Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 3rd May 2013, 13:48   #1
Meanmotion
bleh
Meanmotion's Avatar
Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.
Bit-tech and Custom PC Awards Winners Announced
Who did you vote as the best manufacturers and retailers of the year? Find out here!
http://www.bit-tech.net/hardware/201...inners-annou/1
Meanmotion is offline   Reply With Quote
Old 3rd May 2013, 14:08   #2
Pookie
Level 0
Pookie's Avatar
Pookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming Saiyan
Well done Corsair. You have to admit that they have come a long way over the last few years and continue to get better and better.
__________________
Unlimited Fibre Broadband 38Inc Per month including line Rental!
http://pulse8broadband.co.uk/fibreoptic-broadband
Pookie is online now   Reply With Quote
Old 3rd May 2013, 14:11   #3
Shirty
Time travelling rogue
Moderator
Shirty's Avatar
Shirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, Shirty
Looks like Caseking have really turned OCUK around then, which can only be a good thing
Also +1 on Corsair, there was a time when I only used their RAM, but I now rock a corsair PSU, hydro cooler, case fans and memory.
__________________
6700K | Z170I | Liqtech 120X | EVGA GTX 980Ti SC | 16GB | 1TB M550 | Node 304 | SS-460FL2 (fanless) | Dell S2740L | Ducky TKL | Logitech G500
I also have a Surface Pro 2, even though I'm not a pro...
Shirty is offline   Reply With Quote
Old 3rd May 2013, 16:06   #4
SuicideNeil
Banned
SuicideNeil is definitely a rep cheat.SuicideNeil is definitely a rep cheat.SuicideNeil is definitely a rep cheat.SuicideNeil is definitely a rep cheat.SuicideNeil is definitely a rep cheat.SuicideNeil is definitely a rep cheat.SuicideNeil is definitely a rep cheat.SuicideNeil is definitely a rep cheat.SuicideNeil is definitely a rep cheat.SuicideNeil is definitely a rep cheat.SuicideNeil is definitely a rep cheat.
Bad luck Scan, I guess people were getting fed up with refused RMAs and botched orders- would have liked CCL to win, but for OverClockers to win, with their reputation.... wow....
SuicideNeil is offline   Reply With Quote
Old 3rd May 2013, 16:12   #5
Maki role
Dale you're on a roll...
Maki role's Avatar
Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.Maki role is definitely a rep cheat.
Must admit I've found Overclockers' service to be truly excellent. I ordered two lots of fittings from them recently, both times the packages arrived the next morning. Most impressive point about that is the second package was ordered on a Friday, arrived on Saturday at 9:15. My only issue with them are their impressively high prices on many components, else I would shop there more often. Free next day deliver with Scan also helps.
Bit confused on the Thermaltake modding award though. Can't really think of a single product of theirs I'd be interested in modding or using in a mod, haven't seen many others do so either. Am I just missing something on that front?
Oh and the article seems to say "Best Modding Manufacturer" twice as if they're separate categories? May need to have a look at that
__________________
Finished Builds: Azure, Vesper, Loramentum, Aetos, Exsectus (Tt UK Modding Trophy 1st Place)
Work in Progress: I Need Healing!, Parvum Argentum, Tower Level 10
Website: http://www.praetex-design.com Twitter: @Maki_Role Instagram: @Maki_Role
Maki role is offline   Reply With Quote
Old 3rd May 2013, 16:18   #6
Meanmotion
bleh
Meanmotion's Avatar
Good spot. Fixed.
Old 3rd May 2013, 18:20   #7
MightyBenihana
Do or do not, there is no try
MightyBenihana's Avatar
MightyBenihana is definitely a rep cheat.MightyBenihana is definitely a rep cheat.MightyBenihana is definitely a rep cheat.MightyBenihana is definitely a rep cheat.MightyBenihana is definitely a rep cheat.MightyBenihana is definitely a rep cheat.MightyBenihana is definitely a rep cheat.MightyBenihana is definitely a rep cheat.MightyBenihana is definitely a rep cheat.MightyBenihana is definitely a rep cheat.MightyBenihana is definitely a rep cheat.
I wonder if and how Scan will react to this.
I have started using OCers more nowadays they are close to my parents and usually have the items I want in stock.
This change came after I had problems with a Scan RMA (bent pins on a motherboard, refused a refund and had to jump through hoops for a replacement) even though the pins were bent when I got the board and I had Scan Sure even if they weren't.
The time for resting on your laurels is over Scan, I hope this is the kick up the a** you have been sorely needing recently.
__________________
4670k/Asus 280x TOP/Asus Maximus Gene VI/8GB Corsair Vengence/Fractal Design Define Mini/Asus Xonar D2X/Samsumg 128GB 840 Pro/Samsung 500GB 840 Evo/Corsair AX 860/Be Quiet! Dark Rock Advanced/Dell U2412HM
MightyBenihana is offline   Reply With Quote
Old 3rd May 2013, 18:36   #8
Woodspoon
Supermodder
Woodspoon's Avatar
Woodspoon is definitely a rep cheat.Woodspoon is definitely a rep cheat.Woodspoon is definitely a rep cheat.Woodspoon is definitely a rep cheat.Woodspoon is definitely a rep cheat.Woodspoon is definitely a rep cheat.Woodspoon is definitely a rep cheat.Woodspoon is definitely a rep cheat.Woodspoon is definitely a rep cheat.Woodspoon is definitely a rep cheat.Woodspoon is definitely a rep cheat.
Agreed, really, really wouldn't use Thermaltake stuff for anything other than poking at arms length with a pointy stick.
Woodspoon is offline   Reply With Quote
Old 3rd May 2013, 18:43   #9
billysielu
Multimodder
billysielu has yet to learn the way of the Dremel
OCUK Forums FTW
billysielu is offline   Reply With Quote
Old 3rd May 2013, 18:50   #10
Kovoet
I Mod, Therefore I Own
Kovoet's Avatar
Kovoet is a Super Spamming SaiyanKovoet is a Super Spamming SaiyanKovoet is a Super Spamming SaiyanKovoet is a Super Spamming SaiyanKovoet is a Super Spamming SaiyanKovoet is a Super Spamming SaiyanKovoet is a Super Spamming SaiyanKovoet is a Super Spamming SaiyanKovoet is a Super Spamming SaiyanKovoet is a Super Spamming SaiyanKovoet is a Super Spamming Saiyan
Damn I was two out and one was overclockers but I'm glad scan have been knocked off their perch. Cannot wait to see the back of the magazine now
__________________
MOBO[ Asus Maximus Formula VII ]CPU[I7 4770K]RAM[Corsair Vengeance PRO Red 2133mhz]SSD's[1TB Samsung EVO, 256GB Samsung, 128GB Mushkin, 128 GT Corsair]GPU[EVGA GTX980]PSU[Corsair AX1200i Red Cables]CASE[Corsair 540] Cooler[Corsair H100i]Screen[Dell U2913WM} Perp[Corsair K70, Logitech G502,Belkin razer N52TE,
HyperX Cloud II]
Kovoet is offline   Reply With Quote
Old 4th May 2013, 06:56   #11
Blackshark
Multimodder
Blackshark has yet to learn the way of the Dremel
Gosh, OC have really turned it around. No suprise on the SSD front, well done Samsung and always up there at the top is Corsair. The C300, M4, M5 series has given enthusiasts a great working SSD that gives up little in speed to the likes of SF whilst having few of the issues. Samsung though are simply knocking aside all others with their all in house products.
Blackshark is offline   Reply With Quote
Old 4th May 2013, 09:05   #12
Shirty
Moderator
Shirty's Avatar
I agree although those are Crucial drives you've mentioned...
__________________
Old 4th May 2013, 10:05   #13
GravitySmacked
Mostly Harmless
GravitySmacked's Avatar
GravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming Saiyan
+ 1 for CCL and I'm glad to see Scan didn't win for a change; their service has gone downhill in recently.
GravitySmacked is offline   Reply With Quote
Old 8th May 2013, 10:35   #14
Phil Rhodes
Hypernobber
Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.
My last order (and it will be my last order) with Scan was 18 months ago; I hope they can't possibly be any worse than they were then.
Phil Rhodes is offline   Reply With Quote
Old 20th May 2013, 16:49   #15
One1ros
What's a Dremel?
One1ros has yet to learn the way of the Dremel
I totally agree with this. What does Thermaltake produce that can be defined as modding product? Fans? The Gorb?
One1ros is offline   Reply With Quote
Old 20th May 2013, 18:23   #16
Fizzban
Man of Many Typos
Fizzban's Avatar
Fizzban is definitely a rep cheat.Fizzban is definitely a rep cheat.Fizzban is definitely a rep cheat.Fizzban is definitely a rep cheat.Fizzban is definitely a rep cheat.Fizzban is definitely a rep cheat.Fizzban is definitely a rep cheat.Fizzban is definitely a rep cheat.Fizzban is definitely a rep cheat.Fizzban is definitely a rep cheat.Fizzban is definitely a rep cheat.
+1 for CCL also.
__________________
-Banana in disc drive error-
To win the battle, is to be prepared to die - Miyamoto Musashi
Originally Posted by RedFlames View Post
Asking to pick between the main parties is like asking which testicle you want to be kicked in, you're gonna get kicked the nuts whoever you pick... Just have to hope whoever you pick aren't wearing steelies...
Fizzban is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
