Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 28th Feb 2013, 17:22   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
Leap Motion gesture control system to launch in May
Final funding push means a retail release.
http://www.bit-tech.net/news/hardwar.../leap-motion/1
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is offline   Reply With Quote
Old 28th Feb 2013, 17:58   #2
Sheiken
Wat?
Sheiken's Avatar
Sheiken is almost as Godly as yodasarmpitSheiken is almost as Godly as yodasarmpitSheiken is almost as Godly as yodasarmpitSheiken is almost as Godly as yodasarmpitSheiken is almost as Godly as yodasarmpitSheiken is almost as Godly as yodasarmpitSheiken is almost as Godly as yodasarmpitSheiken is almost as Godly as yodasarmpitSheiken is almost as Godly as yodasarmpitSheiken is almost as Godly as yodasarmpitSheiken is almost as Godly as yodasarmpit
I need this in my life
__________________
Whoring Out My Hardware 4.6!
Portaputer - rMBP Late 2013 - 13" / i5 / 8GB / 256gb ssd
Sheiken is offline   Reply With Quote
Old 28th Feb 2013, 18:21   #3
[PUNK] crompers
Dremedial
[PUNK] crompers's Avatar
[PUNK] crompers is the Cheesecake. Relix smiles down upon them.[PUNK] crompers is the Cheesecake. Relix smiles down upon them.[PUNK] crompers is the Cheesecake. Relix smiles down upon them.[PUNK] crompers is the Cheesecake. Relix smiles down upon them.[PUNK] crompers is the Cheesecake. Relix smiles down upon them.[PUNK] crompers is the Cheesecake. Relix smiles down upon them.[PUNK] crompers is the Cheesecake. Relix smiles down upon them.[PUNK] crompers is the Cheesecake. Relix smiles down upon them.[PUNK] crompers is the Cheesecake. Relix smiles down upon them.[PUNK] crompers is the Cheesecake. Relix smiles down upon them.[PUNK] crompers is the Cheesecake. Relix smiles down upon them.
Sounds great until you forget its on, start doing some yoga and realise you have pulled every vertices in your 50+ hour scale model of a deathstar over to the left of the screen
__________________
| Main Rig | FT02 BW | 2600k @ 4.3Ghz | Sabertooth Z77 | 16GB Corsair Vengance | GTX 1070 @ 2020Mhz | OCZ ARC100 480GB |1TB Samsung F3 | Corsair HX650W | U2711 | Filco Majestouch 2 Tenkeyless | Xonar Essence STX | ProSonus Eris 4.5 monitors |
| HTPC | Lian Li Q11-B | AMD A10 5800k | ASRock FM2A75M-ITX | 8GB XMS3 2000 | 1TB Seagate | SFX 350W |
[PUNK] crompers is offline   Reply With Quote
Old 28th Feb 2013, 20:02   #4
GravitySmacked
Mostly Harmless
GravitySmacked's Avatar
GravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming Saiyan
This is the first I've heard of the device but after watching that video all I can say is WANT!
GravitySmacked is offline   Reply With Quote
Old 1st Mar 2013, 08:52   #5
hampurista
What's a Dremel?
hampurista has yet to learn the way of the Dremel
Ordered! Don't mind the extra 20$ compared to order before yesterday....
hampurista is offline   Reply With Quote
Old 1st Mar 2013, 09:27   #6
Blackshark
Multimodder
Blackshark has yet to learn the way of the Dremel
Ordered last year when it was first announced - looking forward to using it at work for manipulating our spatial data
Blackshark is offline   Reply With Quote
Old 1st Mar 2013, 10:01   #7
Krikkit
Super Moderator
Moderator
Krikkit's Avatar
Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.
Originally Posted by [PUNK
crompers]Sounds great until you forget its on, start doing some yoga and realise you have pulled every vertices in your 50+ hour scale model of a deathstar over to the left of the screen
I think it only works in a small(ish) area above the device - take your hands away to type/stretch etc and it'll move out of range.
I remember seeing this ages ago and thinking "this must be bullshit", but I'm glad to be wrong!
__________________
The Good, The Bad, The Ugly, The Zlad!, The Wut?!, The Kempness
Krikkit is offline   Reply With Quote
Old 1st Mar 2013, 11:21   #8
EvilRusk
Multimodder
EvilRusk has yet to learn the way of the Dremel
I think this looks like a great idea. After using my android phone I realised how badly the PC needed a better interface for some things.
Since I don't want to buy a touch screen this could be it - no smudgy finger prints all over the place! Browse the web while eating crisps! Use your forehead to draw in paint! Awesome!
EvilRusk is offline   Reply With Quote
Old 1st Mar 2013, 13:43   #9
dyzophoria
Supermodder
dyzophoria has yet to learn the way of the Dremel
for interactions like holding a 3D object, manipulating maybe the start screen of windows 8, this may be efficient, but for actual drawings, aside from a tablet, I think its much practical to use a touch screen imo
__________________
[FONT=Lucida Console]picture this..[/FONT] // [FONT=Tahoma][FONT=Fixedsys]picture that..[/FONT][/FONT]
dyzophoria is offline   Reply With Quote
Old 1st Mar 2013, 17:13   #10
Jimbob
Multimodder
Jimbob is the Cheesecake. Relix smiles down upon them.Jimbob is the Cheesecake. Relix smiles down upon them.Jimbob is the Cheesecake. Relix smiles down upon them.Jimbob is the Cheesecake. Relix smiles down upon them.Jimbob is the Cheesecake. Relix smiles down upon them.Jimbob is the Cheesecake. Relix smiles down upon them.Jimbob is the Cheesecake. Relix smiles down upon them.Jimbob is the Cheesecake. Relix smiles down upon them.Jimbob is the Cheesecake. Relix smiles down upon them.Jimbob is the Cheesecake. Relix smiles down upon them.Jimbob is the Cheesecake. Relix smiles down upon them.
It's certainly neat, but is it really that usefull for desktop use? Perhaps if it uses standard touch screen api's so Windows Touch Pack works etc but I really want to test it oput first.
Jimbob is offline   Reply With Quote
Old 1st Mar 2013, 18:01   #11
Guinevere
Mega Mom
Guinevere's Avatar
Guinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming SaiyanGuinevere is a Super Spamming Saiyan
Give me two minutes and I can think of a few dozen different gestures that 'could' be implemented to embellish a keyboard / mouse or keyboard / trackpad or keyboard / mouse / touchscreen environment.
Leap haven't ever come out and said 'this device will replace X". They're throwing it out there to see what people do with it.
Brilliant idea!
Guinevere is offline   Reply With Quote
Old 1st Mar 2013, 20:14   #12
Nexxo
Whatever's Geek.
Nexxo's Avatar
Nexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming Saiyan
__________________
In memory of Kidmod-Southpaw (1997 - 2014), Teelzebub (1955 - 2016) and Waynio (1978 - 2016)
"We are the music makers; we are the dreamers of dreams"
Current project: Metaversa 02 Ada.
Nexxo is offline   Reply With Quote
Reply
Tags
gesture control, leap motion, leap motion controller, motion control, motion sensing
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
