and weekends off. So wanted to go back to a full Desktop so I can spend crazy amounts of money on it.
£2250 is what I got for the Alieneware M18X R2.
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
