Reply
Thread Tools View Mode
Old 8th May 2013, 12:45   #1
Kronos
Another grumpy old git.
Kronos's Avatar
Kronos is a Super Spamming SaiyanKronos is a Super Spamming SaiyanKronos is a Super Spamming SaiyanKronos is a Super Spamming SaiyanKronos is a Super Spamming SaiyanKronos is a Super Spamming SaiyanKronos is a Super Spamming SaiyanKronos is a Super Spamming SaiyanKronos is a Super Spamming SaiyanKronos is a Super Spamming SaiyanKronos is a Super Spamming Saiyan
Bitfenix Prodigy. (red & white).Finished.
I scratched one side of my white Prodigy so as I have a mate that sprays cars and the like I decided to get it painted except it suddenly took on a life of its own.
Lying in bed I thought how about I get it powder coated inside and out but remove all the innards first, HHD enclosure, optical drive bay slot, mobo tray and PSU enclosure. So it went from white to red.
First mod as such and I am aware that I have not got photos of everything, IE: the front and top grills stripped so the mesh can be painted and no images of the sides before powder coating.
Stripped ready for painting.
Back from powder coaters.
Top and front original.
Painted.
The feet I am using.
Insides refitted.
With top.
And front and feet.
Rear.
I am still in the process (never again) of shortening the PSU cables and sleeving them white along with all other cables including a new case USB cable replacement from Bitfenix because mine was afflicted with a common problem of faulty cables where only one USB port worked. But I am waiting on that.
That's it for now.
__________________
Carbide 240/Asus Z170M plus/I5 6600K @ 4.6Ghz/Avexir Core Blue Series 16GB /AXP 200 Muscle /Gigabyte FE 1080/256GB Crucial m4/1x1TB & 2TB HDD/ SST-ST60F-P PSU/Dell U3415/CM TK White (browns)/Logitech G400s/.
Silverstone GD05B/ MSI B751A-E33/G840/2x2GB Crucial Ballistix DDR3 Red LED/GTX 260/Kingston 60GB/500GB WD/Corsair CX500/Dell U2711/ E Element Chroma KB /Logitech M518.
Kronos is offline   Reply With Quote
Old 8th May 2013, 12:49   #2
Phame
COOOOFFFFEEEEE
Phame's Avatar
Phame is almost as Godly as yodasarmpitPhame is almost as Godly as yodasarmpitPhame is almost as Godly as yodasarmpitPhame is almost as Godly as yodasarmpitPhame is almost as Godly as yodasarmpitPhame is almost as Godly as yodasarmpitPhame is almost as Godly as yodasarmpitPhame is almost as Godly as yodasarmpitPhame is almost as Godly as yodasarmpitPhame is almost as Godly as yodasarmpitPhame is almost as Godly as yodasarmpit
Nice start man, il watch this!
Phame is offline   Reply With Quote
Old 8th May 2013, 12:57   #3
Kronos
Kronos's Avatar
Thanks.
__________________
Old 8th May 2013, 12:59   #4
Shirty
Here from the future...
Moderator
Shirty's Avatar
Shirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, ShirtyShirty is, simply, Shirty
Very nice KRONOS. Got to love the finish on a good powder coat. Looking forward to seeing it built back up again.
__________________
6700K | Z170I | Liqtech 120X | EVGA GTX 980Ti SC | 16GB | 1TB M550 | Node 304 | SS-460FL2 (fanless) | Dell S2740L | Ducky TKL | Logitech G500
I also have a Surface Pro 2, even though I'm not a pro...
Shirty is offline   Reply With Quote
Old 8th May 2013, 13:03   #5
Kronos
Kronos's Avatar
Needing to get my hands on some Crucial Balistix RAM with Red LED's, at the moment I can only get my hands on 8GB which is 4 more than I need unless I reinstall Windows 7 but the 64Bit version.
__________________
Old 9th May 2013, 08:17   #6
Kronos
Kronos's Avatar
It started off as a quick respray but as mentioned has taken on a life off it's own. I keep changing my mind how I want it to look or how to do things so apart from taking longer than I thought it has also been a steep learning curve.
During the night I decided to spray the PSU white so this morning I have stripped it down and later I will sand and prime.
Initially I was sleeving the cables with white braiding but have switched to white spiral which is easier to fit and looks good so will need to redo the cables already sleeved.
Also have changed my mind about the front fans, instead of two 120mm, which for the life of me I cannot figure out how to install correctly as screw holes certainly do not line up, instead I am going to use 1 x 200mm Coolermaster Mega flow.
__________________
Old 9th May 2013, 09:22   #7
wejjy
Hypermodder
wejjy's Avatar
wejjy is the Cheesecake. Relix smiles down upon them.wejjy is the Cheesecake. Relix smiles down upon them.wejjy is the Cheesecake. Relix smiles down upon them.wejjy is the Cheesecake. Relix smiles down upon them.wejjy is the Cheesecake. Relix smiles down upon them.wejjy is the Cheesecake. Relix smiles down upon them.wejjy is the Cheesecake. Relix smiles down upon them.wejjy is the Cheesecake. Relix smiles down upon them.wejjy is the Cheesecake. Relix smiles down upon them.wejjy is the Cheesecake. Relix smiles down upon them.wejjy is the Cheesecake. Relix smiles down upon them.
Looks good so far mate and I love the colour scheme. Shortening the cables on your PSU will definitely be worth it, I promise, these cases look so much better when everything is tidy inside, and as for plans, they always change and evolve over time, my projects are never ending, it's part of the fun.
__________________
Coolermaster Cosmos II | 3770k @ 4.5Ghz | Asus Z77 Sabertooth | 16gb Corsair Vengeance | 2 x EVGA 680's Sli'd | 256gb Samsung SSD | 4 x 2TB Samsung Spinpoints | Asus Xonar | Fully Immersed in Beautiful H2O using EK's Finest + Aquacomputer Aquaero 5XT
Interior Des(k)ign | BitPac | Bitfenix Prodigy Stacker
Modding is addictive!![/CENTER]
wejjy is offline   Reply With Quote
Old 9th May 2013, 09:48   #8
Kronos
Kronos's Avatar
Thanks. It would have been great if I could have removed the actual plastic ATX connection but I tried everything from a decent set of tools to paper clips but it was not to be.
__________________
Old 9th May 2013, 10:05   #9
wejjy
Hypermodder
wejjy's Avatar
I bought a decent tool from good ol specialtech for mine a while ago, used a few before that and found them useless, but the decent ones should do it, which one did you try?
__________________
Old 9th May 2013, 10:31   #10
Kronos
Kronos's Avatar
A set of these http://www.mnpctech.com/ATX_Molex_Removal_Tools.html and these http://www.specialtech.co.uk/spshop/...-pid-9466.html and bent staples, but I could not get it off, in fact any of the the PSU connections proved impossible to remove.
__________________
Old 11th May 2013, 17:27   #11
Kronos
Kronos's Avatar
All fans fitted with cables sleeved. Have also chopped the bottom plastic thingy to give me a strip of white at the bottom which also covered the original fitting holes. I have also fitted a Bitfenix Recon fan controller.
PSU cover and HHD trays primed ready for painting white.
PSU finally sleeved yet to be tidied up or tested, will not be doing that until I have put the cover back on.
Currently sleeving the front panel cables but only for size purposes as I am awaiting on a replacement for my faulty USB 3 connection.
__________________
Old 11th May 2013, 19:52   #12
mnpctech
bit-tech sponsor
mnpctech's Avatar
mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.
Cool color combo! I think this 1st time I've seen the Diamond Knurl feet on the Prodigy
__________________
My GPU support brackets We Ship International Orders!
mnpctech is offline   Reply With Quote
Old 12th May 2013, 08:47   #13
Kronos
Kronos's Avatar
Beautiful if expensive feet by the way.
I am not really sure how the colour combo took hold, it just sort of happened. Should I do another mod in the future then a lot of planning will take place instead of the way my current mod has happened. Massive learning curve though.
__________________
Old 19th May 2013, 12:02   #14
Kronos
Kronos's Avatar
SSD/HDD and PSU casing finally painted.
PSU reassembled.
Front/side panel cables sleeved.
I am going to get a better camera as my photos are cr**.
__________________
Old 23rd May 2013, 15:18   #15
Kronos
Kronos's Avatar
I only have a crappy (Flip Mino) camera so apologies for the quality.
This has been my first attempt at modding and I have learnt much, I hope it isn't too shabby though I suspect it will be a little blingy for some.LOL.
__________________
Old 23rd May 2013, 15:34   #16
Shirty
Moderator
Shirty's Avatar
Very nice Glenn - although you need a white Recon
__________________
Old 23rd May 2013, 15:41   #17
Kronos
Kronos's Avatar
Yeah, I know, but might see if I can take this one apart and just paint that.
__________________
Old 23rd May 2013, 16:36   #18
Knighthammer
Multimodder
Knighthammer has yet to learn the way of the Dremel
Nicely done.
Knighthammer is offline   Reply With Quote
Old 23rd May 2013, 16:54   #19
dream1
Multimodder
dream1's Avatar
dream1 has yet to learn the way of the Dremel
Gratz !!! Looks great
dream1 is offline   Reply With Quote
Old 23rd May 2013, 16:55   #20
Kronos
Kronos's Avatar
Originally Posted by Knighthammer View Post
Nicely done.
Thanks guys.
__________________
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
