Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 23rd Apr 2013, 18:34   #1
Meanmotion
bleh
Meanmotion's Avatar
Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.
Dremel launches 8200 Platinum Edition toolkit
Get a Dremel 8200, 65 accessories and carry case for under 180.
http://www.bit-tech.net/news/modding...-diy-toolkit/1
Meanmotion is offline   Reply With Quote
Old 24th Apr 2013, 03:17   #2
Tyinsar
6 screens 1 card since Nov 17 2007
Tyinsar's Avatar
Tyinsar is definitely a rep cheat.Tyinsar is definitely a rep cheat.Tyinsar is definitely a rep cheat.Tyinsar is definitely a rep cheat.Tyinsar is definitely a rep cheat.Tyinsar is definitely a rep cheat.Tyinsar is definitely a rep cheat.Tyinsar is definitely a rep cheat.Tyinsar is definitely a rep cheat.Tyinsar is definitely a rep cheat.Tyinsar is definitely a rep cheat.
Looks like nice kit but my experiences with the 4200 (a corded version of which two lasted one use each) are making me look at more powerful options.
Still, that toolbox looks quite tempting.
__________________
Regardless of what you believe there is someone at least as smart, or smarter, than you who believes something you think is stupid (and it's not just because you know something they don't).
Tyinsar is offline   Reply With Quote
Old 24th Apr 2013, 10:50   #3
johnnyboy700
I *am* a Dremel
johnnyboy700's Avatar
johnnyboy700 is definitely a rep cheat.johnnyboy700 is definitely a rep cheat.johnnyboy700 is definitely a rep cheat.johnnyboy700 is definitely a rep cheat.johnnyboy700 is definitely a rep cheat.johnnyboy700 is definitely a rep cheat.johnnyboy700 is definitely a rep cheat.johnnyboy700 is definitely a rep cheat.johnnyboy700 is definitely a rep cheat.johnnyboy700 is definitely a rep cheat.johnnyboy700 is definitely a rep cheat.
It does look good but its expensive.
I found that the Dremel cut off discs are a bit on the brittle side and oddly the cheap version from Aldi/Lidil were more robust, although the Aldi/Lidil drills and burrs weren't so good.
johnnyboy700 is offline   Reply With Quote
Old 24th Apr 2013, 11:54   #4
aleph31
What's a Dremel?
aleph31 has yet to learn the way of the Dremel
@Tyinsar I'm interested in adquiring a rotary tool, could you please give a recommendation on a more-powerful, reliable / robust alternative? (your comment on two dying after first use has scared the hell out of me)
aleph31 is offline   Reply With Quote
Old 24th Apr 2013, 17:53   #5
aleph31
What's a Dremel?
Nobody wants to give input on better alternatives to dremel? :S
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
