Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 27th Feb 2013, 08:48   #1
Shirty
Good news everyone!
Shirty's Avatar
Shirty can't run CrysisShirty can't run CrysisShirty can't run CrysisShirty can't run CrysisShirty can't run CrysisShirty can't run CrysisShirty can't run CrysisShirty can't run CrysisShirty can't run CrysisShirty can't run CrysisShirty can't run Crysis
Would you buy a 680 or a 7970?
I'm in the market for a new card now, and since we aren't going to see anything life changing for some time now, I've settled on picking up a top single GPU to keep me going for the foreseeable.
Right now, the cheapest 680 on Scan is £360, whereas the vanilla 7970s start at £296. The cheapest GHz edition is still well under the price of the 680 (I wouldn't bother with a GHz edition anyway as the original can be clocked just as high). SLI/Xfire might happen in a year or so if and when it's needed.
So why the hell would I buy a new 680 right now? All the benchies I've seen across the net point to the 7970 being pretty much on a par or exceeding it performance wise. The only real benefit is power consumption.
Which have you got/would you get and why? If you can recommend a particular card as well then all the better.
I might just end up getting another 670 on a 680 PCB and overclock it to 680 speeds anyway, I loved that card so much.
__________________
2500K | Corsair H55 | HIS 7950 | 8GB XMS3 | 128GB Crucial M4 | Samsung 2TB | ASRock H77M-ITX | Corsair CX500M | White Bitfenix Prodigy | Dell U2311H | Creative T6060s | Ducky G2 Pro TKL (Reds) | Logitech G500
Why.
Shirty is offline   Reply With Quote
Old 27th Feb 2013, 09:12   #2
Cei
pew pew pew
Cei's Avatar
Cei should be considered for presidentCei should be considered for presidentCei should be considered for presidentCei should be considered for presidentCei should be considered for presidentCei should be considered for presidentCei should be considered for presidentCei should be considered for presidentCei should be considered for presidentCei should be considered for presidentCei should be considered for president
680, as in my experience AMD's drivers are terrible (Catalyst Control Centre, ugh). I also appreciate lower temps, less noise and lower power use.
__________________
i7 3770 | Asus RoG Maximus V Gene Z77 | 8GB 1600Mhz Vengeance | Crucial M4 256 & 128GB | Corsair H80 + Gentle Typhoons | Corsair AX750 | EVGA GTX 680 SC 2GB | Xonar DX | Silverstone FT03
Cei is offline   Reply With Quote
Old 27th Feb 2013, 09:15   #3
Xir
I Mod, Therefore I Own
Xir's Avatar
Xir - it's over 9000!!!!!!!!1!1!1!!!Xir - it's over 9000!!!!!!!!1!1!1!!!Xir - it's over 9000!!!!!!!!1!1!1!!!Xir - it's over 9000!!!!!!!!1!1!1!!!Xir - it's over 9000!!!!!!!!1!1!1!!!Xir - it's over 9000!!!!!!!!1!1!1!!!Xir - it's over 9000!!!!!!!!1!1!1!!!Xir - it's over 9000!!!!!!!!1!1!1!!!Xir - it's over 9000!!!!!!!!1!1!1!!!Xir - it's over 9000!!!!!!!!1!1!1!!!Xir - it's over 9000!!!!!!!!1!1!1!!!
Why'd you get rid of it?
__________________
SN25P
A64 3700+ (San Diego)
2 GB DDR400 OCZ Platinum EL 2-3-2-5 1T
X1800XT 512mb Sapphire
200GB Samsung SP2004C 24" Asus something 1920x1080
Xir is offline   Reply With Quote
Old 27th Feb 2013, 09:16   #4
theshadow2001
Ultramodder
theshadow2001's Avatar
theshadow2001 should be considered for presidenttheshadow2001 should be considered for presidenttheshadow2001 should be considered for presidenttheshadow2001 should be considered for presidenttheshadow2001 should be considered for presidenttheshadow2001 should be considered for presidenttheshadow2001 should be considered for presidenttheshadow2001 should be considered for presidenttheshadow2001 should be considered for presidenttheshadow2001 should be considered for presidenttheshadow2001 should be considered for president
There was so little between a 680 and 670 I said I would just go with a 670 (I went with overclocked evga f.t.w). Also if you look at tech reports within the second analysis, it seems the quality of a card isn't just the raw frames per second it can pump out. The intervals at which it can put those frames out is important as well.
Without having access to similar level cards from both amd and nvidia I can't see for myself how this within the second stuff compares or applies to real life unfortunately.
theshadow2001 is online now   Reply With Quote
Old 27th Feb 2013, 09:17   #5
Mankz
dat steak
Mankz's Avatar
Mankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on you
I'd probably go for a 4Gb GTX670 if I were in your shoes.
Mankz is offline   Reply With Quote
Old 27th Feb 2013, 09:18   #6
rollo
rollo should be considered for presidentrollo should be considered for presidentrollo should be considered for presidentrollo should be considered for presidentrollo should be considered for presidentrollo should be considered for presidentrollo should be considered for presidentrollo should be considered for presidentrollo should be considered for presidentrollo should be considered for presidentrollo should be considered for president
680 reasons above.
7970 stock cooler sounds like an aircraft engine if you apply the ghz clock settings to it.
If your going to watercool the 7970 becomes a better idea but its still heavy on power which only gets worse overclocking.
AMD became alot like the old nvidia 400 series brute force for performance. 480 to this day is still super quick but its hugely power hungry and ear bashing on the stock cooler. 7970 is a modern replica.
rollo is offline   Reply With Quote
Old 27th Feb 2013, 09:52   #7
Parge
Do you even mod, bro?
Parge's Avatar
Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.Parge is the Cheesecake. Relix smiles down upon them.
If you have concerns about the noise, get a aftermarket 7970, then OC it to Ghz speeds, and use the money you've saved on something else - another 8GB of XMS3 maybe?
Honestly, price performance wise AMD are doing great right now. I use a 7850 in my LAN rig and I've never had a single problem with their drivers. Rollo above is banging on about power use, but there is only 30W in it which won't make a single shred of difference to your powerbill, or anything else I can think of- oh and its nothing like the 480.
__________________
Deep Silence 1 - 2500K @4.5Ghz - Gigabyte UD7 - GTX 670 - 16GB 1866mhz Tactical Tracer - 240GB Vertex 3 - Xonar DX - U3011
Pump/MCP 355 - CPU/EK Supreme HF Nickel Plexi - GPU/EK Nickel Acetal Full Cover - Rads/2x EK 240 XTX - Fans/6x Gentle Typhoon 1850s - Controller/BigNG
Parge is online now   Reply With Quote
Old 27th Feb 2013, 10:14   #8
rollo
If you pay your own electric bill it makes a difference.
Ive seen heavy savings myself from sli 580s ( Around 750 - 800 watts from the wall) to sli 680s ( 450 - 500 watts from the wall give or take games). Sli 580s use similar power to cf 7970s for reference.
My own bill has dropped £20 a month. (got them around release last year would guess ive saved between £150-£200 on electric since then) If it continues at that rate ive saved nearly the cost of the cards to begin with after i sold my orginal 580s. free upgrades are always good.
He did mension he was considering SLI CF later.
Old 27th Feb 2013, 10:27   #9
Shirty
Good news everyone!
Shirty's Avatar
I'm more of a plug and play user, so the intricacies of the driver suite will barely be touched.
Tyres were needed urgently and I don't do payday loans
I had a 670 f.t.w. as well, a cracker.
Will that extra 2Gb frame buffer do much for me at 1080p? The general consensus seems to be that it won't.
Originally Posted by rollo View Post
680 reasons above.
I'd avoid the stock cooler, and from what I've seen some of the aftermarket coolers are substantially quieter than the stock nv coolers on the 670 and 680.
I agree, I don't game enough for marginal differences in power consumption to make a noticeable difference.
If you pay your own electric bill it makes a difference. Maybe 10 hours a week?
Ah, but the peak power draw of a stock 7970 is only around 30w higher than a 680. So even in CF the difference would be the equivalent of switching on a 60w bulb for the duration of gaming. Maybe £60-70 a year for my usage, half that in single card mode.
__________________
Why.
Old 27th Feb 2013, 10:46   #10
GeorgeK
Relapsing Filcoholic
GeorgeK's Avatar
GeorgeK is the Cheesecake. Relix smiles down upon them.GeorgeK is the Cheesecake. Relix smiles down upon them.GeorgeK is the Cheesecake. Relix smiles down upon them.GeorgeK is the Cheesecake. Relix smiles down upon them.GeorgeK is the Cheesecake. Relix smiles down upon them.GeorgeK is the Cheesecake. Relix smiles down upon them.GeorgeK is the Cheesecake. Relix smiles down upon them.GeorgeK is the Cheesecake. Relix smiles down upon them.GeorgeK is the Cheesecake. Relix smiles down upon them.GeorgeK is the Cheesecake. Relix smiles down upon them.GeorgeK is the Cheesecake. Relix smiles down upon them.
For 1920x1080 I would go with a 2GB GTX680 - that's exactly what I run and I've not found a game that really needs the 2GB of RAM (let alone more). Crysis 3 run on nvidia's "Optimum Setting" maxes out at about 1.8GB so far. A lot of people say that 670s overclock to 680 level, but a 680 overclocks further. I can't stand AMD for the drivers (Catalyst Control Center is awful imo) but nvidia's drivers just work...
/my 2p
__________________
Main Rig: i5 760 @ 4GHz | H100i | EVGA GTX680 2GB | GA-P55M-UD2 | 8GB Dominator LP 1600 | 1TB F3 | 128GB M4 | X-1050 | CM690II Adv | VP2365wb | Xonar DX | SP2500s
HTPC: i3 2125 | H61I-E35-B3 | Lian Li PC-Q11b | 4GB 1066MHz | 64GB M4 | ST50F-P w/PP05 Short Cables | HP bd240i
NAS: HP Proliant Microserver | 8Gb 1333MHz | 250Gb OS Disk | 2x2Tb Samsung F4 Raid 1 | WHS 2011
Keyboards: Black Filco TKL w/Reds| White Filco TKL w/Browns | Poker w/Clears
GeorgeK is online now   Reply With Quote
Old 27th Feb 2013, 10:46   #11
Parge
Parge's Avatar
I pay my own bill, but thanks.
Firstly 7970s idle far lower than dual 680s, so any time you aren't gaming, you are using less power than the 680s. I personally spend a lot of the time my computer is on surfing the net, or watching films, so this is a pretty useful feature.
SLI 680s do not pull 450 watts from the wall in games. Add another 75w or so and you'd be closer.
Finally, 7970s pull another 100W or so on top of that (they are costing you an extra 1p per hour of gaming)
There is about 30W in it. 1KWH = around 10p - therefore 30w = 0.03p. If he plays games at max load for 10 hours a week his maximum saving will be £1.20 a month. Kerching! By your reasoning he should get his free upgrade in 250 months (about 2032)
__________________
Old 27th Feb 2013, 10:59   #12
rollo
Guess we just have high elec bills were I live as savings have been large and comp is on 24/7 was at £80 ish a month now at £55 to £60 nothing else has changed that ive noticed at least.
Old 27th Feb 2013, 11:05   #13
Shirty
Good news everyone!
Shirty's Avatar
That's the big difference, my PC is on maybe 15 hours a week, and only used for gaming maybe 10. Hell, I'm playing Trine 2 at the minute which probably isn't too taxing either!
You know, I'm actually wondering whether a 7950 might not be a better bet at my res - the new prices are insanely low with Crysis 3 and the new Bioshock (two games I will be playing regardless), with the money saved I could buy something quite nice.
__________________
Why.
Old 27th Feb 2013, 11:12   #14
rollo
At 1080p its the price performance king the 7950 is. More so if you intend to play the 2 games it comes with as your effectively wiping £60 of the price of that card straight away.
Old 27th Feb 2013, 11:56   #15
Spreadie
No disassemble!
Spreadie's Avatar
Spreadie is definitely a rep cheat.Spreadie is definitely a rep cheat.Spreadie is definitely a rep cheat.Spreadie is definitely a rep cheat.Spreadie is definitely a rep cheat.Spreadie is definitely a rep cheat.Spreadie is definitely a rep cheat.Spreadie is definitely a rep cheat.Spreadie is definitely a rep cheat.Spreadie is definitely a rep cheat.Spreadie is definitely a rep cheat.
I think you've talked yourself into it. You don't need a 680 or 7970 at 1080p - buy a swanky 7950 boost card with free games. I'd push you towards a 670ftw but the 670 prices need to drop - they have the performance, but are losing ground on the value.
__________________
Before you judge a man, walk a mile in his shoes; after that, who cares?! He's a mile away and you've got his shoes!
2500K|Gene-Z|8GB|670|X-Fi|V1200+|3007WFP-HC|M4|F3|MK-85|G500|EK Full Ni|FC670|D5|360 GTS|240 UT60
Spreadie is online now   Reply With Quote
Old 27th Feb 2013, 12:08   #16
true_gamer
Cheesecake anyone?©
true_gamer's Avatar
true_gamer is the Cheesecake. Relix smiles down upon them.true_gamer is the Cheesecake. Relix smiles down upon them.true_gamer is the Cheesecake. Relix smiles down upon them.true_gamer is the Cheesecake. Relix smiles down upon them.true_gamer is the Cheesecake. Relix smiles down upon them.true_gamer is the Cheesecake. Relix smiles down upon them.true_gamer is the Cheesecake. Relix smiles down upon them.true_gamer is the Cheesecake. Relix smiles down upon them.true_gamer is the Cheesecake. Relix smiles down upon them.true_gamer is the Cheesecake. Relix smiles down upon them.true_gamer is the Cheesecake. Relix smiles down upon them.
Theres a reason I parted with my 2 HD7970 so quickly. More to do witb multiple cards though.
As Mankz has said - Get a GTX 670 4GB csrd. Perferrally the F.T.W+ card that I have purchased.
Games like Crysis 3, Farcry 3, Hitman etc will use more tha 2GB VRAM when msxed out at 1080p.
__________________
i7 3930K @ 4.7GHz - ASUS Rampage IV Extreme - 16GB Corsair 2400MHz 10 12 12 31 - 3x EVGA GTX 670 F.T.W 4GB Tri SLI with AquagraFX waterblocks Cores: 1306MHz Memory's: 7114MHz - 128GB OCZ Vector SSD - PNY Prevail 120GB SSD - 2TB WD Black Caviar - Silverstone TJ07 - Silverstone Strider 1KW - Samsung DVD/RW - Custom Waterloop - U2713HM 2560x1440 @ 90Hz Overclocked
ORIGIN username: wipeyourarse - Steam ID: true_gamer - UPLAY ID: true_gamer
My Crysis 3 Ultra Config My Crysis 1 ultra Config
true_gamer is online now   Reply With Quote
Old 27th Feb 2013, 12:13   #17
docodine
docodine's Avatar
docodine - it's over 9000!!!!!!!!1!1!1!!!docodine - it's over 9000!!!!!!!!1!1!1!!!docodine - it's over 9000!!!!!!!!1!1!1!!!docodine - it's over 9000!!!!!!!!1!1!1!!!docodine - it's over 9000!!!!!!!!1!1!1!!!docodine - it's over 9000!!!!!!!!1!1!1!!!docodine - it's over 9000!!!!!!!!1!1!1!!!docodine - it's over 9000!!!!!!!!1!1!1!!!docodine - it's over 9000!!!!!!!!1!1!1!!!docodine - it's over 9000!!!!!!!!1!1!1!!!docodine - it's over 9000!!!!!!!!1!1!1!!!
4gb 670 and 680 are a waste of money in general, moreso at your screen res
best thing at your res is the 7950 boost since AMD's combo games are so awesome right now
__________________
Intel i7-3820 @ 4.65GHz | GeForce GTX 480 | 4x4GB Vengeance | Asus Sabertooth X79
Silverstone TJ07 | OCZ 1000W | Samsung 830 256GB | CM QF Pro w/Browns | CM Xornet
docodine is offline   Reply With Quote
Old 27th Feb 2013, 12:16   #18
Shirty
Good news everyone!
Shirty's Avatar
Yeah if the 670s could drop down even just £25 they would be there on the value front, but two AAA games and quite a lot of change to buy some other bits seems preferable to what a 670 will ultimately give me - another 10fps when they are already plenty high enough...
__________________
Why.
Old 27th Feb 2013, 12:41   #19
Mankz
dat steak
Mankz's Avatar
I've been doing a comparison of Crysis vs. Crysis 3, and found VRAM to be by far the limiting factor. I had been using a 2Gb GTX670 (before it fried itself).. If I were getting a new GPU to last a year or two, I'd definately stump up the extra for added RAM these days.
**waits for ARES II to come back into the office...**
Old 27th Feb 2013, 12:47   #20
Kovoet
Do I or Don't I
Kovoet's Avatar
Kovoet is the Cheesecake. Relix smiles down upon them.Kovoet is the Cheesecake. Relix smiles down upon them.Kovoet is the Cheesecake. Relix smiles down upon them.Kovoet is the Cheesecake. Relix smiles down upon them.Kovoet is the Cheesecake. Relix smiles down upon them.Kovoet is the Cheesecake. Relix smiles down upon them.Kovoet is the Cheesecake. Relix smiles down upon them.Kovoet is the Cheesecake. Relix smiles down upon them.Kovoet is the Cheesecake. Relix smiles down upon them.Kovoet is the Cheesecake. Relix smiles down upon them.Kovoet is the Cheesecake. Relix smiles down upon them.
I have the direct cuii 7970 and the 680 -version arrived today will come back to you.
__________________
[Coolermaster Cosmos II] [i7 i2700K] [Hydro H100i] [ASUS GTX680 DirectCUii Top] [16GB Corsair Vengeance 1600mhz] [Asus Sabertooth Z77] [Corsair AX850] [1 x 300gb VelociRaptor] [1 x 1TB samsung F3] [Dell U2312H & U2311HM] [Corsair K90] [Belkin (razer) N52te] [ASUS ROG Vulcan] [120GB Corsair pro SSD] [ Mushkin 120GB deluxe SSD Sata 3 ][Logitech G9x] [ASUS Xonar DX soundcard]
Asus Nexus Tablet
Kovoet is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
