Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 10th May 2013, 10:23   #1
Meanmotion
bleh
Meanmotion's Avatar
Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.Meanmotion is definitely a rep cheat.
Fractal Design Arc Midi R2 Review
Fractal is back again with a revised edition of its performance oriented Arc Midi chassis.
http://www.bit-tech.net/hardware/cas...di-r2-review/1
Meanmotion is offline   Reply With Quote
Old 10th May 2013, 13:12   #2
Siwini
What is 4+no.5?
Siwini's Avatar
Siwini has yet to learn the way of the DremelSiwini has yet to learn the way of the Dremel
Looks great, almost as good as my xigmatek utgard. The only thing I'd like to see is a little bigger window
__________________
Win7 Pro 64Bit | I7 860 @4.0Ghz XSPC RS240 | Gigabyte P55-UD5 | 8GB G.Skill 1600 7 8 7 24| Crucial C300 64GB SSD | 2x 1TB Samsung F3 RAID0 | Asus GTX 570 | Asus Xonar DS 7.1 | Logitech Z-2300 | Corsair CMPSU 850 ATX | Xigmatek Utgard | Dell U2410
Siwini is offline   Reply With Quote
Old 10th May 2013, 14:17   #3
Hustler
Hypermodder
Hustler's Avatar
Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.Hustler is the Cheesecake. Relix smiles down upon them.
For goodness sakes, will you guy's go on a photography course or something and learn about lighting, your photographs of this case (and just about all the other cases you review) make it look appallingly drab.
Proper shots, which I had to look up after reading this review, thinking it can't possibly look that bad, show up what a nice quality finish this case has.
Hustler is offline   Reply With Quote
Old 10th May 2013, 14:19   #4
Parge
the worst
Moderator
Parge's Avatar
Parge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming Saiyan
Ok, having been an owner of version 1, its worth knowing that one problem with this case that wasn't (and couldn't have been) covered in this review is the fact that after a few days of use the front grill has two round dust patches on the. Sure, easy to clean with a hoover, but I don't hoover every other day so I found it extremely annoying.
Nice review though.
__________________
NCase M1 - 5820k @4.3Ghz - H105 - GTX 980ti - ASRock X99e ITX/ac - 16GB DDR4 - 3x SSD - 600w SFX - 29" Ultrawide - Xonar U7 - Bassshaker - RAT3 - Quickfire TK - Q90s - Orbweaver - Warthog
Parge is online now   Reply With Quote
Old 10th May 2013, 16:22   #5
Meanmotion
bleh
Meanmotion's Avatar
A fair cop. We'll look to improve these for future reviews and will address those in this review on Monday.
Old 11th May 2013, 01:48   #6
SchizoFrog
I *am* a Dremel
SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.SchizoFrog is the Cheesecake. Relix smiles down upon them.
I like the window, I don't like the tint to it. Could this be some odd thing with just the version you received? I ask as from the images on Fractal's own site seem to indicate no tint or if indeed there is a slight one, for it to be a slight grey colour.
Image 1
http://www.fractal-design.com/img_pr...-R2-W-BL_9.jpg
Image 2
http://www.fractal-design.com/img_pr...-R2-W-BL_2.jpg
So can you confirm with Fractal please?
I also would like to know a little more about the sound proofing, or lack of. Other cases seem to be much quieter and yet many still have fan grills in the front, top and even on the side for GPU cooling. So are there any other factors involved in this? Would sound proofing material placed wherever it can make that much of a difference? Is the Arc Midi R2 just made out of very thin materials that allow sound out?
I love the look of this case but the mentioned issue are massive to me. The window is important to me and any tinting would affect my purchase, I also do still want a quiet PC and would be using quiet rated fans to cool the case, I would also most likely fill all the fan bays with fans but then run them at their lowest settings, while not having a serious overclock if any, on my CPU and GPU.
__________________
SchizoFrog is offline   Reply With Quote
Old 11th May 2013, 11:43   #7
Dogbert666
I benchmark, therefore I am.
bit-tech Staff
Dogbert666's Avatar
Dogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming SaiyanDogbert666 is a Super Spamming Saiyan
We can drop Fractal an email to confirm if you like, but a quick glance around other reviews seems to suggest the tint looks similar to our sample.
We'll look more into the sound proofing issues you bring up on Monday. What I can say for sure is that at lower speeds the three included Silent Series R2 fans are very quiet!
Dogbert666 is offline   Reply With Quote
Old 11th May 2013, 12:21   #8
SchizoFrog
I *am* a Dremel
Cheers Dogbert666, I've had a look as well including some video reviews on youtube and it does seem to be as you say which disappoints me somewhat to be honest. Maybe their own imahes are from a pre-release sample.
I'll be very interested in what you have to say about the sound proofing... :-)
__________________
Old 11th May 2013, 18:34   #9
phoenixck
Supermodder
phoenixck is the Cheesecake. Relix smiles down upon them.phoenixck is the Cheesecake. Relix smiles down upon them.phoenixck is the Cheesecake. Relix smiles down upon them.phoenixck is the Cheesecake. Relix smiles down upon them.phoenixck is the Cheesecake. Relix smiles down upon them.phoenixck is the Cheesecake. Relix smiles down upon them.phoenixck is the Cheesecake. Relix smiles down upon them.phoenixck is the Cheesecake. Relix smiles down upon them.phoenixck is the Cheesecake. Relix smiles down upon them.phoenixck is the Cheesecake. Relix smiles down upon them.phoenixck is the Cheesecake. Relix smiles down upon them.
Good review, you can definitely fit a 240 60mm rad in push pull?
If I wasn't using the optical bays do you reckon I could fit a 360 rad in push pull with only a few extra holes drilled?
__________________
I'll post my rig so i don't have to keep reposting it over and over:
ASUS Sabertooth p79 B3 rev. I5 2500k @ 4.3 (ish), PNY GTX 570, Antec tru power 650w, CM 690 II
To do, put in a water loop, then fry all my components.
phoenixck is offline   Reply With Quote
Old 13th May 2013, 18:13   #10
Dogbert666
bit-tech Staff
Dogbert666's Avatar
Right, in terms of photography, we've replaced a few of the images in this review but the main thing to note is that we'll be investing in some new lighting equipment and paying more attention to this side of things in the future.
@SchizoFrog, I wouldn't call the side panels thick, but they're certainly fairly hefty and could be thinner so I suspect much of the sound is escaping through the front and roof. If you were to fill all the available fan mounts as you said, your options for sound proofing the case would be quite limited. It definitely wouldn't hurt to put some material around the window and all over the right hand side panel, but you would be sacrificing some cable management room there. A couple of other things worth mentioning is that the dust filtering material on the roof/front is already a foam material that will have at least some impact against noise, and also the integrated fan controller is only rated to control three fans. Still, with quieter hardware than ours I think this chassis would still be able to stay fairly quiet, as we were unable to distinguish the noise of the case fans at lower speeds. Hope that helps!
@phoenixck, having quickly looked at the case again today, there is easily room in the front for a 240 x 60mm rad in push pull, and likewise in the roof. With the roof one, this would impede upon the rear exhaust fan and the CPU cooler area, but as you'd likely be water-cooling your CPU this shouldn't matter. Also, as the mounting holes are so offset, even most high profile RAM modules should have enough clearance with a push/pull roof rad. As for your 360 rad idea, if you were to remove the rivets holding the optical drive bay and drill extra holes in line with the offset mounting holes for 240 rads, you should be able to fit the 360 no problem. Even with a 60mm rad in push pull, there'd still be enough room beneath it for all eight hard drive cages too, should you need them.
Old 15th May 2013, 08:14   #11
SchizoFrog
I *am* a Dremel
Not confirmation from Fractal Design about the window tint?
__________________
Old 15th May 2013, 11:54   #12
Dogbert666
bit-tech Staff
Dogbert666's Avatar
Sorry, yes, they have confirmed there is a tint on the window.
Old 15th May 2013, 13:19   #13
SchizoFrog
I *am* a Dremel
OK, cheers Dogbert, now get back to work. :-)
Any new cases coming from Silverstone? Seems an age since they released a case along the lines of the Arc Midi.
__________________
Old 15th May 2013, 23:51   #14
Dogbert666
bit-tech Staff
Dogbert666's Avatar
No worries :-) As for SilverStone, ones we know are in the pipeline include the Raven RV04, Mammoth MM01, and Fortress FT04, as well as the micro-ATX Sugo SG10. We'll be sure to try to get them in as soon as possible!
Old 20th May 2013, 11:36   #15
SchizoFrog
I *am* a Dremel
Dogbert, maybe you can do something for me? When you do a review or talk to someone from Silverstone, maybe you can ask them why all their inverted cases such as the Raven are always set up the reverse of a standard case with the motherboard on the left instead of the right and the window on the right instead of the left? Especially when nearly every computer desk ever made caters for the standard set up of the tower being placed on the right and side of the user.
Having now looked at all three of Silverstone's upcoming cases they are all based that way, with the Raven and the FT04 being almost identical except for the front aesthetics and the sound proofing inside.
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
