Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 9th Apr 2013, 14:58   #1
Meanmotion
bleh
Meanmotion's Avatar
Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.
Crucial M500 SSDs made official, available today
Crucial has officially unveiled its latest M500 SSDs, and they're already available to buy.
http://www.bit-tech.net/news/hardwar...-20nm-micron/1
Meanmotion is offline   Reply With Quote
Old 9th Apr 2013, 15:15   #2
meandmymouth
I Mod, Therefore I Own
meandmymouth's Avatar
meandmymouth is a Super Spamming Saiyanmeandmymouth is a Super Spamming Saiyanmeandmymouth is a Super Spamming Saiyanmeandmymouth is a Super Spamming Saiyanmeandmymouth is a Super Spamming Saiyanmeandmymouth is a Super Spamming Saiyanmeandmymouth is a Super Spamming Saiyanmeandmymouth is a Super Spamming Saiyanmeandmymouth is a Super Spamming Saiyanmeandmymouth is a Super Spamming Saiyanmeandmymouth is a Super Spamming Saiyan
A bit on the slow side compared to the 840's but some nice features included.
__________________
Main - i7 3770K, Maximus V Gene, 32GB Crucial, 480 Sandisk Ultra II, 7TB HDD's, Fractal Arc Mini, CM 850W
meandmymouth is offline   Reply With Quote
Old 9th Apr 2013, 15:42   #3
Harlequin
Harlequin's Avatar
Harlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming SaiyanHarlequin is a Super Spamming Saiyan
looks like they binned the V4 as well (its gone from crucial shop)
__________________
They shall grow not old, as we that are left grow old:
Age shall not weary them, nor the years contemn.
At the going down of the sun and in the morning
We will remember them
Harlequin is offline   Reply With Quote
Old 9th Apr 2013, 19:09   #4
Blackshark
Multimodder
Blackshark has yet to learn the way of the Dremel
1TB of Crucial SSD goodness for less than 500 GBP!! I can remember buying a 256 C300 for that price, a 512 M4 for that price. OK OK, maybe not the full TB but still that is pretty good going. So have we reached the point where development, both speed and capacity growth will slow?
Blackshark is offline   Reply With Quote
Old 9th Apr 2013, 22:37   #5
roundyz
Multimodder
roundyz is the Cheesecake. Relix smiles down upon them.roundyz is the Cheesecake. Relix smiles down upon them.roundyz is the Cheesecake. Relix smiles down upon them.roundyz is the Cheesecake. Relix smiles down upon them.roundyz is the Cheesecake. Relix smiles down upon them.roundyz is the Cheesecake. Relix smiles down upon them.roundyz is the Cheesecake. Relix smiles down upon them.roundyz is the Cheesecake. Relix smiles down upon them.roundyz is the Cheesecake. Relix smiles down upon them.roundyz is the Cheesecake. Relix smiles down upon them.roundyz is the Cheesecake. Relix smiles down upon them.
315.99 for the 960GB would be a winner.
roundyz is offline   Reply With Quote
Old 9th Apr 2013, 23:11   #6
theshadow2001
[DELETE] means [DELETE]
theshadow2001's Avatar
theshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyantheshadow2001 is a Super Spamming Saiyan
When it comes to capacity and value on SSD crucial have it down
theshadow2001 is offline   Reply With Quote
Old 9th Apr 2013, 23:19   #7
Gradius
IT Consultant
Gradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for president
Still capped @ 500MB/s? Too slow if you are already used to it (not me, I'm used to 2GB/s).
Gradius is offline   Reply With Quote
Old 10th Apr 2013, 09:59   #8
Mankz
5318008
Mankz's Avatar
Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.Mankz is definitely a rep cheat.
a 960Gb drive is $600 in the US.. that would make it very attractive if the price had been ported over properly :/
Mankz is offline   Reply With Quote
Old 10th Apr 2013, 10:35   #9
andrew8200m
Mod Master
andrew8200m's Avatar
andrew8200m is a Super Spamming Saiyanandrew8200m is a Super Spamming Saiyanandrew8200m is a Super Spamming Saiyanandrew8200m is a Super Spamming Saiyanandrew8200m is a Super Spamming Saiyanandrew8200m is a Super Spamming Saiyanandrew8200m is a Super Spamming Saiyanandrew8200m is a Super Spamming Saiyanandrew8200m is a Super Spamming Saiyanandrew8200m is a Super Spamming Saiyanandrew8200m is a Super Spamming Saiyan
It has... You forgot to add state tax orin the UK ... VAT.
That makes it 473ish.. which most are at 499.99inc or there abouts.
__________________
Systems with parts from various manfacturers
andrew8200m is offline   Reply With Quote
Old 10th Apr 2013, 12:01   #10
Harlequin
Harlequin's Avatar
nah only scan are 500 - most are less
edit:
I stand corrected , looks like ocuk et all are price gouging as yesterday they were 460 or so and are now 500
__________________
Old 10th Apr 2013, 12:22   #11
Blackshark
Multimodder
I am at work, but I havent found a way to squeeze a PCI express SSD in to my laptop - which is all I have at home :-( Also I am not sure what game I could run that would find much of a difference between two raided M4s in my sony laptop and a 2Gb / s PCI Express SSD. There are few games if any that run at queue depths high enough to utilise your card. Or are you using a larger array on SATA ports?
Old 10th Apr 2013, 14:26   #12
LightningPete
Diagnosis: ARMAII-Holic
LightningPete has yet to learn the way of the Dremel
The write speed on the 120GB flavour looks a tad slow, other current and previous gen SSDs at 120gb shown on Scans website include uppers of 300~400mb/s write speeds or is that just the speed they state on all of them?
LightningPete is offline   Reply With Quote
Old 11th Apr 2013, 15:47   #13
Kodongo
Multimodder
Kodongo's Avatar
Kodongo can run CrysisKodongo can run CrysisKodongo can run CrysisKodongo can run CrysisKodongo can run CrysisKodongo can run CrysisKodongo can run CrysisKodongo can run CrysisKodongo can run CrysisKodongo can run CrysisKodongo can run Crysis
^ It's because the Crucial M500s are using NAND which is twice the density of all the other drives therefore we have the performance of a 60/64 GB drive but with twice the capacity. This is also why Crucial refrained from releasing a 60GB version as it would be truly pedestrian compared to other SSDs.
__________________
Intel Core i7-2600k | Noctua NH-C14 | Sapphire R9 290 Tri-X OC | Asus P8P67-M Pro | Samsung 8GB 30nm | Samsung 830 256GB | WD Black 1.5TB + 1TB | Seasonic X-660 | Dell U2412M | Ducky Shine III (Brown) | Asus RT-N66U
Kodongo is offline   Reply With Quote
Old 12th Apr 2013, 10:32   #14
r3loaded
Ultramodder
r3loaded's Avatar
r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.r3loaded is definitely a rep cheat.
Meh, the Samsung 840 is cheaper and the 840 Pro only costs a small premium. The M500 would be awesome if Samsung didn't exist.
It's also worth noting the 840 series have a cashback offer until the end of May:
__________________
Main: Silverstone FT03 | Asus P8P67-M Pro | i5 2500K @ 4.6Ghz | CM 212+ | 16GB Corsair Vengeance 1600Mhz | XFX Radeon 7970 DD | 500GB Samsung 840 Evo | Samsung XL2270HD | KBT Race | Logitech G402
Mac: 13 inch MacBook Pro 2014 | 16GB RAM | Filco Minila Air | Magic Trackpad
Server: Asus M3N78-AM | Athlon II X3 400e | 4GB Corsair XMS2 | 4x 2TB Samsung F4EG (RAID-5) | LSI MegaRAID 8708EM2 | Corsair CX400 | Arch Linux
r3loaded is offline   Reply With Quote
Old 12th Apr 2013, 12:04   #15
jrs77
theorycrafting
jrs77's Avatar
jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.
Anand allready benched all the capacities of this drive and can only recommend the 960GB version really, as the Samsung 840 Pro and other drives are more competitive in price/performance for the smaller capacities.
http://www.anandtech.com/show/6884/c...gb-240gb-120gb
__________________
...and allways remember, that the world is an orange!
Cooltek/Jonsbo U1 | Silverstone SX500-LG | Noctua NF-R8 Redux 1200
Gigabyte H97N-WiFi | intel i7-5775C | Noctua NH-D9L | Crucial Ballistix 16GB DDR3L1600 | Crucial MX200 250GB | 2.5" WD AV 1TB
jrs77 is offline   Reply With Quote
Old 12th Apr 2013, 14:36   #16
Harlequin
Harlequin's Avatar
3 warranty is poor to be honest as well
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
