Reply
Thread Tools View Mode
Old 24th Apr 2013, 01:12   #1
quizz_kid
Squid
quizz_kid's Avatar
quizz_kid - may the hammer of Bindi be bestowed on youquizz_kid - may the hammer of Bindi be bestowed on youquizz_kid - may the hammer of Bindi be bestowed on youquizz_kid - may the hammer of Bindi be bestowed on youquizz_kid - may the hammer of Bindi be bestowed on youquizz_kid - may the hammer of Bindi be bestowed on youquizz_kid - may the hammer of Bindi be bestowed on youquizz_kid - may the hammer of Bindi be bestowed on youquizz_kid - may the hammer of Bindi be bestowed on youquizz_kid - may the hammer of Bindi be bestowed on youquizz_kid - may the hammer of Bindi be bestowed on you
R-KAID-Я (15/5 Zero margins)
Let me present "R-KAID-Я", the handheld arcade unit. Iīve been sketching on it for some time now, and itīs finally time for execution. You probably all know I love old school gaming by now, and while R-KAID-Я might not be small and mobile as a DS or a Vita, it will be an interesting competitor with classic joystick+button layout, storage, flexibility and of course, amazingly good looks!
That being said, itīs still not a simple task to make everything fit in there. The console measures 28x18x9cm, which means I have to plan everything well.
Although some might think Iīm monotonous when it comes to materials, Iīll be using walnut and brass, simply because that is one hell of a combination, a classic.
It will store a self booting game library of over 20.000 emulated classic game titles
This little machine will aslo have some other really nice and unique features, but more about that as I process...
It will be build sort of like a casket, with a base unit housing most of the HW, and a top piece with display and speakers.
Before I let you in on the ingredients, I just want to thank VIA embedded and Kingston for their support.
Ok, so here are the guts:
Kingston 120gb ssd and so-dimm 4gb
And here is the little board that makes this project possible, the EPIA P910 from VIA Embedded.
Itīs a tiny monster! The board measures only 10x7cm, but has an 64-bit VIA QuadCore E-Series processor. Iīve attached 4x 25mm spacers, this is for mounting it under a panel.
And hereīs whats going to supply the console with current, a 12v rechargeable Lithium-ion battery with 8000mAh. To make it work proper Iīll use that brick to the left, a DC-DC 12V 6A step-up&down converter.
And hereīs the display Iīm going to use, an 8" LCD screen with controller board.
Some things for the gamepad, a small solderless controller PCB...
... and some nice black Sanwa push buttons. Youīll notice thereīs only eight of them in the picture. The ninth is going through some modifications right now. Iīll tell you more about that later.
The push buttons are also going to get a facelift, and for that Iīll use these curtain rings in solid brass.
This is the joystick. To make it fit when the casket is closed I have to make some modifications. A simple solution actually, I just cut the shaft in half More about this later...
This is the speaker Iīll be using, a tiny 50mm element.
To have a proper signal link between base and top I first had to count the signals needed. 12 for VGA, 2 for LCD power and another 5 signals for audio+volume knob. I had an old flat IDE cable laying around and decided to use that for connection. Just strip it down and use the amount of signals needed
Finally, i found this slightly convex glass that I might use with the LCD to make it look more like a retro CRT monitor.
And some process so far:
Cut some pieces of solid walnut
I wanted to use the laser cutter for some finer details, but it can only cut through 4mm, so I had to prepare the pieces by removing some material from the back.
I aslo made the two panels. For the top I used 6mm MDF. The base panel have to be slighly thicker due the the amount of pounding itīll get when playing Track&Field so I used 10mm for that one. Walnut veneer onto that!
These where also going into the laser cutter, so some material removing here as well.
Preperations done!
First the panels...
Then onto the side pieces of solid walnut.
I made some ornament cutting on the sides for small vents. The left over piece below is quite striking. You shouldnīt be able to make these kind of things out of solid wood. Iīm amazed!
The boxes are glued under pressure.
Veneering time again. In this picture you can see the ornament vent... Quite classy!
This is a 9mm brass rod...
... and this is the joystick shaft I told you about in the introduction.
I cut it, made a hole for an M6 thread and made the docking shaft piece from brass with threads on both sides. Made two of them for fun, while I was at it.
Laptops uses tiny hinges with friction for the right amount of resistance, and I needed something similar. But I couldnīt find something that suited my needs, so I decided to try making the hinges myself. I wanted to controll the amount of friction and came up with an idea using that 9mm brass rod I had laying around. More about this later.
And this is the locking mechanism. Iīm going into the details about this feature later, but here are some pictures...
Well, thatīs it for know. I hope youīll like it! Sorry for the picture quality, I blame it on the phone.
I want to give a big thank you to the people here on Bit-tech who helped me out regarding the use of Lithion batteries.
/ Quizz
__________________
Tempel / Revelation / The Shrine / REDELUX / 4M
Follow me on facebook or Instagram
https://www.facebook.com/lovehultenau
@lovehulten
quizz_kid is offline   Reply With Quote
Old 24th Apr 2013, 04:00   #2
Furball Zen
Shut up and Mod
Furball Zen's Avatar
Furball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run CrysisFurball Zen can run Crysis
Dude?!!!! Would you just stop already??? LOL
__________________
Life. Liberty. The pursuit of those who oppose it.
Guides: Modular PSU ~ FC foam removal Mods: Blue on Black ~ DVD-ROM Worklog: Acronymus ~ Carbide
@furballzen ~ Admin at Xoxide Forums
Furball Zen is offline   Reply With Quote
Old 24th Apr 2013, 09:25   #3
Ocelot
Multimodder
Ocelot's Avatar
Ocelot is a Super Spamming SaiyanOcelot is a Super Spamming SaiyanOcelot is a Super Spamming SaiyanOcelot is a Super Spamming SaiyanOcelot is a Super Spamming SaiyanOcelot is a Super Spamming SaiyanOcelot is a Super Spamming SaiyanOcelot is a Super Spamming SaiyanOcelot is a Super Spamming SaiyanOcelot is a Super Spamming SaiyanOcelot is a Super Spamming Saiyan
Man, this is awesome!
Really cool concept. It must have taken a lot of research and time to get all the components together. What do you estimate the battery life will be like?
Impressive wood working skills and workshop too.
Ocelot is offline   Reply With Quote
Old 24th Apr 2013, 09:44   #4
Pranja
Blackwolf
Pranja's Avatar
Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.Pranja is the Cheesecake. Relix smiles down upon them.
It is allready awesome project.
Pranja is offline   Reply With Quote
Old 24th Apr 2013, 09:48   #5
Waynio
Relaxing
Waynio's Avatar
Waynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming SaiyanWaynio is a Super Spamming Saiyan
Awesome to see another quizz project on the go, handheld arcade system in the awesome quizz_kid retro styling, woo hoo.
Nice progress already.
__________________
Corsair AX860i - GA-Z97MX-Gaming 5 - i5-4690k - Noctua NH-D14 - 8GB DDR3 - GTX 980 Ti - Win 10
40" 4k Samsung TV - Corsair K70 - Corsair M65
Waynio is offline   Reply With Quote
Old 24th Apr 2013, 18:20   #6
Darkwisdom
Level 99 Retro Nerd
Darkwisdom's Avatar
Darkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming SaiyanDarkwisdom is a Super Spamming Saiyan
Ah! Another one already? Does your brain ever switch off thinking about these projects?
I love the idea but... how much charge will you even get from a 8000mah battery? Also; that dinky motherboard is awesome. I'm assuming it'll play things like NES and SNES games. I can't see this playing N64 games.
__________________
Main Rig: i3 3220 ~ GTX 970 Strix ~ 8GB Vengeance Ram ~ EVGA Supernova G2 750W ~ P8H77-m le ~ Samsung 830 128GB SSD ~ Steelseries GCv2 ~ Razer imperator ~
Darkwisdom is offline   Reply With Quote
Old 25th Apr 2013, 18:10   #7
quizz_kid
Squid
quizz_kid's Avatar
NEVER! =)
Thanks Ocelot! Yes, the layout took some time to design. I have never worked with this kind of batteries before, but the board does 30w at average load, so with 8000 mAh Iīm aiming at 6 hrs, at least.
Thanks a lot Pranja. Especially for all the help pre-wise.
Thanks Waynio! Why take a break while Iīm in such a creative flow =)
My brain works in strange ways. It would probably explode if I didnīt have projects shooting out of my ass 247...
As I mention above, Iīm hoping for at least 6 hrs of gaming with that battery. Shouldnīt be an issue there, hopefully.
I havenīt tested it fully, but I shouldnīt expect N64 running smothly. But itīs good enough for most of the MAME games, exept some of the 3D games that are more demanding I guess.
Update:
Here are the panels after laser cutting... Since Iīm going to stain them dark later, I donīt have to do anything about that burned wood along the cuts.
And here is that ninth button a was talking about before. Lets see if anyone can point out the purpose of the small brass piece inserted under the push button.
Hinges dissected. They come in two parts, one with an M3 thread.
Hinges assembled. I must say Iīm very proud over these. They work AND they look good. You adjust the friction simply but tighten or loosen the M3 screw. Small 7mm o-rings in between.
Iīve learned some minor metal work as youīve noticed. Itīs great fun!! Canīt wait to dig deeper into this area
__________________
@lovehulten
Old 25th Apr 2013, 20:25   #8
Waynio
Relaxing
Waynio's Avatar
Man that's an awesome quote.
Very nice hinges.
__________________
Old 25th Apr 2013, 21:34   #9
AlienwareAndy
Banned
AlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming SaiyanAlienwareAndy is a Super Spamming Saiyan
It looks like a Victorian laptop..
I effing love it !
AlienwareAndy is offline   Reply With Quote
Old 26th Apr 2013, 17:40   #10
quizz_kid
Squid
quizz_kid's Avatar
Very nice hinges.
Thanks W!
I effing love it !
Well, the victorian era had a lot of beauty, so thanks!
__________________
@lovehulten
Old 26th Apr 2013, 21:42   #11
Darkwisdom
Level 99 Retro Nerd
Darkwisdom's Avatar
Are we thinking of using that button with the brass piece for a momentary switch; say a power button perhaps.
__________________
Old 27th Apr 2013, 04:41   #12
quizz_kid
Squid
quizz_kid's Avatar
The push buttons are momentary to start with =) So no, we are not thinking power button here.
__________________
@lovehulten
Old 27th Apr 2013, 09:56   #13
woody_294
Wizard Ninja :P
woody_294's Avatar
woody_294 is the Cheesecake. Relix smiles down upon them.woody_294 is the Cheesecake. Relix smiles down upon them.woody_294 is the Cheesecake. Relix smiles down upon them.woody_294 is the Cheesecake. Relix smiles down upon them.woody_294 is the Cheesecake. Relix smiles down upon them.woody_294 is the Cheesecake. Relix smiles down upon them.woody_294 is the Cheesecake. Relix smiles down upon them.woody_294 is the Cheesecake. Relix smiles down upon them.woody_294 is the Cheesecake. Relix smiles down upon them.woody_294 is the Cheesecake. Relix smiles down upon them.woody_294 is the Cheesecake. Relix smiles down upon them.
Looks like it's gonna be the volume knob? Great concept!
__________________
X3 720 BE @3.5GHz - MSI 790FX-GD70 - XFX 4870 XXX @ 795/995 - 4GB Corsair XMS3 1333MHz
http://www.cpcff.co.uk
Project λ-Zephyr
woody_294 is offline   Reply With Quote
Old 28th Apr 2013, 17:50   #14
quizz_kid
Squid
quizz_kid's Avatar
Well it aint a volume knob =) Would be a nice idea though
__________________
@lovehulten
Old 28th Apr 2013, 19:54   #15
kelmannen
Supermodder
kelmannen has yet to learn the way of the Dremelkelmannen has yet to learn the way of the Dremelkelmannen has yet to learn the way of the Dremelkelmannen has yet to learn the way of the Dremel
friggin sweet! love your classic style!
ps. if you need some "special tool" i might be able to fix it, working for Ahlsell if you know that company...
__________________
Works as a tool retailer, glad if i can help someone with tool questions!
Hopes that i someday completes my first scratchbuild...
kelmannen is offline   Reply With Quote
Old 28th Apr 2013, 23:15   #16
quizz_kid
Squid
quizz_kid's Avatar
Thanks friend!
I kinda know Ahlsell, supplier of all kinds of tools and other stuff. Thank you for offering your help, thatīs very thoughtful. Donīt know if Iīm in need of anything special right now, but Iīll let you know if... Do they have a catalogue or something?
__________________
@lovehulten
Old 29th Apr 2013, 18:48   #17
kelmannen
Supermodder
Thanks friend!
ahlsell.se then click on catalogues
__________________
Old 1st May 2013, 13:30   #18
quizz_kid
Squid
quizz_kid's Avatar
Do I have to order them? Canīt seem to find any online ones. Does Ahlsee by any chance have drill sets like these?
__________________
@lovehulten
Old 2nd May 2013, 12:53   #19
Asouter
Asouter's Avatar
Asouter is definitely a rep cheat.Asouter is definitely a rep cheat.Asouter is definitely a rep cheat.Asouter is definitely a rep cheat.Asouter is definitely a rep cheat.Asouter is definitely a rep cheat.Asouter is definitely a rep cheat.Asouter is definitely a rep cheat.Asouter is definitely a rep cheat.Asouter is definitely a rep cheat.Asouter is definitely a rep cheat.
Another cool project squid, I'm still trying to get my head around the bits of hardware. It's definitely not a run of the mill project, you're my kind of loon. Watching with interest
__________________
Finished Projects : D33P THOUGHT : THING : Mini Moto Mayhem
Current Project : BITZA
Asouter is offline   Reply With Quote
Old 2nd May 2013, 23:14   #20
quizz_kid
Squid
quizz_kid's Avatar
Thank man! Iīm just trying something new, which means Iīm a bit confused about the bitsīnīpieces going into this as well =)
Small update
Drilled all the holes for the controller panel.
And made a 35mm volume knob.
I had to make it 5mm thin because of the margins when the damn thing is closed.
__________________
@lovehulten
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
