Reply
Thread Tools View Mode
Old 9th May 2013, 04:09   #1
Pennywise
Multimodder
Pennywise has yet to learn the way of the Dremel
TRITON mod, CaseLabs sm8 blue and green build.
I just got done with my newest mod last January, TRITON. I thought I should put up my work log on it here. Let me know what you guys think.
I will be starting a new mod in the next couple weeks. It will be a Mini-ITX build in CaseLabs new mercury s3.
For my build this winter I'm going to be using CaseLabs new Merlin SM8 case,
EVGAs Z77 FTW board, 2 EVGAs GTX 680 Classified Hydros, and an Intel 3770k. I
am still working on the rest of the components. I will be building a custom 5
bay reservoir, feet, and a few other parts.
Thank you CaseLabs for another high quality case.
Thank you EVGA for your continued devotion to the enthusiast community.
Thank You Roccat for your outstanding products.
Pennywise is offline   Reply With Quote
Old 9th May 2013, 12:51   #2
Pennywise
Multimodder
These are my final pictures of Triton. It is featured on the front page of CPU Magazine.
Thank you everyone for your feedback, ideas, and support.
Old 9th May 2013, 12:52   #3
Pennywise
Multimodder
The CaseLabs Merlin SM8 case is smaller than my last build (EpiDemic). It is a single wide case with a variety of options.
The first thing I will be working on is the 5 bay reservoir.
this is my first attempt to see how the water will flow
after getting it all glued together, and building an icycle design into it.
I sanded down the outside to create a frost look to it. I still need to use a larger grit sand paper.
I put together a quick gasket to see how every thing works. I also made a video.
I still have a few other things to do to, but let me know what you think so far.
I put togeather a video of the water flow for you guys to see.
http://youtu.be/kXk-nz6FInw
Old 9th May 2013, 12:52   #4
Pennywise
Multimodder
I've been looking for fans that would go with my build. I picked up an Xigmatek xaf-f1256. It has white leds. not sure if I like the white leds or not. Great fan though. Very quiet and great air flow. Would be nice to have some blue leds in it though.
I've been putting in some leds on top of the resevoir to illuminate the reservoir. This picture only has one for now, but when i'm done it will light it up really well. I will probably put it on a dimmer. I have a couple small tweaks to do on it, but minor ones.
Old 9th May 2013, 12:53   #5
Pennywise
Multimodder
I started working on the feet today. I still have some polishing to do. I also ordered some MDPC sleeving.
Freshly cut
After a little sanding
And some more sanding
Old 9th May 2013, 12:54   #6
Pennywise
Multimodder
Happy Holidays everyone. I've been ordering parts and working on the feet.
I received my sleeving from MDPC. I picked up some Carbon fiber vinyl, and the rest of my fans.
I was playing around with the carbon fiber vinyl a little of a 240 rad my buddy DA gave me.
I ordered some other vinyl to do the rad in my build with.
I am also fabbing up a mount for my pump.
Here is an early picture of one of the feet i wrapped, drilled and tapped. I will be mounting a blue led inside once finished.
Old 9th May 2013, 12:54   #7
Pennywise
Multimodder
So I picked up a d5 pump and a 480 rad today.
Took a picture and quick video for you guys. There is no resistance an I need to turn the pump down a little, so the water is just flying through there. should have less bubbles once turned down.
http://youtu.be/ZNEfJT2YI10
Old 9th May 2013, 12:56   #8
Pennywise
Multimodder
As promised, here are some pictures of what I have been up to the last couple
weeks. First here are some pictures of what I got in the mail.
I talked to the guys at Roccat this week about a mouse. These guys are great.
They are sending me there Kone XTD mouse, and there Isku FX keyboard. Thanks
Roccat.
Blue connectors in as well as my ax1200 connector kit.
The rest of my Fittings, Orings, and Tamper proof buttons.
Picked up this 480 gtx rad from Clamdip on the PDXLan Forums.
I got my Dominator Platinum, and force GT 240 gb ssd in today.
I started out by wrapping the gtx 480 rad with some brushed blue steel vinyl.
I wrapped the koolance block with vinyl and cut out the dark grey metal.
The 2 gtx 680 classies were pretty time consuming to wrap.
I continued on my vinyl wrapping spree by rapping my AX1200, followed by my
drives.
I have about 90% of my wiring complete at this point. I finished the 24 pin,
the 4 pci 8 pins, and the 2 mobo 8 pins. I still have a couple more to do. I
also built, wired and sleeved the feet light and I also lite up the acrylic
peace behind the pump.
Here is the support and mount for the pump that I built.
I did some decals and painting a little yestarday.
Ok, lastly. I need your opinion. Should I wrap the top of the Dominator
memory and put green lettering on top that says dominator. OR, should I leave
it chrome. It looks so nice the way it comes.
Old 9th May 2013, 12:56   #9
Pennywise
Multimodder
The gtx 680 classified hydros come with the red led, that light up the frosted acrylic block in the water bridge. The Led are soldered onto the board, so i covered them up and drilled a hole in the bottom of the water bridge. I made a new acrylic block with a channel board out on the bottom. I ran up some wire through the channel to some blue leds on either side of the acrylic. Looks realy cool. I need to put my dimmer on for my UV lights. they are up way to high.
I then wrapped the cover to the block.
So, I needed to see what the ram would look like with the lettering on it to make up my mind.
Old 9th May 2013, 12:57   #10
Pennywise
Multimodder
I was sick all last week. I did manage to get a few things done though. I sleeved the sata power cables, sleeved the sata
cables, sleeved the 6 pin power cable for the pci slots, wrapped all the dominator memory (Thanks for everyones input), built
a mesh guard for the wires that sit over the top of a fan. Organized some wires, and have been trying to come up with a name
for my build.
I also received a Roccat Kone xtd mouse, and Isku keyboard. I spent the night playing around with the mouse. Is all I have to
say is, WOW, what a great mouse. Besides just the basics of a mouse, comfort, smoothness. It looks amazing. I love the way I
can customize the colors on the sides.
All I have left to do is build a power cable for my pump lighting and fans (I'm just waiting on the sleeving to come in.),
install the wire guard above the fan by the pump, and get some decal work done on the outside.
Old 9th May 2013, 12:59   #11
Pennywise
Multimodder
I will be starting a new build within the next 2 weeks. It will be a Mini-ITX build in CaseLabs new Mercury S3 case.
Old 9th May 2013, 13:01   #12
[ZiiP] NaloaC
I Mod, Therefore I Own
[ZiiP] NaloaC's Avatar
[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan[ZiiP] NaloaC is a Super Spamming Saiyan
A bit garish for my own tastes, but a great job with the cabling nonetheless.
__________________
ZiiP Gaming Community
Sui Generis: i7 5820K, Corsair H105, 16GB Kingston 2133, ASUS X99-S, Samsung 950 Pro 512GB M2, Samsung 850 1TB EVO, Corsair F3 120GB SSD & Samsung EVO 250GB SSD, MSI GTX 970, Corsair HX850W, Corsair Obsidian 800D, AOC 34", Logitech G15, Shogun Bros Ballista Mk-1, Corsair 1500.
[ZiiP] NaloaC is offline   Reply With Quote
Old 9th May 2013, 13:12   #13
torment lm
Danish Viking
torment lm's Avatar
torment lm has yet to learn the way of the Dremel
stunning front panel.
__________________
Viking Customs - WILD
Project In Progress
NitroGlycer
torment lm is offline   Reply With Quote
Old 9th May 2013, 13:19   #14
Boorach
Supermodder
Boorach's Avatar
Boorach is definitely a rep cheat.Boorach is definitely a rep cheat.Boorach is definitely a rep cheat.Boorach is definitely a rep cheat.Boorach is definitely a rep cheat.Boorach is definitely a rep cheat.Boorach is definitely a rep cheat.Boorach is definitely a rep cheat.Boorach is definitely a rep cheat.Boorach is definitely a rep cheat.Boorach is definitely a rep cheat.
Great attention to detail. Really impressed with how well the vinyl wrapping came out too. Expecially on the graphics cards.
Boorach is offline   Reply With Quote
Old 9th May 2013, 13:54   #15
Axoxenon
Do it right the first time
Axoxenon has yet to learn the way of the Dremel
Cool!
Wicked colour-scheme
__________________
Check out my Infestissumam mod
Axoxenon is offline   Reply With Quote
Old 11th May 2013, 18:10   #16
Pennywise
Multimodder
Thanks for the great feedback. I was really happy the way the color scheme came out.
All the green highlights just made everything pop.
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
