Reply
Thread Tools View Mode
Old 28th Apr 2013, 06:00   #1
TheGreatSatan
Dark Lord of BT!
TheGreatSatan's Avatar
TheGreatSatan is definitely a rep cheat.TheGreatSatan is definitely a rep cheat.TheGreatSatan is definitely a rep cheat.TheGreatSatan is definitely a rep cheat.TheGreatSatan is definitely a rep cheat.TheGreatSatan is definitely a rep cheat.TheGreatSatan is definitely a rep cheat.TheGreatSatan is definitely a rep cheat.TheGreatSatan is definitely a rep cheat.TheGreatSatan is definitely a rep cheat.TheGreatSatan is definitely a rep cheat.
Saint Louis Cardinals theme case! - COMPLETE! 6/11
A Mod for my Wife!! She is a Mega Fan!
The case I'm using is the Fractal Design Arc Midi
I need to tear it down for painting. The first to go is one of the drive bay cages. I will not be putting it back in either because I'll only have two drives and there's room on the bottom
Next, comes everything else that's not part of the base steel frame
Can you believe this thick filter was on the top? Why the hell would they use such a thick filter over an exhaust fan??
The front comes off too with it's lone fan
There she is....the frame
I start painting with a light red coat
The front and top mesh pieces are painted white
and the front and top panels are painted red
Once dry, I reassemble the top without the thick mesh filter
The front will obviously have a mesh filter, so that's where I start
There will be two 140mm intake fans
under the completed bezel
I need to paint the panel controls and ports area too
And put it back on the case
Once the frame is dry, all the fans and accessories go back in
Now that the top panel and front bezel are on, they go back on the case
I added a matching DVD burner
The right panel finally gets its top coat
__________________
2011-3 WET DREAM MACHINE
MountainMods U2-UFO with an Intel i7 5960x (8-Core), MSI X99S-SLI, 32GB (4GB x 8) DDR4, 960GB Crucial M500, 1TB Samsung 850 Pro, 240GB Sandisk Extreme, Corsair AX1500i 80 Titanium, GTX Titan X, a Corsair H80i and 15 Green LED Coolmax fans!
TheGreatSatan is offline   Reply With Quote
Old 28th Apr 2013, 08:33   #2
Kovoet
I Mod, Therefore I Own
Kovoet's Avatar
Kovoet is a Super Spamming SaiyanKovoet is a Super Spamming SaiyanKovoet is a Super Spamming SaiyanKovoet is a Super Spamming SaiyanKovoet is a Super Spamming SaiyanKovoet is a Super Spamming SaiyanKovoet is a Super Spamming SaiyanKovoet is a Super Spamming SaiyanKovoet is a Super Spamming SaiyanKovoet is a Super Spamming SaiyanKovoet is a Super Spamming Saiyan
Looking go so far. What size logo you going to use
__________________
MOBO[ Asus Maximus Formula VII ]CPU[I7 4770K]RAM[Corsair Vengeance PRO Red 2133mhz]SSD's[1TB Samsung EVO, 256GB Samsung, 128GB Mushkin, 128 GT Corsair]GPU[EVGA GTX980]PSU[Corsair AX1200i Red Cables]CASE[Corsair 540] Cooler[Corsair H100i]Screen[Dell U2913WM} Perp[Corsair K70, Logitech G502,Belkin razer N52TE,
HyperX Cloud II]
Kovoet is offline   Reply With Quote
Old 28th Apr 2013, 18:34   #3
flame696
Terminating People Since 1980....
flame696's Avatar
flame696 is a Super Spamming Saiyanflame696 is a Super Spamming Saiyanflame696 is a Super Spamming Saiyanflame696 is a Super Spamming Saiyanflame696 is a Super Spamming Saiyanflame696 is a Super Spamming Saiyanflame696 is a Super Spamming Saiyanflame696 is a Super Spamming Saiyanflame696 is a Super Spamming Saiyanflame696 is a Super Spamming Saiyanflame696 is a Super Spamming Saiyan
Great work always look forward to your builds. Have a few questions regarding paint,
1. How many coats do you apply?
2. Do you wet sand in between coats?
3. Also do you use lacquer??
Only need to know as you paint finish is always fantastic
__________________
flame696 is offline   Reply With Quote
Old 28th Apr 2013, 22:36   #4
TheGreatSatan
Dark Lord of BT!
This new paint has paint and primer in one, so three.
Yes, about 2000 grit
No
__________________
Old 29th Apr 2013, 03:56   #5
TheGreatSatan
Dark Lord of BT!
I just slapped a BIG decal on the right side because that's what the wifey wants.
It looks good anyway
and then I started painting left side and ran out paint!!
__________________
Old 29th Apr 2013, 05:24   #6
TheGreatSatan
Dark Lord of BT!
I intend to use the other 5.25 bay for a light controller. The NZXT Hue is great little toy, but it's not gonna match like this
So I strip it down to the core components
The top piece, which is the largest will be white. The under layer will be red, when I get more paint...
__________________
Old 29th Apr 2013, 18:58   #7
TheGreatSatan
Dark Lord of BT!
I got the Specs lined up:
i5 3570K
Asrock Z77 Extreme 6
EVGA GTX 580 DS Superclocked
8GB DDR3-1866 Corsair Dominator Platinum & OCZ Vertex 3 240GB
Corsair H110 Cooler
__________________
Old 29th Apr 2013, 21:53   #8
flame696
flame696's Avatar
does the paint not chip and will it be durable without lacquer? Sorry for the questions.... Lovely build though
__________________
Old 29th Apr 2013, 21:57   #9
GregTheRotter
GregTheRotter's Avatar
GregTheRotter is the Cheesecake. Relix smiles down upon them.GregTheRotter is the Cheesecake. Relix smiles down upon them.GregTheRotter is the Cheesecake. Relix smiles down upon them.GregTheRotter is the Cheesecake. Relix smiles down upon them.GregTheRotter is the Cheesecake. Relix smiles down upon them.GregTheRotter is the Cheesecake. Relix smiles down upon them.GregTheRotter is the Cheesecake. Relix smiles down upon them.GregTheRotter is the Cheesecake. Relix smiles down upon them.GregTheRotter is the Cheesecake. Relix smiles down upon them.GregTheRotter is the Cheesecake. Relix smiles down upon them.GregTheRotter is the Cheesecake. Relix smiles down upon them.
Why the 580? Did you have it sitting spare?
__________________
Main rig: i5 4670k, 8gb 1600mhz ram, Asus Z87-A, Crucial m4 250gb SSD 2 x EVGA GTX 670 in SLI, Dell U2711, Nec 20WGX2, Asus VG248 24" 144hz monitor
Photography gear; Nikon D700, Nikon 24-70 AF-S, Nikon 70-200 F2.8 VR II, Nikon 35mm F2 D,Nikon 50mm 1.8D, Nikon 85mm 1.8D, Micro Nikkor 105 f2.8 AI-S, Nikon SB-900,
GregTheRotter is offline   Reply With Quote
Old 29th Apr 2013, 23:40   #10
TheGreatSatan
Dark Lord of BT!
I did have a spare. My wife will use this machine maybe once a week for an hour tops to print coupons!! I thought a 580 would be hilarious!
Should I have given it away here instead??
I never do a clear coat. I've never had a problem with the paint chipping and shiny cases don't do it for me
__________________
Old 1st May 2013, 00:23   #11
TheGreatSatan
Dark Lord of BT!
I picked up some more red paint for the mesh
And then reassembled the panel
Then I painted some thumb screws to match
Now the bays are back together
__________________
Old 1st May 2013, 12:09   #12
DraC_01
What's a Dremel?
DraC_01 has yet to learn the way of the Dremel
Can I just say, awesome paint job, what kind of spray paint did you use? Automotive? And if you do sell that 580, I'd be more than happy to buy it, could sli it in my bro's comp
DraC_01 is offline   Reply With Quote
Old 4th May 2013, 00:09   #13
TheGreatSatan
Dark Lord of BT!
I got an awesome deal on it - $212!!
__________________
Old 6th May 2013, 03:13   #14
TheGreatSatan
Dark Lord of BT!
I put the balls on the knobs
I don't know if I like it, what do you think?
I want an STL logo on the front of the case and tried ordering it through a metal cutter. The problem is that it's a copyrighted symbol and no one will cut it for me!
So, here I go:
I slowly widdle it away
Till it's done
I just have to strip, sand, paint, and then mount it
__________________
Old 7th May 2013, 01:40   #15
Asouter
Asouter's Avatar
Asouter is definitely a rep cheat.Asouter is definitely a rep cheat.Asouter is definitely a rep cheat.Asouter is definitely a rep cheat.Asouter is definitely a rep cheat.Asouter is definitely a rep cheat.Asouter is definitely a rep cheat.Asouter is definitely a rep cheat.Asouter is definitely a rep cheat.Asouter is definitely a rep cheat.Asouter is definitely a rep cheat.
Not so sure about the base ball knobs (that just sounds sooo wrong ) They're definitely different but really stand out, S'pose you could graduate them 0 to 11 (that a whole one louder than 10)... Nice colours on the case though...
__________________
Finished Projects : D33P THOUGHT : THING : Mini Moto Mayhem
Current Project : BITZA
Asouter is offline   Reply With Quote
Old 7th May 2013, 07:50   #16
KrunchR
Supermodder
KrunchR's Avatar
KrunchR is almost as Godly as yodasarmpitKrunchR is almost as Godly as yodasarmpitKrunchR is almost as Godly as yodasarmpitKrunchR is almost as Godly as yodasarmpitKrunchR is almost as Godly as yodasarmpitKrunchR is almost as Godly as yodasarmpitKrunchR is almost as Godly as yodasarmpitKrunchR is almost as Godly as yodasarmpitKrunchR is almost as Godly as yodasarmpitKrunchR is almost as Godly as yodasarmpitKrunchR is almost as Godly as yodasarmpit
Yeah, I would lose the baseballs. Paint looks good.
__________________
SYSTEM ONE on hold for now....
But my KnuckleDuster makes a Return!
For sale! lian li pc7
KrunchR is offline   Reply With Quote
Old 7th May 2013, 19:17   #17
flame696
flame696's Avatar
+1 on losing the baseballs. I think they are a bit big and just over powers the fan controller. If they were smaller they might look good
__________________
Old 9th May 2013, 01:58   #18
TheGreatSatan
Dark Lord of BT!
I agree, the knobs are going. I'm gonna order one more and turn them into case feet instead.
__________________
Old 9th May 2013, 02:02   #19
Asouter
Asouter's Avatar
What would they look like cut in half ? they'd not stand out as much
__________________
Old 9th May 2013, 14:23   #20
TheGreatSatan
Dark Lord of BT!
They would still be just as wide
__________________
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
