Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 13th Mar 2013, 11:31   #1
Meanmotion
bleh
Meanmotion's Avatar
Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.
Dropbox 2.0 update adds one-stop menu
A new Dropbox client update adds in a host more sharing and uploading features to its context menus.
http://www.bit-tech.net/news/bits/20...ne-stop-menu/1
Meanmotion is offline   Reply With Quote
Old 13th Mar 2013, 11:53   #2
Platinum
Multimodder
Platinum has yet to learn the way of the Dremel
Can I sync folders that are not in my dropbox install folder yet?
Platinum is offline   Reply With Quote
Old 13th Mar 2013, 15:02   #3
[-Stash-]
Multimodder
[-Stash-] has yet to learn the way of the Dremel
No.
[-Stash-] is offline   Reply With Quote
Old 13th Mar 2013, 16:26   #4
XXAOSICXX
Hypermodder
XXAOSICXX is almost as Godly as yodasarmpitXXAOSICXX is almost as Godly as yodasarmpitXXAOSICXX is almost as Godly as yodasarmpitXXAOSICXX is almost as Godly as yodasarmpitXXAOSICXX is almost as Godly as yodasarmpitXXAOSICXX is almost as Godly as yodasarmpitXXAOSICXX is almost as Godly as yodasarmpitXXAOSICXX is almost as Godly as yodasarmpitXXAOSICXX is almost as Godly as yodasarmpitXXAOSICXX is almost as Godly as yodasarmpitXXAOSICXX is almost as Godly as yodasarmpit
That's why I use SpiderOak
XXAOSICXX is offline   Reply With Quote
Old 13th Mar 2013, 16:53   #5
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
I used to use SpiderOak, until the synchronisation function started serving up outdated copies of files and clobbering the new ones. Then I switched to Ubuntu One - it's the closest thing I've found to Dropbox that isn't actually Dropbox.
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is offline   Reply With Quote
Old 13th Mar 2013, 23:09   #6
pbryanw
Multimodder
pbryanw has yet to learn the way of the Dremel
Wuala can do this too but it's Mac client is a bit rubbish at the moment (new beta on the way though). Windows is fine though and it comes in useful when syncing folders between PCs.
pbryanw is offline   Reply With Quote
Old 13th Mar 2013, 23:13   #7
longweight
Possibly Longbeard.
longweight's Avatar
longweight is definitely a rep cheat.longweight is definitely a rep cheat.longweight is definitely a rep cheat.longweight is definitely a rep cheat.longweight is definitely a rep cheat.longweight is definitely a rep cheat.longweight is definitely a rep cheat.longweight is definitely a rep cheat.longweight is definitely a rep cheat.longweight is definitely a rep cheat.longweight is definitely a rep cheat.
Skydrive is bloody awesome.
longweight is offline   Reply With Quote
Old 13th Mar 2013, 23:26   #8
Pliqu3011
The cake is an alternative fact
Pliqu3011's Avatar
Pliqu3011 is a Super Spamming SaiyanPliqu3011 is a Super Spamming SaiyanPliqu3011 is a Super Spamming SaiyanPliqu3011 is a Super Spamming SaiyanPliqu3011 is a Super Spamming SaiyanPliqu3011 is a Super Spamming SaiyanPliqu3011 is a Super Spamming SaiyanPliqu3011 is a Super Spamming SaiyanPliqu3011 is a Super Spamming SaiyanPliqu3011 is a Super Spamming SaiyanPliqu3011 is a Super Spamming Saiyan
Especially if you have an old hotmail account lying around and get a free 25GB (don't know if that still works though)
__________________
“Talent is a pursued interest. In other words, anything that you're willing to practice, you can do.” - Bob Ross
“Ὁ βίος βραχύς, ἡ δὲ τέχνη μακρή, ὁ δὲ καιρὸς ὀξύς, ἡ δὲ πεῖρα σφαλερή, ἡ δὲ κρίσις χαλεπή.” - Hippocrates
Pliqu3011 is offline   Reply With Quote
Old 13th Mar 2013, 23:27   #9
longweight
Possibly Longbeard.
longweight's Avatar
Sadly I don't think that it does.
Old 14th Mar 2013, 00:17   #10
yougotkicked
A.K.A. YGKtech
yougotkicked's Avatar
yougotkicked has yet to learn the way of the Dremelyougotkicked has yet to learn the way of the Dremelyougotkicked has yet to learn the way of the Dremel
well, I can't say I actually use the sharing features of dropbox much at all, but maybe this will give me a reason to.
@Platinum: it's not a perfect solution, but simply moving the actual files to a subdirectory of your dropbox folder and placing a shortcut to said folder where the files used to be might be worth considering. Symlinks in linux would do it very well, but windows might not like it.
__________________
Intel I5 2500K @ 4.5Ghz on air ::::: 16GB DDR3 @ 1866mhz 9-9-9-27-1T
Asus P8Z68-V LX ::::: NVIDIA GTX 680
128 GB intel SSD, 1 TB Samsung Spinpoint F3 HDD, 2x 1 TB WD drives in Raid 1
2x 2 TB WD drives in Raid 1, 160 GB Hitachi Deskstar HDD
yougotkicked is offline   Reply With Quote
Old 14th Mar 2013, 14:49   #11
Bloody_Pete
Technophile(and yes, thats 724Mb/s)
Bloody_Pete's Avatar
Bloody_Pete is a Super Spamming SaiyanBloody_Pete is a Super Spamming SaiyanBloody_Pete is a Super Spamming SaiyanBloody_Pete is a Super Spamming SaiyanBloody_Pete is a Super Spamming SaiyanBloody_Pete is a Super Spamming SaiyanBloody_Pete is a Super Spamming SaiyanBloody_Pete is a Super Spamming SaiyanBloody_Pete is a Super Spamming SaiyanBloody_Pete is a Super Spamming SaiyanBloody_Pete is a Super Spamming Saiyan
I love Dropbox for my uni work! Plus I have 30gb for free because of the space race they did...
__________________
i5 3570k @ 4.6GHz (1.28v) on custom water loop/ Watercooling how-to, Asus Maximus 5 Gene, 16GB Corsair Vengence 1600MHz (2 black, 2 red), Asus 780 Posiedon Platinium, 512GB Crucial Mx1000, 3 x Samsung F1 1TB in RAID 5, Xigmatek Elysium, Enermax Revolution 85+ 850W, Corsair K60, Corsair SP2500 speakers, Dell U2311H & Asus VK222W.
Bloody_Pete is offline   Reply With Quote
Old 16th Mar 2013, 05:57   #12
cebla
Multimodder
cebla has yet to learn the way of the Dremel
I use symlinks on windows to make other folders sync using dropbox and it hasn't caused any issues. I then have powershell script which I can run which I can run on a new machine to setup the symlink folders how I like them.
cebla is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
