Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 15th Apr 2013, 19:39   #1
Poulter
Multimodder
Poulter is almost as Godly as yodasarmpitPoulter is almost as Godly as yodasarmpitPoulter is almost as Godly as yodasarmpitPoulter is almost as Godly as yodasarmpitPoulter is almost as Godly as yodasarmpitPoulter is almost as Godly as yodasarmpitPoulter is almost as Godly as yodasarmpitPoulter is almost as Godly as yodasarmpitPoulter is almost as Godly as yodasarmpitPoulter is almost as Godly as yodasarmpitPoulter is almost as Godly as yodasarmpit
3GB EVGA 660ti FTW+
Hey,
Was wondering if there was a review for the 3GB EVGA 660ti FTW+ card yet anywhere, i can't seem to find one?
Also any other cards that come close to this one in terms of the performance for the price?
Thanks
Poulter is offline   Reply With Quote
Old 15th Apr 2013, 19:57   #2
B1GBUD
More Biddy Bang Bang than Sean Paul
B1GBUD's Avatar
B1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming SaiyanB1GBUD is a Super Spamming Saiyan
Probably a stock 670 might come pretty close, what res will you be gaming at?
__________________
Teh unofficial Bit-Tech proof reader
Originally Posted by Teelzebub View Post
( Kid you dont want either only bud is any good lol )
B1GBUD is offline   Reply With Quote
Old 15th Apr 2013, 20:00   #3
Poulter
Multimodder
Well i was looking to get the dell ultrasharp 24" which i think is 1980x1200?
Old 15th Apr 2013, 20:00   #4
Throbbi
I Mod, Therefore I Own
Throbbi's Avatar
Throbbi is the Cheesecake. Relix smiles down upon them.Throbbi is the Cheesecake. Relix smiles down upon them.Throbbi is the Cheesecake. Relix smiles down upon them.Throbbi is the Cheesecake. Relix smiles down upon them.Throbbi is the Cheesecake. Relix smiles down upon them.Throbbi is the Cheesecake. Relix smiles down upon them.Throbbi is the Cheesecake. Relix smiles down upon them.Throbbi is the Cheesecake. Relix smiles down upon them.Throbbi is the Cheesecake. Relix smiles down upon them.Throbbi is the Cheesecake. Relix smiles down upon them.Throbbi is the Cheesecake. Relix smiles down upon them.
http://hexus.net/tech/reviews/graphi...w-signature-2/
This is, however for the non-Ti version. This is virtually the same card however.
I can't see how it's worth spending that kind of money on a 660Ti, even a super duper version, when for a very small amount more you can just get a 670.
Also lol at F.T.W. - cheesecake bittech autocorrect
__________________
Steam - Throbbi ::WoT -Unpainted_Target ::BF3 - Throbbi
AMD FX-6300-Gigabyte 990AX-UD3-EVGA 660Ti Signature 3GB-Momentus XT-be quiet! E7-600W-Avexir 2x4GB 1600
Share And Enjoy!
Worklog - The Amputer!
Throbbi is offline   Reply With Quote
Old 15th Apr 2013, 20:03   #5
Poulter
Multimodder
That's the none ti version
Old 15th Apr 2013, 20:06   #6
B1GBUD
B1GBUD's Avatar
Are there Ti and non-Ti variants?
Edit: Beaten to it
__________________
Old 15th Apr 2013, 20:07   #7
Throbbi
Throbbi's Avatar
Yeah, edited accordingly
__________________
Share And Enjoy!
Old 15th Apr 2013, 20:08   #8
Poulter
Multimodder
http://www.scan.co.uk/products/3gb-e...-cores-1344-hd
^^ ti
http://www.scan.co.uk/products/3gb-e...37mhz-cores-96
^^ none ti
EDIT: Couldn't find the links fast enough... :P
Old 15th Apr 2013, 20:09   #9
bawjaws
I *am* a Dremel
bawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyanbawjaws is a Super Spamming Saiyan
Pete J posted a good thread about his tri-SLI EVGA 660 ti SC+ 3GB, which are very similar to the F.T.W.+ http://forums.bit-tech.net/showthread.php?t=257709
bawjaws is offline   Reply With Quote
Old 15th Apr 2013, 20:09   #10
B1GBUD
B1GBUD's Avatar
Well the non-Ti doesn't really benefit from having 3GB..... surely a second hand 670 or even a 7950 would be better?
__________________
Old 15th Apr 2013, 20:10   #11
Poulter
Multimodder
http://www.scan.co.uk/savedbasket/35...1bbd89ec250193
The above is the build i have saved atm, if i went for a 670, i would have to change something, i really can only spend 1100 max, anything you would change?
Old 15th Apr 2013, 20:17   #12
dullonien
Master of the unfinished.
dullonien's Avatar
dullonien is a Super Spamming Saiyandullonien is a Super Spamming Saiyandullonien is a Super Spamming Saiyandullonien is a Super Spamming Saiyandullonien is a Super Spamming Saiyandullonien is a Super Spamming Saiyandullonien is a Super Spamming Saiyandullonien is a Super Spamming Saiyandullonien is a Super Spamming Saiyandullonien is a Super Spamming Saiyandullonien is a Super Spamming Saiyan
Can't you get free postage because of bit-tech? Could save you 16.64.
Link to the thread: http://forums.bit-tech.net/showthread.php?t=186923
__________________
Main SilverStone FT03B | Intel i5 2500K@4.0GHz | Corsair H70 | Maximus IV Gene-Z | 16GB DDR3 | Zotac GTX 470 | Corsair HX520 | 500GB HDD | 2 x HP ZR24W Monitors |
Server
Fractal Design Define R5 | Intel Core 2 Quad Q6600 | Corsair H50 | EVGA 680i SLI | 8GB DDR2 | Sapphire HD4870 | Corsair AX750 | HighPoint RocketRAID 2680SGL | 8 x 1.5TB HDD's in RAID5 | 1TB HDD | 500GB HDD |
dullonien is offline   Reply With Quote
Old 15th Apr 2013, 20:19   #13
Poulter
Multimodder
Yep this is true, i would be getting free postage, bringing it just under 1100, was just wondering if there was anything i could get that was better for the same price
Old 15th Apr 2013, 20:32   #14
Throbbi
Throbbi's Avatar
Free delivery from bit-tech for a start which saves 16.64.
Second there 's the same CPU-RAM-MoBo as a bundle in the today only deals for 299.99 which, based on your basket, will save you 12.64. You could save a further 8.40 by taking the bundle which has slower timings on the RAM (11-11-11-30 instead of 9-9-9-24, which in general use/gaming you will never, ever notice).
Third, is the H60 really needed? Are you pushing the overclock to very high levels? The H55 would save another 9-ish or the CM Seidon would save 14.98.
That's a potential 52.66 to play with depending on what you do. Not saying it's not a great build already, it is, just always like to see people get the most that they can.
__________________
Share And Enjoy!
Old 15th Apr 2013, 20:45   #15
Throbbi
Throbbi's Avatar
This is what I came up with
- 670 F.T.W. GPU.
- hybrid modualr Corsair PSU.
- virtually the same cooler
- Better SSD
- 88.20(after taking off the carriage costs) remaining to choose a better case (e.g. Carbide 300R/Fractal Arc Mini etc.)
Just my 2pence worth making the most of today only offers. These guys will be able pick that build apart and see if you can get even more possibly.
EDIT - Even though you can hardly read it thanks to a pants crop/upload lol.
__________________
Share And Enjoy!
Old 15th Apr 2013, 21:07   #16
Poulter
Multimodder
- 670 F.T.W. GPU.
- Better SSD
Wow! Thanks a bunch, thats a hell of alot better than i was getting, for the same price, i think i might stick with the zalman z9+ however, i've heard nothing but amazing reviews about it, and for the price there's not much that can beat it i guess the 670 is alot better than the 660ti
Old 15th Apr 2013, 21:47   #17
Throbbi
Throbbi's Avatar
Just give these guys an hour or so to check on that
__________________
Share And Enjoy!
Old 15th Apr 2013, 22:16   #18
Shirty
Here from the future...
Moderator
Shirty's Avatar
Shirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, Shirty
I'd stretch a little further and go for the Carbide 300R, its a much better case for just over a tenner more.
__________________
3770K | Z77E-ITX | Liqtech 120X | EVGA GTX 980Ti SC | 8GB | 1TB M550 | Node 304 | SS-460FL2 (fanless) | Dell S2740L | Ducky TKL | Logitech G500
I also have a Surface Pro 2, even though I'm not a pro...
Shirty is offline   Reply With Quote
Old 15th Apr 2013, 22:26   #19
Throbbi
Throbbi's Avatar
I can confirm that it's an awesome case by the way.
__________________
Share And Enjoy!
Old 15th Apr 2013, 22:29   #20
Poulter
Multimodder
Why is it better than the z9+ ?
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
