Reply
Thread Tools View Mode
Old 30th Mar 2013, 12:16   #1
Piotrek_PL
Modder
Piotrek_PL's Avatar
Piotrek_PL is a hoopy frood who really knows where their towel is.Piotrek_PL is a hoopy frood who really knows where their towel is.Piotrek_PL is a hoopy frood who really knows where their towel is.Piotrek_PL is a hoopy frood who really knows where their towel is.Piotrek_PL is a hoopy frood who really knows where their towel is.Piotrek_PL is a hoopy frood who really knows where their towel is.Piotrek_PL is a hoopy frood who really knows where their towel is.Piotrek_PL is a hoopy frood who really knows where their towel is.Piotrek_PL is a hoopy frood who really knows where their towel is.Piotrek_PL is a hoopy frood who really knows where their towel is.Piotrek_PL is a hoopy frood who really knows where their towel is.
ReactorMod rusty project. FINISHED - final pics!
Hi there! Itís my first post here so I thought it would be nice to write a few words about myself before I proceed to the project log. Iím not a native English Ė I live in Warsaw in Poland Ė but I will do my best to use proper English Iíve completed several small mods that are not even worth posting here but I think Iíve learnt a lot while building them. Oh how much metal sheets I have trashed before Iíve caught how to do stuff.
Now thanks to my older brother whoís set up a small workshop in the basement I have a chance to make something better.
Ok but lets get back to the project. Iíve stared it in July 2012 and I kept a log only on my local forum. Now the build is quite close to an end so I decided to share it with you.
I was thinking about a way to write this log for a while and because thereís a lot of stuff to show Iíve decided that the best way would be to divide it by particular parts of the case. I donít want to spoil the fun and end this log too quickly And I must admit that writing this log takes more time than I expected.
Hardware. It's not really anything to be proud of, just my computer for every day usage.
CPU: Athlon II x4 640
MB: MSI 870-C45
RAM: 2x2GB Kingston HyperX
GPU: GeForce GTS450 512GDDR5
HDD: 120GB Kingston SSDNow oraz 250GB Seagate
PSU: Chieftec 450W
Iím proud to say that all water cooling parts used in this build were sponsored by EK Water Blocks.
I want to make a case that will look like old, a little seedy like it was used for many years in bad conditions, in a factory or something. You know Ė rust, cracks and so on. I was inspired by some old control and measurement instruments and stuff that Iíve found on the nearest scrap yard
Iíve started looking for some case in the online shops and I decided to buy second hand Chieftec BX-03. It was cheap and looked like easy to mod.
Iíve started from modding the front panel. Striped parts removed and mesh put instead. Luckily everything was mounted only with some latches so there was no need to cut.
Then I cut the mesh and bent it. Itís all screwed with nice rusty screws that I kept for a special occasion.
Overall view of the front panel.
The right side of the case also needed some change. There were two air-holes, I decided to get rid of them and put some mesh instead.
Again: cutting and bending and finally it's a perfect fit.
In this photo you can see the screws but then I decided to use pop-rivets, but the mesh must rust before riveting it.
I left all the mesh outside on the rain to rust and started work on the left side panel. There will be a lot to do with it
More to come soon...
and sorry for my bad English
Piotrek_PL is offline   Reply With Quote
Old 2nd Apr 2013, 01:28   #2
Piotrek_PL
Modder
Piotrek_PL's Avatar
Sponsored by EKWB
Afterwards I began the work on the left side panel of the case. I remembered having old switch that I've found on the scrap yard.
The switch is mounted, it was a quick job, only three holes were needed. I've decided to make a series connection between those black buttons so they will work as reset switch only when pressed together. The red button will be power switch of course.
And a quick look on the insides
Now it was the high time for bigger changes in this case. After some quick welding the radiator mount is made. Photo was made before drilling holes for screws.
The radiator is mounted.
As you can see in the photo above the radiator is sticking out a mile from the case, so I had to cut the left side panel.
A day ago I saw a perforated metal sheet and I couldn't resist to buy it. It turned out a great solution for building the radiator cover.
Cutting...
..bending...
Finally I made a nice box
and welded it onto the side panel. In this snapshot you can also see the lines for cutting the window.
It was quite dark already but it didn't put mi off. I prefer to use grinder outside because my workshop is very small
Once I cut it I could get back to the basement
How do you call this kind of gasket?
The window will be made from parts of an old laptop broken screen.
Hope I didn't overdo with this cracks.
Let me know if you like it, expect the next update in next few days
Old 2nd Apr 2013, 10:14   #3
Parge
the worst
Moderator
Parge's Avatar
Parge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming Saiyan
Love it, and really enjoy seeing old cases made good again!
__________________
NCase M1 - 5820k @4.3Ghz - H105 - GTX 980ti - ASRock X99e ITX/ac - 16GB DDR4 - 3x SSD - 600w SFX - 29" Ultrawide - Xonar U7 - Bassshaker - RAT3 - Quickfire TK - Q90s - Orbweaver - Warthog
Parge is offline   Reply With Quote
Old 2nd Apr 2013, 10:36   #4
Darkwisdom
Level 99 Retro Nerd
Darkwisdom's Avatar
Darkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming Saiyan
Nice industrial look. I like the idea of making those old workshop style switches as power buttons. Are you going to do anything about the rusted parts? You don't want the rust to spread all over the rest of your project.
It's nice to see a project that isn't just made by throwing money at it.
__________________
Main Rig: i3 3220 ~ GTX 970 Strix ~ 8GB Vengeance Ram ~ EVGA Supernova G2 750W ~ P8H77-m le ~ Samsung 830 128GB SSD ~ Steelseries GCv2 ~ Razer imperator ~
Darkwisdom is offline   Reply With Quote
Old 2nd Apr 2013, 11:21   #5
Sheiken
Wat?
Sheiken's Avatar
Sheiken is almost as Godly as yodasarmpitSheiken is almost as Godly as yodasarmpitSheiken is almost as Godly as yodasarmpitSheiken is almost as Godly as yodasarmpitSheiken is almost as Godly as yodasarmpitSheiken is almost as Godly as yodasarmpitSheiken is almost as Godly as yodasarmpitSheiken is almost as Godly as yodasarmpitSheiken is almost as Godly as yodasarmpitSheiken is almost as Godly as yodasarmpitSheiken is almost as Godly as yodasarmpit
Loving it!
__________________
Whoring Out My Hardware 4.6!
Portaputer - rMBP Late 2013 - 13" / i5 / 8GB / 256gb ssd
Sheiken is offline   Reply With Quote
Old 2nd Apr 2013, 14:35   #6
matiss
Multimodder
matiss's Avatar
matiss is definitely a rep cheat.matiss is definitely a rep cheat.matiss is definitely a rep cheat.matiss is definitely a rep cheat.matiss is definitely a rep cheat.matiss is definitely a rep cheat.matiss is definitely a rep cheat.matiss is definitely a rep cheat.matiss is definitely a rep cheat.matiss is definitely a rep cheat.matiss is definitely a rep cheat.
Instantly reminds me of Stalker and Metro 2033. Very nice.
__________________
in planning for to long: Viole(n)t Raven
matiss is offline   Reply With Quote
Old 3rd Apr 2013, 09:17   #7
Piotrek_PL
Modder
Piotrek_PL's Avatar
thanks. I'm not going to do anything about the rusted parts, actually I do want this mod to be rusted and later I'll be adding even more rust
Old 3rd Apr 2013, 22:48   #8
Piotrek_PL
Modder
Piotrek_PL's Avatar
Sponsored by EK Water Blocks:
OK guys that's gonna be a bigger update! This time I'll show you the building process of the reservoir.
The mesh that I put into the side and front panel rusted nicely.
Let's get around to the res.
Started with aluminium pipe (60mm diameter)
A while of milling. In this photo there are three separate 'bean' shapes cut but then I thought that a one longer will look better.
Now it's time for the res window. First time I've made it from epoxy resin
it went out pretty good
but sadly there was a small leak between the window and the pipe (don't know how that's possible, I think it's because of different thermal expansion of the epoxy and the pipe), so I came up with a new idea. Drilled and rifled 8 holes that will hold a plexiglass. It's now sealed with silicon. No more problems
Then I proceeded to the 70 diameter 20 mm thick aluminium rod slices.
After a while of turning they changed a bit. They will be the reservoir caps.
This one will be the bottom one. Two G1/4" threads.
And this will be to upper one.
The plug for connecting the UV diodes that will sit inside the res and the plug for filling the reservoir.
That plug needed some turning to allow it to screw in completely.
Once the res itself is made it's time to make it's mount. It wasn't hard, just a 2 flat bars with 4 holes in them and a 2 rifled 5mm diameter aluminium bar.
I also made a pass inside the case for the hose.
And the final look on the front.
Hope you enjoyed, sorry for the mistakes and stay tuned! Next update soon
Old 4th Apr 2013, 07:37   #9
dreps
Multimodder
dreps has yet to learn the way of the Dremeldreps has yet to learn the way of the Dremeldreps has yet to learn the way of the Dremeldreps has yet to learn the way of the Dremeldreps has yet to learn the way of the Dremeldreps has yet to learn the way of the Dremeldreps has yet to learn the way of the Dremeldreps has yet to learn the way of the Dremel
looking stunning already keep up the nice work!
dreps is offline   Reply With Quote
Old 4th Apr 2013, 13:28   #10
ziza
Multimodder
ziza's Avatar
ziza has yet to learn the way of the Dremel
Hehe this is a tough project.
Nice res.
__________________
Per me si va nella cittŗ dolente,
per me si va nell'eterno dolore,
per me si va tra la perduta gente
ziza is offline   Reply With Quote
Old 4th Apr 2013, 16:38   #11
Vetalar
*learning english*
Vetalar is a Super Spamming SaiyanVetalar is a Super Spamming SaiyanVetalar is a Super Spamming SaiyanVetalar is a Super Spamming SaiyanVetalar is a Super Spamming SaiyanVetalar is a Super Spamming SaiyanVetalar is a Super Spamming SaiyanVetalar is a Super Spamming SaiyanVetalar is a Super Spamming SaiyanVetalar is a Super Spamming SaiyanVetalar is a Super Spamming Saiyan
alu + cu (WB and rads - bad idea due to galvanic corrosion
__________________
10 re-plan "SuperBestBuild Of My Dream"
20 have a sleep
30 goto 10
Vetalar is offline   Reply With Quote
Old 4th Apr 2013, 16:51   #12
Piotrek_PL
Modder
Piotrek_PL's Avatar
yeah I know about that, that is why I've covered all res on the inside with the layer of epoxy and I will be using the EK Coolant which contains a corrosion inhibitors
Old 4th Apr 2013, 18:07   #13
Pranja
Blackwolf
Pranja's Avatar
Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.
+1
Really not good idea. If you want Alu,whole loop must have Alu components.
Pranja is offline   Reply With Quote
Old 4th Apr 2013, 21:20   #14
Piotrek_PL
Modder
Piotrek_PL's Avatar
Originally Posted by Pranja View Post
+1
Yeah guys I do know about it, that's why I've covered all the reservoir on the inside with a solid layer of the epoxy. And I will be using EK- Ekoolant which protect the loop from corrosion. Anyway I realise that I'll have to be careful with that
edit. sorry for double post its because I was using my smartphone..
Old 7th Apr 2013, 21:48   #15
Piotrek_PL
Modder
Piotrek_PL's Avatar
"The amount of posts in this thread
Is too damn low! "
I expect this case to be quite heavy, so I added four eye nuts as some kind of hooks.
Fitting before welding them in place.
Drilled 4 holes for the screws and welded.
There's really not much to say about that, see the outcome. Later I will remove the zinc coat from the nuts to make them look old.
Close-up.
Overall view.
I like how it went out
In this build I will have several things which voltage I'd need to control (fans, light, pump and so on) and I don't want to use ordinary control panel so I decided to build one from scratch.
After a while of wondering this is what I made.
I think it's the simplest circuit possible based on the LM317t. As gauge I will use 12V bulb per channel running on 6V when max output volatge is set, so they won't dazzle eyes.
After bending this is gonna be the controller case. 2mm thick steel.
Good hammer comes in handy!
I had left some perforated steel so I used it on the sides. That's finished controller case.
First run of the controller. Dat feeling...when everything works fine on the first try!
I also had this connector at the very bottom of the closet with computer stuff . Don't know from what it is, it's only important that it's quite old
Made the mount for it from the flat bar and welded it onto the top of the case. The pass for cables is also visible in this shot.
All controller in place, final shots (of the controller, not the case!).
Ouch there must have been a shorting in the circuit as there are several burnt cables
View on the case, I think the controller completely change its appearance, didn't it ?
Old 9th Apr 2013, 18:05   #16
Piotrek_PL
Modder
Piotrek_PL's Avatar
Hey guys, do you see the pics? There's a problem with my server and some people from particular countries for example Argentina or US might not see them, don't know what's going on, my hosting support is working on it (at least they say they are..)
If you don't see them please tell me what error do you get and where are you from, it will help solving it. Thanks!
Old 9th Apr 2013, 18:36   #17
Pranja
Blackwolf
Pranja's Avatar
I have no problem with pics-they are fine.
Old 11th Apr 2013, 19:37   #18
ry@n
Ultramodder
ry@n's Avatar
ry@n can run Crysisry@n can run Crysisry@n can run Crysisry@n can run Crysisry@n can run Crysisry@n can run Crysisry@n can run Crysisry@n can run Crysisry@n can run Crysisry@n can run Crysisry@n can run Crysis
Looking really good! I enjoy looking at how themed builds are put together, its not often you see a welder using on a case mod
__________________
Stacker 830 Evo //Core i7-920 ~ 4Ghz (4.2 stable) //Gigabyte EX58-UD5 //Corsair Dominator 6GB 1600Mhz //BFG GTX 285 OCX //BeQuiet! 750w //Samsung F3 1TB
DDC Ultra 18w //Black Ice 360mm //EK Multioption 250mm //Heatkiller LT CPU Block //MIPS RAM block
DDC Ultra 18w //Black Ice 240mm //EK Multioption 150mm //No Blocks yet
- Dual Loop i7 Stacker Left Handed? CLICK HERE -
ry@n is offline   Reply With Quote
Old 11th Apr 2013, 19:53   #19
Shurika
Multimodder
Shurika's Avatar
Shurika has yet to learn the way of the DremelShurika has yet to learn the way of the Dremel
That's pity I can't see any pics...
__________________
sorry for my English
Shurika is offline   Reply With Quote
Old 11th Apr 2013, 20:38   #20
Piotrek_PL
Modder
Piotrek_PL's Avatar
Thanks! I hope more ppl will see the pics soon
Yeah my server blocks some IP's due to safety reasons...need to change it asap, hope to fix it soon.
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
