Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 27th Feb 2013, 11:09   #1
Combatus
Bit-tech Modding + hardware reviews
Moderator
Combatus's Avatar
Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.Combatus is definitely a rep cheat.
Thermaltake Chaser A31 Review
We check out Thermaltakes new sub 100 case
http://www.bit-tech.net/hardware/cas...r-a31-review/1
__________________
My Mods Project: SFX | How to photograph your project | Join the Case Mod Index and WIN PRIZES!
Originally Posted by Mattmc91 View Post
Is the res loud, like, constantly making you need a piss loud?
Combatus is offline   Reply With Quote
Old 27th Feb 2013, 17:51   #2
SuicideNeil
Banned
SuicideNeil is definitely a rep cheat.SuicideNeil is definitely a rep cheat.SuicideNeil is definitely a rep cheat.SuicideNeil is definitely a rep cheat.SuicideNeil is definitely a rep cheat.SuicideNeil is definitely a rep cheat.SuicideNeil is definitely a rep cheat.SuicideNeil is definitely a rep cheat.SuicideNeil is definitely a rep cheat.SuicideNeil is definitely a rep cheat.SuicideNeil is definitely a rep cheat.
Assuming one has a motherboard with 3 or 4 fan headers ( like mine has ), and one uses fans with 3 pins at least, then there is no need for a fan controller- just use the software that comes bundled with most motherboards these days ( or download some ) to set fan profiles. Behold, the front / top of your case doesn't need to be cluttered with extra knobs & switches and looks a lot cleaner as a result...
SuicideNeil is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
