Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 12th Mar 2013, 12:16   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
AMD Radeon HD 7790 details leak
First desktop GCN 2.0 part launching in April.
http://www.bit-tech.net/news/hardwar...-radeon-7790/1
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is online now   Reply With Quote
Old 12th Mar 2013, 13:36   #2
V3ctor
Tech addict...
V3ctor's Avatar
V3ctor has yet to learn the way of the Dremel
Meh... too many gpu's in that price tag... Where are the new generations??
__________________
Main: Intel Core i7 4770K@4.5Ghz / ASUS Sabertooth Z87 / 2x4Gb Gskill Trident X 2400Mhz / MSI GTX 750Ti 2Gb GDDR5 / Samsung T260 / 2x Corsair Force GT 240Gb raid0/ Corsair HX-850W/ Silverstone FT02R-Wi
Laptop: Intel Core i7 4790K 4-4.4Ghz / 8Gb DDR3 1600Mhz / nVidia GTX 980M 8Gb GDDR5 / Samsung SSD 256Gb XP941
Hobby: AMD Opteron 175 / ASUS A8N-SLi SE / 3Gb DDR400 / ATI HD4850 512Mb GDDR3 / Crucial M550 128Gb M2
V3ctor is offline   Reply With Quote
Old 12th Mar 2013, 14:04   #3
true_gamer
Cheesecake on sale!
true_gamer's Avatar
true_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyan
Looking like the Batmobile again...
__________________
i5 4670K @ 4GHz - Corsair H100i - MSI Z87-G45 Gaming Mobo - 16GB Hyper X DDR3 2400MHz - SandDisk Ultra 2 120GB SSD - 500GB SSHD - 2x Asus R9 280X DCU2 - Coolermaster 1KW PSU - NZXT Phantom 530 Case - Philips 40" 4K Monitor BDM4065UC
ORIGIN username: wipeyourarse - Steam ID: true_gamer - UPLAY ID: true_gamer
Crysis 3 Ultra Config Crysis 1 ultra Config
true_gamer is offline   Reply With Quote
Old 12th Mar 2013, 14:05   #4
rollo
I Mod, Therefore I Own
rollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyan
Is not any new ones due to be released for 2013
rollo is offline   Reply With Quote
Old 12th Mar 2013, 15:29   #5
debs3759
Was that a warranty I just broke?
debs3759's Avatar
debs3759 is a Super Spamming Saiyandebs3759 is a Super Spamming Saiyandebs3759 is a Super Spamming Saiyandebs3759 is a Super Spamming Saiyandebs3759 is a Super Spamming Saiyandebs3759 is a Super Spamming Saiyandebs3759 is a Super Spamming Saiyandebs3759 is a Super Spamming Saiyandebs3759 is a Super Spamming Saiyandebs3759 is a Super Spamming Saiyandebs3759 is a Super Spamming Saiyan
If it's the first desktop card built using GCN 2.0 technology, surely that makes it a next generation card?
__________________
HeatWare
debs3759 is offline   Reply With Quote
Old 12th Mar 2013, 15:50   #6
alwayssts
Minimodder
alwayssts has yet to learn the way of the Dremel
Even if the 2.0 is a marketing gimmick, I was going to say that as well. It likely is the new gen. By any realistic measure, this *should* be priced between 7770 and 650ti as well. That's a decent size gap...between ~100-150 USD.
Not only is this likely a new generation part, it also is the one worth noting. I say that because a 896sp part, if it exists, will simply be a 7850 2GB replacement (or very very close to it). If you question that, simply do the math.
You could compare known stock frequencies/bw versus what is likely for such a part (1075-1100mhz and 128-bit/~7gbps or 192-bit/~5gbps) and come to a similar conclusion, but look at catalysts' overclocking maximums. They are a clear hint of where amd wants products to be segmented.
7850 is a max of 1050mhz. (1024/896)*1050 = 1200mhz. IOW, an 896sp part will be tuned to hit around 1200mhz overclocked...like any other 28nm part not limited by low voltage and/or artificial tdp restraints (like 7850 2GB).
alwayssts is offline   Reply With Quote
Old 12th Mar 2013, 17:05   #7
DBA
I do my modding with a spoon
DBA's Avatar
DBA has yet to learn the way of the Dremel
They should have made the PCB smaller to fit mITX boards. That would have made it perfect for such applications and have appealed to a much broader market.
DBA is offline   Reply With Quote
Old 12th Mar 2013, 17:51   #8
Farting Bob
Supermodder
Farting Bob's Avatar
Farting Bob has yet to learn the way of the DremelFarting Bob has yet to learn the way of the DremelFarting Bob has yet to learn the way of the Dremel
Agreed, NV has made an effort to slim down the size of their reference boards, this still looks pretty long. I dont mind my 7850's size right now, but if i were to put it in a mITX case (which ive considered) id still rather having something an inch or 2 shorter.
Farting Bob is offline   Reply With Quote
Old 12th Mar 2013, 21:21   #9
Gareth Halfacree
WIIGII!
bit-tech Staff
Just to clarify: that's a picture of a 7770 for reference; nobody's got a picture of the 7790 yet. (Chances of a shorter PCB, however, are slim to none.)
__________________
Reply
Tags
amd, bonnaire, bonnaire xt, gcn, gcn 2.0, graphics card, graphics core next, radeon, radeon hd, radeon hd 7790
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
