Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 26th Apr 2013, 09:59   #1
Meanmotion
bleh
Meanmotion's Avatar
Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.
What is the best 720-750W Power Supply?
We put eight 720-750W PSUs through their paces to separate the champs from the chumps.
http://www.bit-tech.net/hardware/psu...psu-720-750w/1
Meanmotion is offline   Reply With Quote
Old 26th Apr 2013, 10:56   #2
aleph31
What's a Dremel?
aleph31 has yet to learn the way of the Dremel
My conclusion is that the Seasonic X-Series 750W is the best all-rounder, isn't it?
aleph31 is offline   Reply With Quote
Old 26th Apr 2013, 11:43   #3
KayinBlack
Terminal is a state of mind
KayinBlack's Avatar
KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.KayinBlack is definitely a rep cheat.
The XFX is the same physical PSU design, but it's cheaper. Ergo, win.
__________________
I don't feed the trolls...
PC: Intel i7-4830K, ASUS X79 Deluxe, 64GB GEiL Golden Dragon 1333MHz RAM, EVGA nVidia Titan Black 6GB Hydro Copper, Blu-Ray burner, 4x250GB Samsung 840 EVO in RAID 10, Corsair AX860i.
KayinBlack is offline   Reply With Quote
Old 26th Apr 2013, 11:46   #4
xela333
Minimodder
xela333 has yet to learn the way of the Dremel
Agreed, the XFX is the way to go. They use Seasonic for all their PSU's. I always recommend them at work now.
xela333 is offline   Reply With Quote
Old 26th Apr 2013, 11:53   #5
GeorgeK
Oooh purple
Moderator
GeorgeK's Avatar
GeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming Saiyan
That was my thought having had a read through - interesting that it doesn't get an award despite getting the same score as the "PC Power & Cooling" supply (which I wouldn't put anywhere near my rig tbh)
I've recently bought a Seasonic X-Series and was tempted by the, physically identical but cheaper, XFX but I've heard bad things about their customer service and decided that as the Seasonic I bought was on offer, and as such was only slightly more than the XFX, I would go for the Seasonic - it's an excellent PSU and I don't regret it in the slightest
GeorgeK is offline   Reply With Quote
Old 26th Apr 2013, 11:58   #6
rollo
I Mod, Therefore I Own
rollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyanrollo is a Super Spamming Saiyan
Brought the XFX myself a few years back now not had a problem with it since, ( brought it with my i7950 mobo and chip so we are talking 3 years give or take now )
100% stable with having had 2 580s and now 2 680s + the watercooling pump and stuff all connected.
Seasonic is the exact same psu but seasonic has slightly better customer service.
rollo is offline   Reply With Quote
Old 26th Apr 2013, 12:06   #7
Shirty
Here from the future...
Moderator
Shirty's Avatar
Shirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, Shirty
What always makes me chuckle is that so many PC builders go for premium 750W or higher PSUs despite the fact that they will only ever be powering a single CPU & GPU rig with a handful of hard drives and a few fans.
One of the very reasons I have "downgraded" to a 550W unit - for my uses I would have seen no benefit in spending more than £50 - none whatsoever. So far in real world usage I haven't seen the rig pull more than 350W. I could probably just about have gotten away with a decent 430W to be honest, but I'm wary that overclocking might have been pushing that too far in extreme circumstances.
__________________
3770K | Z77E-ITX | Liqtech 120X | EVGA GTX 980Ti SC | 8GB | 1TB M550 | Node 304 | SS-460FL2 (fanless) | Dell S2740L | Ducky TKL | Logitech G500
I also have a Surface Pro 2, even though I'm not a pro...
Shirty is offline   Reply With Quote
Old 26th Apr 2013, 12:56   #8
David
RIP Tel
David's Avatar
David is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming SaiyanDavid is a Super Spamming Saiyan
If I had to buy a new PSU, I'd be looking at 550W too, and I wouldn't consider spending more than £60-£65. Look at the premiums for the high efficiency PSUs - it will take you YEARS to recover the difference in price over a decent Bronze PSU; unless you're folding 24/7.
I understand some people want to leave room for the possible inclusion of a 2nd GPU, but most of people with fairly modern gear won't use more than 350W-400W. I ran an X58 rig with a dual GPU GTX 295, both CPU and GPUs heavily overclocked, and it didn't trouble my 700W Realpower PSU. My 2500k and 670 don't breach 350W when overclocked and stressed.
__________________
Before you judge a man, walk a mile in his shoes; after that, who cares?! He's a mile away and you've got his shoes!
Main rig - 6700K|Z170i Pro|16GB|256GB M.2|500GB SSD|GTX 980|3007WFP-HC|Hadron Air
David is offline   Reply With Quote
Old 26th Apr 2013, 13:54   #9
capmoq
Minimodder
capmoq has yet to learn the way of the Dremel
No Corsair PSU? Come on :|
capmoq is offline   Reply With Quote
Old 26th Apr 2013, 14:26   #10
pbryanw
Multimodder
pbryanw has yet to learn the way of the Dremel
I think the only reason I spend more on PSUs is that the expensive ones also tend to be the quietest (Seasonic, Be Quiet!). And I've also downgraded to a 550W unit after previously owning a more-wattage-then-I-needed PSU.
Also, great article - thanks for the roundup Bit-tech.
pbryanw is offline   Reply With Quote
Old 26th Apr 2013, 15:30   #11
MightyBenihana
Do or do not, there is no try
MightyBenihana's Avatar
MightyBenihana is definitely a rep cheat.MightyBenihana is definitely a rep cheat.MightyBenihana is definitely a rep cheat.MightyBenihana is definitely a rep cheat.MightyBenihana is definitely a rep cheat.MightyBenihana is definitely a rep cheat.MightyBenihana is definitely a rep cheat.MightyBenihana is definitely a rep cheat.MightyBenihana is definitely a rep cheat.MightyBenihana is definitely a rep cheat.MightyBenihana is definitely a rep cheat.
100% agree. Corsair are one of the most commonly used and recommended PSUs and they have been admitted from this test?!
I understand that they may not have sent you a sample to test but I can't believe that you don't have one lying around.
I have seen this a few times with BT round ups - where the most common and popular models have been omitted.
MightyBenihana is offline   Reply With Quote
Old 26th Apr 2013, 15:38   #12
David
RIP Tel
David's Avatar
I'm not sure how it works but, if BT are planning a feature, don't they contact all the usual suspects for review samples? Maybe Corsair didn't ship any, or they were late?
__________________
Old 26th Apr 2013, 15:50   #13
Adnoctum
Kill_All_Humans
Adnoctum's Avatar
Adnoctum should be considered for presidentAdnoctum should be considered for presidentAdnoctum should be considered for presidentAdnoctum should be considered for presidentAdnoctum should be considered for presidentAdnoctum should be considered for presidentAdnoctum should be considered for presidentAdnoctum should be considered for presidentAdnoctum should be considered for presidentAdnoctum should be considered for presidentAdnoctum should be considered for president
My conclusion is the best PSU is the Seasonic X-Series. The extra isn't that much, you get more warranty, and you get Seasonic support instead of XFX. You may get Seasonic build quality with the XFX, but you get XFX support too.
Look at it a different way, you are paying 13 quid for 2 years extra warranty and Seasonic service support. Worth it.
Is 7 years warranty excessive and useless?
Tell that to my PC Power & Cooling Silencer 750w, 6 years (and 12mths out of warranty) and still chugging strong in an enthusiast-class machine. Dependable and inaudible at heavy loads, why would I "upgrade" any time soon? A high-quality PSU will easily outlast several generations of more ephemeral hardware like CPUs, GPUs, and MBs.
__________________
Main Rig: Amiga A1200 - Motorola 68EC020@14.2MHz + 68030@50MHz Acc. Card - Lisa Graphics - 2+8MB RAM - 80MB HDD
LAN Rig: Amiga A500 - Motorola 68000@8MHz - Denise Graphics - 512+512KB RAM
Adnoctum is offline   Reply With Quote
Old 26th Apr 2013, 17:30   #14
Tangster
Butt-kicking for goodness!
Tangster's Avatar
Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.Tangster is definitely a rep cheat.
Quite happy that my Dark Power Pro still holds up nicely. I'd quite happily use a lower power 550 or 600W PSU, but I originally bought the BeQuiet for an overclocked i7 950 rig, which enjoyed sucking power like vampires like blood.
__________________
The Box:i7 2700K@5.3GHz|EK Supreme LT+Coolstream XT 360|16GB HyperX DDR3@1866MHz|EVGA GTX780 ti+EK FC780ti|MSI P67A-GD55||M5 512|BeQuiet Dark Power Pro 750W|U3011|Raven RV-02E|KBT Pure+Perixx MX2000 + Intuos 4M
Audio: PC->TosLink->TEAC UD-501->Fostex TH600|InEar LivePro 3|Truth B2030A Monitors
BT Feedback
Tangster is offline   Reply With Quote
Old 26th Apr 2013, 18:16   #15
AiA
Multimodder
AiA has yet to learn the way of the Dremel
my Be Quiet and Corsair (about 650W, and 550W) are still working nicely after a few years now
AiA is offline   Reply With Quote
Old 26th Apr 2013, 19:29   #16
Gradius
IT Consultant
Gradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for presidentGradius should be considered for president
I got myself 2x AX850. Corsair indeed is uber common. You guys really NEED to do a review with Corsair too.
Gradius is offline   Reply With Quote
Old 26th Apr 2013, 20:11   #17
Zaim
Supermodder
Zaim's Avatar
Zaim should be considered for presidentZaim should be considered for presidentZaim should be considered for presidentZaim should be considered for presidentZaim should be considered for presidentZaim should be considered for presidentZaim should be considered for presidentZaim should be considered for presidentZaim should be considered for presidentZaim should be considered for presidentZaim should be considered for president
I'm quite surprised there is no Corsair psu in that test. Imo the best 750w psu is the AX series, reviews speak for themselves.
I wouldn't touch xfx psus as their support is terrible.
Sent from my HTC One X using Tapatalk 2
__________________
CPU:Intel I7 3770K 5GHZ |CPU Cooler:Noctua NH D14|RAM:16GB Corsair Vengeance White LP|MB:Asus P8Z68-V PRO/GEN3|GPU:Asus GTX 980 Strix OC|PSU: Corsair AX 750|HDD:2x Corsair 240GB Force GS| 2X WD 2TB Red|Sound Card:Asus Xonar Phoebus|Speakers:Sony STR-DH820+Yamaha Speakers+Tannoy TS2.10|Mouse/Keyboard:Corsair K95/M95|Case:Corsair 500R|
Zaim is offline   Reply With Quote
Old 26th Apr 2013, 21:40   #18
The_Crapman
MD of M.Z.A. Inc and Weasel Pimp
The_Crapman's Avatar
The_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming SaiyanThe_Crapman is a Super Spamming Saiyan
Pffft. Your puny weakling PSU's are a pathetic insignificance. Everyone knows that anything under 1Kw isn't worth having.
__________________
i5 3570K@4.4, ASRock Z77 Extreme4, EVGA GTX 970 Cheesecake@1517/7700, 8GB Kingston HyperX Fury 1866MHz CL10, Enermax Revolution 1050W, Samsung 840 EVO 120GB , Fractal Arc Midi R2, Dell U2412M, CM Rapid-i w/Browns, R.A.T. 7, Kingston HyperX Cloud
XSPC Twin DDC Dual Bay Res, 2x Laing DDC-1T Plus, Alphacool NexXxoS XP≥ Light, Alphacool NexXxoS NVXP GTX760 Full Cover Copper Block, Alphacool Heatmaster II, 2x 240mm Alphacool ST30, 5x
Xigmatec CLF 120mm LED Fans
The_Crapman is offline   Reply With Quote
Old 26th Apr 2013, 22:57   #19
Nexxo
Whatever's Geek.
Nexxo's Avatar
Nexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming SaiyanNexxo is a Super Spamming Saiyan
PC Power & Cooling is supposed to have a really solid reputation, but mine was the only PSU I've ever owned that literally went up in smoke.
__________________
In memory of Kidmod-Southpaw (1997 - 2014), Teelzebub (1955 - 2016) and Waynio (1978 - 2016)
"We are the music makers; we are the dreamers of dreams"
Current project: Metaversa 02 Ada.
Nexxo is online now   Reply With Quote
Old 26th Apr 2013, 23:20   #20
leslie
Just me!
leslie's Avatar
leslie has yet to learn the way of the Dremelleslie has yet to learn the way of the Dremel
{cut}
Agreed, on modern systems, we don't need as much power as we used to, but you can go too far and regret it later. As you get down at lower wattages, you do have to start being careful of what rails that power is coming from. It's safer and easier to just over buy, which leaves you head room for upgrades later should you need it, but I do agree, many today are over buying, especially for basic office systems.
As for never seeing one break 350watts...
Dig up an old Pentium 4 805D, these were the first chips where you could hit 4gigs without exotic cooling. Though considering that they can push 240 watts from the cpu alone when overclocked that high, you need a heck of a PSU and cooling system. Combine that with the right video card and you are right at 350 watts just about at idle.
Mine was pulling well over 400 watts from the power supply under load (without SLI), when the 550 watt PSU, the UPS and the water pump all decided it was just too much. Which is why I now have 6 year old, 750 watt PSU in my box.
They had a fantastic reputation before they were bought out. They are still good, just not as good as they once were. Even then though, there is always faulty ones.
My (pre buyout) Silencer 750 is over 6 years old (possibly 7 or 8) and still powers the overclocked 2600k in my desktop. I consider it one of the best investments I ever made in computing.
__________________
When in doubt, wear red. - Bill Blass
leslie is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
