Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 23rd Apr 2013, 10:47   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
AMD launches new G-Series family, hints at future ARM chips
Embedded x86 chips kick Atom into touch.
http://www.bit-tech.net/news/hardwar...amd-g-series/1
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is online now   Reply With Quote
Old 23rd Apr 2013, 15:13   #2
Tyinsar
6 screens 1 card since Nov 17 2007
Tyinsar's Avatar
Tyinsar is definitely a rep cheat.Tyinsar is definitely a rep cheat.Tyinsar is definitely a rep cheat.Tyinsar is definitely a rep cheat.Tyinsar is definitely a rep cheat.Tyinsar is definitely a rep cheat.Tyinsar is definitely a rep cheat.Tyinsar is definitely a rep cheat.Tyinsar is definitely a rep cheat.Tyinsar is definitely a rep cheat.Tyinsar is definitely a rep cheat.
I'd like to see AMD use this to compete with Intel's NUC systems.
I don't know why Zotac with all their tiny systems hasn't made a more powerful AMD based one. I'd make my own but FM2 ITX boards are extremely rare (Isn't the compact, integrated, format the point of these?) and I haven't yet seen any with msata.
__________________
Regardless of what you believe there is someone at least as smart, or smarter, than you who believes something you think is stupid (and it's not just because you know something they don't).
Tyinsar is offline   Reply With Quote
Old 23rd Apr 2013, 16:42   #3
schmidtbag
Ultramodder
schmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpitschmidtbag is almost as Godly as yodasarmpit
I wish AMD the best with this platform, it actually sounds realistic, and I like the fact that they're giving Linux attention. I just hope that these are actual dual cores, not single-cores with 2 modules (same goes for the quad core). AMD should do the same for their FX-4XXX series - I'm sure it'd get a noticeable performance improvement if it were 4 physical cores rather than 2 cores per module.
schmidtbag is offline   Reply With Quote
Old 23rd Apr 2013, 16:54   #4
Gareth Halfacree
WIIGII!
bit-tech Staff
It's already possible to buy a last-generation G-series-based development board on the open market: the Gizmo. I've got a couple here: very compact, surprisingly powerful (about 1/20th the single-core performance of my A10-5800K, or 5x the performance of a Raspberry Pi, using the SysBench CPU benchmark and ignoring the GPU) and includes one on-board SATA port and another that can be accessed using a "high-speed port" on the edge of the device - but you'll have to build an adapter to get at that one.
It's Jaguar, which means updated Bobcat - which means the traditional module approach, using two integer units fused to one shared 256-bit FMAC that can operate in 2x128-bit mode as and when required. In other words: if you think AMD's existing processors aren't 'real' dual/quad core parts, then this ain't going to change your mind.
__________________
Old 24th Apr 2013, 04:13   #5
Marquee
Mac Pro Modder
Marquee's Avatar
Marquee is a Super Spamming SaiyanMarquee is a Super Spamming SaiyanMarquee is a Super Spamming SaiyanMarquee is a Super Spamming SaiyanMarquee is a Super Spamming SaiyanMarquee is a Super Spamming SaiyanMarquee is a Super Spamming SaiyanMarquee is a Super Spamming SaiyanMarquee is a Super Spamming SaiyanMarquee is a Super Spamming SaiyanMarquee is a Super Spamming Saiyan
Can any one say mining. Thats really be the only thing on my mind the last couple of days.
Marquee is offline   Reply With Quote
Old 24th Apr 2013, 04:26   #6
Tyinsar
Tyinsar's Avatar
Originally Posted by Gareth Halfacree View Post
It's already possible to buy a last-generation G-series-based development board on the open market: the Gizmo. ...
I remember that from the January (link). That fell a little short and the cost was too high. I'm currently looking at funding this: http://www.kickstarter.com/projects/...y-single-board but that might be a little too DIY for the time I have available.
I'd still like an FM2 ITX (or smaller) board with msata, HDCP HDMI / DisplayPort / DVI, USB3 ...
__________________
Reply
Tags
amd, amd g-series, amd64, apu, arm, atom, embedded processor, g-series, intel, opeteron, soc, system on chip, tegra, x64, x86, x86-64
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
