Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 1st Mar 2013, 15:11   #1
tsutton
Supermodder
tsutton has yet to learn the way of the Dremel
Samsung 840 256GB SSD - Low Read/Write rate?
Hi all,
Just got my new Samsung 840 256GB SSD this morning. I have upgraded the firmware to the latest version which is DXT07B0Q
I have run the Performance Benchmark via the Samsung Magician software (v4.0) and here is the result:
This is based on the "Maximum Performance" for the OS Optimization setting. I am getting similar result if I change the OS Optimization setting to "Maximum Reliability" and also "Maximium Capacity"
I can confirm that AHCI Mode is enabled and also is connected via SATA 6Gb/s (SATS3 connection)
This is from Windows 7 64 bit (SP1), running on these hardware:
ASUS P8Z77-M Pro
Intel Core i5 3570k
16GB Corsair DDR3
Does anyone know why I am getting lower performance? Am I missing something else?
Thanks.
__________________
- Tony Sutton
- Check out my Ford Focus ST170 site | My Car's Dashcam Videos
tsutton is offline   Reply With Quote
Old 1st Mar 2013, 15:27   #2
suragh
Derp
suragh's Avatar
suragh is definitely a rep cheat.suragh is definitely a rep cheat.suragh is definitely a rep cheat.suragh is definitely a rep cheat.suragh is definitely a rep cheat.suragh is definitely a rep cheat.suragh is definitely a rep cheat.suragh is definitely a rep cheat.suragh is definitely a rep cheat.suragh is definitely a rep cheat.suragh is definitely a rep cheat.
The performance seems reasonably good from my eyes. I don't like using the magician software personally. I would use cinebench or atto.
__________________
i5 4670K - MSI 7970 Lightning - ASUS Maximus VI Gene - Fractal Design R4 - Dell U2412 x 2 - Samsung 840 256GB - 16GB RAM - Xonar DGX w/ T40s - EVGA 850W
Steam: Louis - Origin: Grexthor
suragh is offline   Reply With Quote
Old 1st Mar 2013, 15:39   #3
tsutton
Supermodder
Hmm ok. It's just that it states that it will do 96,000 IOPS for read and 62,000 IOPS for write according to the specs. I'm just wondering why I'm getting lower readings from it...
Will check out cinebench & atto and see what it says.
Thanks.
__________________
- Tony Sutton
Old 1st Mar 2013, 18:47   #4
tsutton
Supermodder
I noticed that the chipset drivers was old version, so I upgraded it to the latest version. Here's the latest stats. A bit of improvement but still not meeting the goals of the SSD specs?
Or am I being too picky?
__________________
- Tony Sutton
Old 1st Mar 2013, 19:12   #5
narwen
narwen
narwen is almost as Godly as yodasarmpitnarwen is almost as Godly as yodasarmpitnarwen is almost as Godly as yodasarmpitnarwen is almost as Godly as yodasarmpitnarwen is almost as Godly as yodasarmpitnarwen is almost as Godly as yodasarmpitnarwen is almost as Godly as yodasarmpitnarwen is almost as Godly as yodasarmpitnarwen is almost as Godly as yodasarmpitnarwen is almost as Godly as yodasarmpitnarwen is almost as Godly as yodasarmpit
if its your boot drive then windows and over programs will be writing and reading from the drive.
to get max iops you would have to test the drive has a secondary will out anything using the drive ie antivirus.
__________________
CPU 2600K | MB ASUS P67PRO | MEM 16MB | GC 570 | WIN 7
narwen is offline   Reply With Quote
Old 1st Mar 2013, 21:17   #6
tsutton
Supermodder
That would make sense... yes it is indeed the boot drive. So I guess I have nothing to worry about as long as it's "near" the specs that it's meant to do.
Thanks!
__________________
- Tony Sutton
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
