Reply
Thread Tools View Mode
Old 7th Mar 2013, 23:34   #1
longyny
Multimodder
longyny has yet to learn the way of the Dremel
Infinity MOD - FINISHED
Hello everybody!
This is my first project here at bit-tech, and hope you enjoy seeing the pics of the progress as much as I did creating it.
As mentioned in the title, this will be a scratch build. The choosen materials are stainless steal for the body of the case and methacrylate for both side panels.
The external body is 3mm thick, with unibody finishing. The inside of the case will be totally modular, made also of stainless steal, but 2mm thick. I have spended near 120kg of stainless steal to create the case, so you could imagine how big is.
There will be two GIANT side panels of ¡¡¡1cm thick!!! methacrylate. Used an entire panel of 2m x 1m to cut both side panels.
HARDWARE
Motherboard: Asus Z9PE-D16
CPUs: 2x Intel Xeon E5-2687W
Memory: 64Gb DDR3 1.600MHz ECC
Graphics Cards: 3-Way SLI GTX 580 EVGA SC 1,5Gb
Sound Card: Auzentech X-Fi Home Theater HD
Infiniband Card: Mellanox ConnectX-3 dual port 40Gbps
Raid Card: 2x SAS2 HBA ATTO ExpressSAS H6F0 GT
Hard drives 32 HDDs Seagate 3Tb 7.200 rpm
SSD: Vertex 4 128Gb
Power Supply: 2x Silverstone Strider GOLD 1.200W
WATERCOOLING
CPUs Waterblock: 2x Koolance CPU-380i
Graphics Cards Waterblocks: 3x Alphacool NexXxos GTX 580 + Backplate
RAM Waterblocks: 16x Koolance RAM-33
HDDs Waterblocks: 7x Aquacomputer Aquadrive X4
Reservoirs: 2x Phobya balancer 250mm + 3x Phobya double bay 5.25"
Pumps: 6x Swiftech MCP655 / Laing D5
Pump's TOPS: 3x Bitspower Dual Laing D5 Top UV Purple
Modding kits for Pumps: 6x Bitspower Laing D5 ModKit Silver Shine
Radiators: 1x MO-RA Pro 9x120 + 3x Aquacomputer AirPlex Extreme 360
Fans: 27x 120mm Alphacool 2.000 rpms + 5x 200mm
Fan controler: Lamptron FC-9
Tubbing: Masterkleer White 19/13
That's all for now!
longyny is offline   Reply With Quote
Old 7th Mar 2013, 23:47   #2
longyny
Multimodder
Let's continue!
I made some drafts with sketchup prior to get working with steal. I'm not an expert with sketchup, but you can get an idea of how it will be.
And of course, some "work in progress" pics:
Seriously, you can't imagine how stunning are the side panels in real life. Sorry for the bad quality photos.
Old 8th Mar 2013, 00:01   #3
longyny
Multimodder
Some pics of the main hardware:
3-Way SLI GTX 580 EVGA SC:
Motherboard, CPUs & Ram:
The motherboard is simply giant, I never had one as big as this one.
Old 8th Mar 2013, 00:11   #4
longyny
Multimodder
Time for Pumps now!
That's the default look of our appreciated Laing D5 Pump:
That's the new look after some surgery:
Not bad at all, but it's still not perfect, let's give them a bit of led light and let's see...
Much more better now! But if we do some sleeving... MDPC of course!
That's it!
Old 8th Mar 2013, 00:12   #5
Maki role
Dale you're on a roll...
Maki role's Avatar
Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.
The board itself may not be a looker, but bloody hell it's got me going. Aside from the dual xeon purdyness... that's a lot of HDDs. I mean that's an awful lot of HDDs. This build is just mahoosive on every front it seems, definitely subbed to see where this is going to head.
__________________
Finished Builds: Azure, Vesper, Loramentum, Aetos, Exsectus (Tt UK Modding Trophy 1st Place)
Work in Progress: Cheers Luv!
Website: http://www.praetex-design.com Twitter: @Maki_Role Instagram: @Maki_Role
Maki role is offline   Reply With Quote
Old 8th Mar 2013, 00:16   #6
longyny
Multimodder
I hope it will be finished in a few weeks, maybe 2 or 3 weeks.
Old 8th Mar 2013, 00:45   #7
longyny
Multimodder
So.. It could not be other way, it's time for sleeving!!
These are the colour scheme I have choosen:
Here are some fans sleeved, the 200mm ones:
And now, what really matters, a totally custom length cables for my dual Silverstone Strider PowerSupplies. Near 150 meters of cable used for this, and obviously sleeved.
Tomorrow some more sleeving pics
Old 8th Mar 2013, 00:54   #8
longyny
Multimodder
Some watercooling stuff:
I think it's enough for today.
Old 8th Mar 2013, 01:06   #9
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming Saiyan
Awesome.
Do you have to tip the rig against a wall when you remove a side panel? Or do you have something to hold it up?
__________________
The Iron Turnip·BlooBalls·Hypnotoad·Plank·Reservoir-Things·NUC-Tooobular·C7Waterblocks·Crusty McBeanbags III·GlassGreen
Powered by: AMD·Gigabyte·Swiftech·Hardware Labs·Noctua·DangerDen
Cheapskate is offline   Reply With Quote
Old 8th Mar 2013, 01:13   #10
longyny
Multimodder
Originally Posted by Cheapskate View Post
Awesome.
The case has its own base, I forgot to upload pics of this part. Here you have a sample:
Old 8th Mar 2013, 01:30   #11
longyny
Multimodder
Last one for today (that's the right one)
Koolance Ram waterblocks installed (recieved today)
I have a lot of drill work for this weekend, so keep tunned!
Old 8th Mar 2013, 02:37   #12
that_du^de
give your head a wobble
that_du^de's Avatar
that_du^de is almost as Godly as yodasarmpitthat_du^de is almost as Godly as yodasarmpitthat_du^de is almost as Godly as yodasarmpitthat_du^de is almost as Godly as yodasarmpitthat_du^de is almost as Godly as yodasarmpitthat_du^de is almost as Godly as yodasarmpitthat_du^de is almost as Godly as yodasarmpitthat_du^de is almost as Godly as yodasarmpitthat_du^de is almost as Godly as yodasarmpitthat_du^de is almost as Godly as yodasarmpitthat_du^de is almost as Godly as yodasarmpit
this is bonkers ive never seen a dual cpu mobo with 4 sets of water cooled ram. how did you form the 4 radius edges on the case?
subbed!
__________________
mozart tx case(11x120mm fans),intel i7 920@4ghz(20x200)1.28v,asus rampage extreme 2,6gig corsair ram(3x2gig),2xati hd5870 crossfire,titan fenrir hsf,enermax revolution 1250w psu,1x120gig ssd 4x1tb hdd,x-fi elite pro soundcard,dell 2405fpw 24"lcd,zboard merc k/board,cyborg rat 7 mouse,win7 64bit
that_du^de is offline   Reply With Quote
Old 8th Mar 2013, 08:07   #13
dream1
Multimodder
dream1's Avatar
dream1 has yet to learn the way of the Dremel
Not bad but for what u r using this setup ??
dream1 is offline   Reply With Quote
Old 8th Mar 2013, 09:48   #14
Pranja
Blackwolf
Pranja's Avatar
Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.
This is total overkill-I love it.
Pranja is offline   Reply With Quote
Old 8th Mar 2013, 10:49   #15
longyny
Multimodder
subbed!
I did them with an industrial grade machinery for curving metal.
I've never seen such configuration anywhere, neither. In fact, Asus told me there was only a few people in Europe that has this mobo.
It's my main Media Server, but it will be also my foldinator, and eventually for gaming, but this is not my main gaming rig.
Thanks buddy!!
Old 8th Mar 2013, 12:44   #16
dream1
Multimodder
dream1's Avatar
Looks great
Old 8th Mar 2013, 21:23   #17
longyny
Multimodder
Hi all!
Some more photos I've made today. I was all day testing the machine to ensure all are working properly.
Maybe tomorrow I will post more photos of the case while working on it.
Old 16th Mar 2013, 16:31   #18
longyny
Multimodder
I finally found a bit of time to work on the case.
Here it is in the middle of my livingroom, I'm "modding" the whole home also xD
A closer look of the case, with all the necessary holes done:
With bulkheads:
Testing with pumps:
Absolutely perfect!
It only remains some cuts to be done, and a bit of polishing. I hope it could be done next week to start mounting everything in the case.
Old 16th Mar 2013, 18:00   #19
Phame
COOOOFFFFEEEEE
Phame's Avatar
Phame is almost as Godly as yodasarmpitPhame is almost as Godly as yodasarmpitPhame is almost as Godly as yodasarmpitPhame is almost as Godly as yodasarmpitPhame is almost as Godly as yodasarmpitPhame is almost as Godly as yodasarmpitPhame is almost as Godly as yodasarmpitPhame is almost as Godly as yodasarmpitPhame is almost as Godly as yodasarmpitPhame is almost as Godly as yodasarmpitPhame is almost as Godly as yodasarmpit
Insane!
So much sweet gear going on..
Keep up the good work dude!
Phame is offline   Reply With Quote
Old 16th Mar 2013, 20:30   #20
tekonivel
Multimodder
tekonivel - it's over 9000!!!!!!!!1!1!1!!!tekonivel - it's over 9000!!!!!!!!1!1!1!!!tekonivel - it's over 9000!!!!!!!!1!1!1!!!tekonivel - it's over 9000!!!!!!!!1!1!1!!!tekonivel - it's over 9000!!!!!!!!1!1!1!!!tekonivel - it's over 9000!!!!!!!!1!1!1!!!tekonivel - it's over 9000!!!!!!!!1!1!1!!!tekonivel - it's over 9000!!!!!!!!1!1!1!!!tekonivel - it's over 9000!!!!!!!!1!1!1!!!tekonivel - it's over 9000!!!!!!!!1!1!1!!!tekonivel - it's over 9000!!!!!!!!1!1!1!!!
Awesome! True modding. Do it because you can! Love it
__________________
Completed : Bulky
tekonivel is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
