Reply
Thread Tools View Mode
Old 12th Apr 2013, 09:34   #1
maRiio
Multimodder
maRiio's Avatar
maRiio has yet to learn the way of the DremelmaRiio has yet to learn the way of the DremelmaRiio has yet to learn the way of the Dremel
HDD-Case(s): rusty, weathered and old! FINAL PICTURES! 26.04.
Hi all!
I just want to present you one/two of my hard drive cases I did recently.
Since I'm doing a lot of photography and post-processing my data was growing unexpectingly fast so a few hard disks and cases had to be ordered.
The case(s) did look a little to normal for my taste so I decided to get them a little bit of modding
Unfortunately I did not make that much pics during the working on the case so I only have a few to present you.
The base case is a Raid-Sonic IcyBox, with a airbrush-finish to get a weathered effect all over it.
I did an outer shell of aluminum for the case to get a little bit more depth and additional effects when doing the rusty painting and breaking some parts of the material off. This is what the base case after the main work was done, did look like.
For this case I bought my first airbrush gun and tried a little bit to do some effects on some sheets of metal. After that I did the best I could on the case itself and was quite satisfied how it did end up
After the first paint-job the case looked like this
And having the inside finished and the disk in place I did the final steps to get the effect I wanted to achieve The rust was created by a special mixture of paint which contains iron-particles which rusts when painted with another special liquid which accellerates the oxiding process - it's just like magic
When the paint was ready I removed the front cover too since it didn't find right onto the case imho.
Right now I'm onto my second case... pictures will follow
EDIT: the case is finished, see the following posts of me...
Here's the result...
Cheers from Austria (not Australia!),
Mario
maRiio is offline   Reply With Quote
Old 12th Apr 2013, 09:42   #2
Shirty
Here from the future...
Moderator
Shirty's Avatar
Shirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, Shirty
That's some sweet detail on there. Good work.
__________________
6700K | Z170I | Liqtech 120X | EVGA GTX 980Ti SC | 16GB | 1TB M550 | Node 304 | SS-460FL2 (fanless) | Dell S2740L | Ducky TKL | Logitech G500
I also have a Surface Pro 2, even though I'm not a pro...
Shirty is offline   Reply With Quote
Old 12th Apr 2013, 09:53   #3
jrs77
theorycrafting
jrs77's Avatar
jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.jrs77 is definitely a rep cheat.
Very nicely done, and some great detail. A little bit sad, that there's no WIP-pictures tho.
__________________
...and allways remember, that the world is an orange!
Cooltek/Jonsbo U1 | Silverstone SX500-LG | Noctua NF-R8 Redux 1200
Gigabyte H97N-WiFi | intel i7-5775C | Noctua NH-D9L | Crucial Ballistix 16GB DDR3L1600 | Crucial MX200 250GB | 2.5" WD AV 1TB
jrs77 is offline   Reply With Quote
Old 12th Apr 2013, 09:53   #4
aramil
One does not simply upgrade Windows
aramil's Avatar
aramil is definitely a rep cheat.aramil is definitely a rep cheat.aramil is definitely a rep cheat.aramil is definitely a rep cheat.aramil is definitely a rep cheat.aramil is definitely a rep cheat.aramil is definitely a rep cheat.aramil is definitely a rep cheat.aramil is definitely a rep cheat.aramil is definitely a rep cheat.aramil is definitely a rep cheat.
I like just needs a pc case to match :thumbup:
__________________
System: Intel i5 3570K delidded CLU @ 4.4Ghz | Asus Stabertooth Z77 |Palit GeForce GTX 980 Super Jetstream 4Gb | Samsung 840 EVO 250Gb | Samsung 1Tb F2 | WD 1Tb | Corsair 750TX v2 | 16Gb (4x4) Corsair Vengence | Corsair K90 Keyboard | XSPC-Raystorm-750-RS2400 | Zalman MS800 | AOC 27" 2560x1440 | Windows 10 Pro 64bit | Linx10 Tablet ED: CMDR Aramil Lorrathain Become a Star Citizen get 5,000 free Credits HERE
aramil is offline   Reply With Quote
Old 12th Apr 2013, 09:56   #5
maRiio
Multimodder
maRiio's Avatar
@jrs77: yeah :/ I'm quite sad about that too but I'm working on a much cooler case right now which is logged
Maybe I will upload the pics today if there's the time to do so.
Thanks to you, Shirty and aramil!
Old 12th Apr 2013, 10:03   #6
ziza
Multimodder
ziza's Avatar
ziza has yet to learn the way of the Dremel
WOW outstanding job
__________________
Per me si va nella città dolente,
per me si va nell'eterno dolore,
per me si va tra la perduta gente
ziza is offline   Reply With Quote
Old 14th Apr 2013, 16:29   #7
maRiio
Multimodder
maRiio's Avatar
Here's the base of the second case... "base"
It's nearly finished, just some paint is left to be sprayed on... and of course the weathering effects that should go with the cases finish
Cheers,
Mario
Old 14th Apr 2013, 17:39   #8
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming Saiyan
Those look cool. I like that you added a second layer. They should have superior ventilation to the stock setup now too.
__________________
The Iron Turnip·BlooBalls·Hypnotoad·Plank·Reservoir-Things·NUC-Tooobular·C7Waterblocks·Crusty McBeanbags III·GlassGreen
Powered by: AMD·Gigabyte·Swiftech·Hardware Labs·Noctua·DangerDen
Cheapskate is offline   Reply With Quote
Old 16th Apr 2013, 13:41   #9
Burnout21
Is the daddy!
Burnout21's Avatar
Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.
Love it!
HDD, painted orange like a flight box recorder?
__________________
Project log Mocha70
i7 930, GA-X58-USB3, 12GB Kingston, GTX980, 240GB Cruical SSD, 1Tb Seagate, WC
Burnout21 is offline   Reply With Quote
Old 16th Apr 2013, 14:20   #10
maRiio
Multimodder
maRiio's Avatar
Haha that was actually my intention but I'm not quite sure if that looks the way I wanted it to. First of all the box will be painted ready on the out- and inside and after finishing that I will decide the color to go with
Old 16th Apr 2013, 15:09   #11
Burnout21
Is the daddy!
Burnout21's Avatar
Vinyl skin the HDD, that way it's not bricked for warranty..
__________________
Project log Mocha70
Old 16th Apr 2013, 20:37   #12
maRiio
Multimodder
maRiio's Avatar
That's also a great idea but I will do a cover for it which can be mounted directly onto the HDD.
BTW: some airbrushing was done by today
I will do a second and a third layer just like that on it tomorrow...
Cheers,
Mario
Old 21st Apr 2013, 17:09   #13
maRiio
Multimodder
maRiio's Avatar
Let me present you the second one of my HDD-cases. I just finished it a few minutes ago and set it up for a quick shoot btw: I will re-use a few of my previous posted pictures to give you a better feel about the process I went through to get to the look it has right now
Unfortunately I did very few pictures during the build of the case. But the one I did I will show you on the following lines...
First of all this was the first layer of polyethylen (the white material ) I did for the start to see how it's gonna look like. The design of the case wasn't planned at all and most of my decisions were totally spontaneous.
(please don't get distracted by the Crysis3-logo. It was planned to be a casemod for Crytek/Crysis but it ended not the way I wanted it to end )
After the base of the front was finished I started to cut all the needed pieces for the rest of the case. Equipped with a heat-gun I started bending all the parts to their final shape. To give it at least a little bit of destructed feel it was time to turn on the dremel (erm... I mean by using the switch on it )
Like mentioned earlier I don't own any more pics of that
The next thing on the list was soldering a led for the hard-drive activity light. Said - Done!
When finished I started airbrushing the base of the case itself (unfortunately you can't see anything of anymore :P). But it was a relaxing and fun task.
And then, yesterday I finsihed the paint for the case. I had two colors in mind, blue and orange. After seeing the case in it's final form I'm more than glad choosing orange over blue since the feel of an old machinery was totally hit (imho).
Then I had to do the painting of the rust. I did the rust on the coners and edges I thought it would appear if some case like this was left out in the rain for many months
After waiting for a day the rust was completey dryed and finished and I startet airbrushing the case to give it a more used look. Additional to the airbrush I used acrylic paint in different colors which I squeezed on the case and wiped it with my fingers
A minor thing was to switch the housing for the activity led. By the way, only one of them (the blue cable one) is showing the harddisk acitiviy, the other one is just for looking purposes
And here's the final end result (of the paint). What's left is the case of the HDD itself and a big smiley face (thanks Jeremy ) on the other side.
Old 21st Apr 2013, 17:14   #14
Pranja
Blackwolf
Pranja's Avatar
Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.
Wow! Amazing airbrush.
You should really make pc mod in same fashion.
Pranja is offline   Reply With Quote
Old 21st Apr 2013, 17:22   #15
Editor22
E22 | Hex-Gear
Editor22's Avatar
Editor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming Saiyan
Utterly stunning MaRiio!! the detail is just brilliant.
PS... how did VeranoX end up? I loved where that was going
__________________
Stores: E22 | HEX GEAR
Social: Youtube | Facebook
Projects: Evolution | K2 MK1 | 21
Editor22 is offline   Reply With Quote
Old 21st Apr 2013, 17:26   #16
KrunchR
Supermodder
KrunchR's Avatar
KrunchR is almost as Godly as yodasarmpitKrunchR is almost as Godly as yodasarmpitKrunchR is almost as Godly as yodasarmpitKrunchR is almost as Godly as yodasarmpitKrunchR is almost as Godly as yodasarmpitKrunchR is almost as Godly as yodasarmpitKrunchR is almost as Godly as yodasarmpitKrunchR is almost as Godly as yodasarmpitKrunchR is almost as Godly as yodasarmpitKrunchR is almost as Godly as yodasarmpitKrunchR is almost as Godly as yodasarmpit
Agreed, a pc mod in the same fashion is a MUST!
Very nice attention to detail.
__________________
SYSTEM ONE on hold for now....
But my KnuckleDuster makes a Return!
For sale! lian li pc7
KrunchR is offline   Reply With Quote
Old 21st Apr 2013, 17:28   #17
maRiio
Multimodder
maRiio's Avatar
Thanks both of you guys, appreciate your kind words.
Maybe I'm planning to do so since I don't own any more hard disk to make a case for
Old 21st Apr 2013, 17:30   #18
KrunchR
Supermodder
KrunchR's Avatar
Get to it!
__________________
Old 21st Apr 2013, 17:34   #19
maRiio
Multimodder
maRiio's Avatar
Ah Editor, I didn't see your post before
Sry to (maybe haha) disappoint you, but VeranoX wasn't going well since the base construction I did for it was a mess I didn't redo it in any way and switched to a TJ07-casemod
Old 21st Apr 2013, 23:03   #20
Editor22
E22 | Hex-Gear
Editor22's Avatar
No worries I'm like a post Ninja
Thats a real shame about VeranoX though still at least you knew when to quit
__________________
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
