Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 14th Mar 2013, 10:57   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
Fujitsu boosts optical networks with ADSL tech
Ten-fold increase for off-the-shelf parts.
http://www.bit-tech.net/news/hardwar...itsu-optical/1
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is online now   Reply With Quote
Old 14th Mar 2013, 12:22   #2
Blackshark
Multimodder
Blackshark has yet to learn the way of the Dremel
SO if I stick one of these fibre optics in my ear - will I hear the classic 56k modem handshake!!??
Blackshark is offline   Reply With Quote
Old 14th Mar 2013, 12:32   #3
Corky42
What did walle eat for breakfast?
Corky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming SaiyanCorky42 is a Super Spamming Saiyan
No, silly.
It's a optics cable you have to stick it in your eye.
Corky42 is online now   Reply With Quote
Old 14th Mar 2013, 12:52   #4
Gareth Halfacree
WIIGII!
bit-tech Staff
Originally Posted by Corky42 View Post
No, silly.
DO NOT LOOK INTO FUJITSU WITH REMAINING EYE.
__________________
Old 14th Mar 2013, 13:30   #5
kenco_uk
I unsuccessfully then tried again
kenco_uk's Avatar
kenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyan
THE INTERNET CAME INTO MY EYES AND OUT OF MY NOSE HOLES.
The applications for this are immense. I hope it ends up being a simple drop in replacement for all the shiny FTTC cabinets that are hanging around on street corners.
__________________
formaggio gāteau
kenco_uk is offline   Reply With Quote
Old 14th Mar 2013, 15:13   #6
play_boy_2000
It was funny when I was 12
play_boy_2000's Avatar
play_boy_2000 is definitely a rep cheat.play_boy_2000 is definitely a rep cheat.play_boy_2000 is definitely a rep cheat.play_boy_2000 is definitely a rep cheat.play_boy_2000 is definitely a rep cheat.play_boy_2000 is definitely a rep cheat.play_boy_2000 is definitely a rep cheat.play_boy_2000 is definitely a rep cheat.play_boy_2000 is definitely a rep cheat.play_boy_2000 is definitely a rep cheat.play_boy_2000 is definitely a rep cheat.
The lasers are the drop in part. You still need line cards with 100gbit ports, which I might point out, are a bit hard to come by at the moment. Unless fijitsu can have this ratified as a proper Ethernet sfp standard (along the lines of 1000base-lx, 1000base-sx etc) then it's never going to be of much use, especially if the it's not compatible with existing 40/100gbit line cards.
And for those of you who think this will speed up fttn, or even ftth anytime soon.... lol.
__________________
Intel Core i5 2500k @ 4.5Ghz
16GB @ 1600mhz CL9 1.5V
XFX 7950 3GB
Asus P8P67
Patriot Wildfire 120GB SSD
play_boy_2000 is offline   Reply With Quote
Old 14th Mar 2013, 15:22   #7
Gareth Halfacree
WIIGII!
bit-tech Staff
Actually, the lasers are unmodified COTS parts designed for 10Gb/s transmission. Says so in the article. Which, of course, you read before commenting. In full.
__________________
Old 14th Mar 2013, 15:59   #8
Krikkit
Super Moderator
Moderator
Krikkit's Avatar
Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.
<3
__________________
The Good, The Bad, The Ugly, The Zlad!, The Wut?!, The Kempness
Krikkit is offline   Reply With Quote
Old 14th Mar 2013, 20:58   #9
Hustler
Hypermodder
Hustler's Avatar
Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.
"For home users, the system promises a potential boost for the growing number of fibre broadband services: current fibre to the cabinet (FTTC) systems could enjoy a tenfold boost to the cabinet to eliminate congestion"
Ooooh!!!!, sounds amazing, then you realise we'd have to rely on BT to actually fit this stuff into their cabinets..so, should be ready around 2020 if we're lucky.
Hustler is offline   Reply With Quote
Old 18th Mar 2013, 17:58   #10
LightningPete
Diagnosis: ARMAII-Holic
LightningPete has yet to learn the way of the Dremel
Well at least theres something that the companies have to upgrade us in 2 years time, even if the tech were available now. Although they screw us out of this tech now, at least we know our FTTC services are going to improve eventually and by a sizeable amount (even if not that described).
Well done on fujitsu for research time and effort for this
LightningPete is offline   Reply With Quote
Old 19th Mar 2013, 20:35   #11
play_boy_2000
On this side of the pond, a drop-in part generally refers to a generic, easy to acquire part that can be used in place of a more expensive custom part. How does the Queen's English define it?
__________________
XFX 7950 3GB
Asus P8P67
Old 20th Mar 2013, 08:01   #12
Gareth Halfacree
WIIGII!
bit-tech Staff
That definition does not fit in this context: a drop-in replacement is exactly what it sounds like, a replacement part that requires only that the original part be removed and does not require any redesign work. An AMD A10-5800K is a drop-in replacement for an AMD A6-5400K, for example. The lasers, however, are not being replaced - hence that definition not fitting the context.
Re-read the article and what you wrote in reply, and insert "a generic, easy to acquire part that can be used in place of a more expensive custom part," see if your reply still makes sense in the context in which it was made. I posit it does not.
The drop-in part, in this case, is the modem Fujitsu has invented: it 'drops in' to a design that has a 10Gb/s transceiver and makes it a 100Gb/s transceiver. The laser is not a 'drop in' part, in either use of the phrase, because it's not being replaced at all - it's the same laser in both designs.
__________________
Old 20th Mar 2013, 15:43   #13
play_boy_2000
In any event, my point was that fijitsu has not created a drop in replacement for an optical ethernet transceiver. No doubt that the IEEE may want to integrate some of the technology into a proper standard, but that is years away, and will require new line card designs.
__________________
XFX 7950 3GB
Asus P8P67
Reply
Tags
broadband, data centre, fibre optic, fibre optic broadband, fibre to the cabinet, fibre to the home, fttc, ftth, fujitsu, optical, optical networking
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
