Go Back   bit-tech.net Forums > Misc > General
Reply
Thread Tools View Mode
Old 16th Apr 2013, 15:25   #1
mars-bar-man
Side bewb.
mars-bar-man's Avatar
mars-bar-man is definitely a rep cheat.mars-bar-man is definitely a rep cheat.mars-bar-man is definitely a rep cheat.mars-bar-man is definitely a rep cheat.mars-bar-man is definitely a rep cheat.mars-bar-man is definitely a rep cheat.mars-bar-man is definitely a rep cheat.mars-bar-man is definitely a rep cheat.mars-bar-man is definitely a rep cheat.mars-bar-man is definitely a rep cheat.mars-bar-man is definitely a rep cheat.
What hot hatch for around £7000?
Well people, it's new car time in a few months, and I'm looking at hot hatches.
So far I have looked at:
2007 Corsa VXR
2006 RenaultSport Clio
2004 Mini Cooper S
And, well, that's about it really. At the moment I'm heavily swayed by the Corsa, mostly because I know I fit in them. Any others worth thinking about?
I've got around £1k set aside to cover insurance and tax on top of the £7k for the car. I've been looking at coupe's, but being 6'6" with most of my height in my legs, these aren't really practical. BMW 1 series would be considered, but please no 3 series (I haven't got a wife, 2 kids and a dog just yet).
__________________
Bewbs.
mars-bar-man is offline   Reply With Quote
Old 16th Apr 2013, 15:32   #2
BentAnat
Software Dev
BentAnat's Avatar
BentAnat should be considered for presidentBentAnat should be considered for presidentBentAnat should be considered for presidentBentAnat should be considered for presidentBentAnat should be considered for presidentBentAnat should be considered for presidentBentAnat should be considered for presidentBentAnat should be considered for presidentBentAnat should be considered for presidentBentAnat should be considered for presidentBentAnat should be considered for president
I personally dislike the Corsa. Not the VXR in particular, since I haven't driven one. The normal Corsa just felt rubbish and the seating position was horrid, when I drove one.
The Mini is a solid car, but the ones we get here get quite a few rattles with time. That said - they handle quite well.
The Clio is what I would probably go for.
Or try to get your hands on a Fiat 500 Abarth... :P
__________________
Find Jobs in Namibia
BentAnat is offline   Reply With Quote
Old 16th Apr 2013, 15:36   #3
Margo Baggins
I'm good at Soldering
Moderator
Margo Baggins's Avatar
Margo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming Saiyan
Seating position in my Corsa is crapola. And the steering wheel is not adjustable, even with the seat dropped as low as it will go the wheel is still basically in my lap. And I haven't been able to make the seat comfortable for my lower back without the aid of a cushion. But my corsa is a really rubbish one, so it might be different with the better models.
__________________
My Imgur
Get a Geek Box
i7 3820 4.3ghz - 8GB 2133mhz - GTX 970
keyboards.
Margo Baggins is offline   Reply With Quote
Old 16th Apr 2013, 15:37   #4
mars-bar-man
Side bewb.
The 500 is just a little too 'cutesy' for my tastes personally.
As for the Corsa, personally I felt fine in it. But it's down to personal preference in that regards I suppose.
__________________
Bewbs.
Old 16th Apr 2013, 15:38   #5
Sketchee
Suddenly, looters! Hundreds of 'em!
Sketchee's Avatar
Sketchee - it's over 9000!!!!!!!!1!1!1!!!Sketchee - it's over 9000!!!!!!!!1!1!1!!!Sketchee - it's over 9000!!!!!!!!1!1!1!!!Sketchee - it's over 9000!!!!!!!!1!1!1!!!Sketchee - it's over 9000!!!!!!!!1!1!1!!!Sketchee - it's over 9000!!!!!!!!1!1!1!!!Sketchee - it's over 9000!!!!!!!!1!1!1!!!Sketchee - it's over 9000!!!!!!!!1!1!1!!!Sketchee - it's over 9000!!!!!!!!1!1!1!!!Sketchee - it's over 9000!!!!!!!!1!1!1!!!Sketchee - it's over 9000!!!!!!!!1!1!1!!!
Alfa 147 gta, doesn't get much hotter!
__________________
Fractal R3 | Asus P6X58D-E | i7 930 @ 3.8 | Megahalems & GT1850 | 6gb XMS3 | EVGA 680 SC Sig2 | Toughpower XT 750 | Seagate 600 480gb | Samsung F3 + F2 | Xonar DX | U2410
Sketchee is offline   Reply With Quote
Old 16th Apr 2013, 15:46   #6
mars-bar-man
Side bewb.
About £500 over budget on the insurance sadly. I would love one of them though. Talking of Alfa's, I have been looking at the Brera, because to be frank, that car gets my dick hard.
__________________
Bewbs.
Old 16th Apr 2013, 15:48   #7
BentAnat
Software Dev
BentAnat's Avatar
+1 for the Alfa, provided you can handle a case of alfa-itis (i.e. loads of charisma and loads of issues. It makes you laugh and cry all at the same time).
What about the Punto Abarth? Not sure how available they are over there, but I heard great things about that little thing - especially with the essesse kit, when it apparently pushes right through the Traction Control and backfires like a rally car.
You can tell I prefer Italians, can't you? :P
Of the ones you listed, though - the Renault. Even a hotted up Twingo would ROCK.
Since you looked at Alfas - the MiTo might look a bit girly, but they're MASSIVELY good. 114kw from a 1.4T engine.
Also worth a look (though I am biased, owning one and all) is the T-Jet Fiat Bravo.
__________________
Old 16th Apr 2013, 16:00   #8
mars-bar-man
Side bewb.
Sadly the Punto Abarth is about £3000 above budget. :'(
The Twingo is just too small for me, my legs just won't fit. The MiTo is a lovely car, only ones in budget are quite a low spec sadly. Just looked at the Bravo, it didn't grab me though, the other cars I've looked at stirred something up inside me, Bravo didn't do it for me.
__________________
Bewbs.
Old 16th Apr 2013, 16:24   #9
BentAnat
Software Dev
BentAnat's Avatar
Sucks about the Punto.
The MiTo in different spec is news to me... we ONLY get it in 1.4 turbo Multi Air 114kw.
The Bravo I'd recommend driving. It doesn't look great, and age isn't kind to the looks, but it REALLY is one of the most fun cars I have driven in my life. That's the 110kw T-Jet.
Also, the build quality in mine (MY08) is still better than the build quality in the MY13 Puntos... never mind the older models.
If there's a Bravo Sport or 110kw T-Jet, give it a spin and judge then.
I have owned and driven a LOT of cars at varying price points, and love the Bravo to tiny little bits, more than any other car (save the GT86 that I have on order... but I am only getting that since my Bravo is paid for and I can afford to have two cars).
__________________
Old 16th Apr 2013, 16:27   #10
true_gamer
Cheesecake on sale!
true_gamer's Avatar
true_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyantrue_gamer is a Super Spamming Saiyan
Isn't the Honda Civic a hot hatch?... I would be looking at a VW Golf in that range. The 2.0 GT Sport TDI 170PS has awesome specs! Clicky That is just an example, and I'm sure you could get one with lower mileage.
Spec's:
Now add a re-map to the beast: http://www.celtictuning.co.uk/
So, out of that, you get - Awesome Performance, Awesome fuel consumption, Awesome low insurance = Win!
__________________
i5 4670K @ 4GHz - Corsair H100i - MSI Z87-G45 Gaming Mobo - 16GB Hyper X DDR3 2400MHz - SandDisk Ultra 2 120GB SSD - 500GB SSHD - 2x Asus R9 280X DCU2 - Coolermaster 1KW PSU - NZXT Phantom 530 Case - Philips 40" 4K Monitor BDM4065UC
ORIGIN username: wipeyourarse - Steam ID: true_gamer - UPLAY ID: true_gamer
Crysis 3 Ultra Config Crysis 1 ultra Config
true_gamer is offline   Reply With Quote
Old 16th Apr 2013, 16:35   #11
mars-bar-man
Side bewb.
Looked at the Civic Type-R, insurance is sky high because of it's reputation. Which sucks. I did look at a Mk5 Golf GTI, but the insurance was around the £1200 mark
__________________
Bewbs.
Old 16th Apr 2013, 16:37   #12
Margo Baggins
Moderator
That's what I be paying on my 1L Corsa
__________________
My Imgur
Get a Geek Box
keyboards.
Old 16th Apr 2013, 16:37   #13
true_gamer
Cheesecake on sale!
true_gamer's Avatar
Have you tried this insurance company? Clicky
I insured my Audi A5 with them fully comp, with all the extras (Break down, lost key cover, wrong fuel cover etc...) For £300 for the year.
__________________
Old 16th Apr 2013, 16:41   #14
Krikkit
Super Moderator
Moderator
Krikkit's Avatar
Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.
BMW 130i would be my choice - NA straight 6, rear wheel drive. Otherwise I'd go for the Clio 197 without the Cup packs as they're hilariously fun.
(Actually I'd have a 147GTA I think, but we've already ruled that out!)
__________________
The Good, The Bad, The Ugly, The Zlad!, The Wut?!, The Kempness
Krikkit is offline   Reply With Quote
Old 16th Apr 2013, 16:42   #15
BentAnat
Software Dev
BentAnat's Avatar
The Mk5 GTI I had (MY05) was hard as nails on the road.
It killed my back on anything longer than one hour trips. That was on 17" wheels, not the 18s that you could get with it.
I mainly blame the seats in it.
Civics aren't bad, if you're into that type of thing. I guess I am not.
What about a Polo GTI? the 1.8T
OR - a 2006/7 1.8T Audi A3. I know - you don't think it's a hot hatch, but drop in a simple K&N air filter, and that thing will reliably outrun a Mk5 GTI. It's got better high-speed handling as well (the GTI I had sucked REAL bad to drive at >170kph, which is, admittedly, well above national limits).
Of ALL of them, I'd still try for the Megane (provided you're not interested in the Bravo)
__________________
Old 16th Apr 2013, 16:44   #16
kenco_uk
I unsuccessfully then tried again
kenco_uk's Avatar
kenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyan
Have you looked at any Fiesta ST's? An '08-plate is within your budget: http://www.pistonheads.com/classifie...PriceHighToLow
__________________
formaggio gāteau
kenco_uk is offline   Reply With Quote
Old 16th Apr 2013, 16:44   #17
Da_Rude_Baboon
What the?
Da_Rude_Baboon's Avatar
Da_Rude_Baboon is almost as Godly as yodasarmpitDa_Rude_Baboon is almost as Godly as yodasarmpitDa_Rude_Baboon is almost as Godly as yodasarmpitDa_Rude_Baboon is almost as Godly as yodasarmpitDa_Rude_Baboon is almost as Godly as yodasarmpitDa_Rude_Baboon is almost as Godly as yodasarmpitDa_Rude_Baboon is almost as Godly as yodasarmpitDa_Rude_Baboon is almost as Godly as yodasarmpitDa_Rude_Baboon is almost as Godly as yodasarmpitDa_Rude_Baboon is almost as Godly as yodasarmpitDa_Rude_Baboon is almost as Godly as yodasarmpit
Seat Leon Cupra?
Da_Rude_Baboon is offline   Reply With Quote
Old 16th Apr 2013, 16:44   #18
mars-bar-man
Side bewb.
TG, I'm guessing that could be partly down to your job? Or would that increase it?
__________________
Bewbs.
Old 16th Apr 2013, 16:45   #19
law99
Custom User Title
law99's Avatar
law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.law99 is definitely a rep cheat.
SNIP
+1. Also you don't own a car made by morons. I.e. The French, Vauxhal. Or a quite frankly bound to blow up eventually not quite as well engineered as BMW supercharged mini.
A remap, even a generic one on that VAG will make it v.fast for the eco. Plus, its torque on the motorways will embarrass a lot of people.
Also, there is a lot to be said of the 20 valve turbo engines. My friend gets 40mpg when not driving like a ****. At least, that is what he says he is getting.
__________________
3570k WC @ 4.7giggles | 8gb Kingston 2133mhz | ASUS Sabertooth Z77 | soaking 1070 gtx | Seasonic x-660w | NZXT 810 switch | Crucial M4 128gb | 2x F3 1tb Raid 1 | NZXT Sentry 6ch 50w fan controller | BenQ bl3200pt 2560x1440p
law99 is offline   Reply With Quote
Old 16th Apr 2013, 16:46   #20
BentAnat
Software Dev
BentAnat's Avatar
The Clio 197 and the 130 beemer are both good options, actually.
__________________
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
