Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 4th Mar 2013, 09:34   #1
Meanmotion
bleh
Meanmotion's Avatar
Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.
ZyXEL PLA4231 Powerline Wireless Extender Review
The Zyxel PLA4231 combines a wireless access point and 2-port powerline adaptor in one tidy package.
http://www.bit-tech.net/hardware/net...ender-review/1
Meanmotion is offline   Reply With Quote
Old 4th Mar 2013, 09:45   #2
Krikkit
Super Moderator
Moderator
Krikkit's Avatar
Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.
Looks like a solid bit of kit, surprised they haven't been more popular before now really.
Editorial note: First graph needs the kit highlighting in red.
__________________
The Good, The Bad, The Ugly, The Zlad!, The Wut?!, The Kempness
Krikkit is offline   Reply With Quote
Old 4th Mar 2013, 09:55   #3
Meanmotion
bleh
Meanmotion's Avatar
Ta, fixed.
Old 4th Mar 2013, 14:25   #4
Blademrk
Why so serious?
Blademrk's Avatar
Blademrk - it's over 9000!!!!!!!!1!1!1!!!Blademrk - it's over 9000!!!!!!!!1!1!1!!!Blademrk - it's over 9000!!!!!!!!1!1!1!!!Blademrk - it's over 9000!!!!!!!!1!1!1!!!Blademrk - it's over 9000!!!!!!!!1!1!1!!!Blademrk - it's over 9000!!!!!!!!1!1!1!!!Blademrk - it's over 9000!!!!!!!!1!1!1!!!Blademrk - it's over 9000!!!!!!!!1!1!1!!!Blademrk - it's over 9000!!!!!!!!1!1!1!!!Blademrk - it's over 9000!!!!!!!!1!1!1!!!Blademrk - it's over 9000!!!!!!!!1!1!1!!!
I've got a Zyxel wireless router from my ISP. I'd agree that the wireless drop-off is pretty drastic - I get a pretty strong signal in the room the router is based in but I'm lucky if I can even pick up a signal in the next room.
I'd swap it for something else but my ISP pre-configures it's routers and doesn't supply the settings.
I ended up, using a 2nd wireless router (Linksys) I had hanging round and configuring it as an access point to get around the weak wireless signal.
__________________
刃mrk
My X-Box Live gamertag, PSN, Steam & Nintendo ID is BladeMrk
Blademrk is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
