Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 13th May 2013, 10:53   #1
Gareth Halfacree
WIIGII!
bit-tech Staff
Gareth Halfacree's Avatar
Gareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming SaiyanGareth Halfacree is a Super Spamming Saiyan
Mad Genius Controller prototype unveiled
Break-apart motion-tracking system demoed.
http://www.bit-tech.net/news/hardwar...s-controller/1
__________________
Author, Raspberry Pi User Guide Fourth Edition, 21 Brilliant Projects for the Raspberry Pi and more | gareth.halfacree.co.uk | twitter | keybase.io
bit-tech news correspondent, Custom PC columnist, other things to other people
I'm a filthy freelancer! Hire me! | Need a VPN? Try AirVPN!
Gareth Halfacree is online now   Reply With Quote
Old 13th May 2013, 11:47   #2
SAimNE
Multimodder
SAimNE has yet to learn the way of the Dremel
now to combine this with the completed version of those gloves that let you "feel" stuff... and i shall cry tears of joy.
SAimNE is offline   Reply With Quote
Old 13th May 2013, 12:59   #3
edzieba
Virtual Realist
edzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyan
From the looks of it, they've pulled the pad and coil boards from Sixense's Hydra, crammed them into two halves of a 360 gamepad with the buttons wired up, and added a mediator (probably an ubiquitous ARM SoC) to mediate the raw position and orientation data in order to do the gesture recognition. Or maybe the mediator is still done in software on a demonstrator PC and they don't have any self-built hardware yet. The cables do look like they run into a wooden box that could hide the transmission coils from a disassembled Hydra.
If they are actually using their own magnatometer tech (and manage not to fall afoul of Sixense' or Polhemus' patents), and reveal raw position & orientation data with minimal delay (real, without any gesture recognition nonsense), then this could take over from the Razer Hydra as the controller du jour for the Oculus.
Unfairly cynical? Maybe. But I've seen plenty of 'revolutionary' motion control and tracking systems that have turned out to be anything but that I now assume them to be either scams or massive naivety until some hard data is provided.
edzieba is offline   Reply With Quote
Old 13th May 2013, 15:00   #4
Zurechial
Elitist
Zurechial's Avatar
Zurechial can run CrysisZurechial can run CrysisZurechial can run CrysisZurechial can run CrysisZurechial can run CrysisZurechial can run CrysisZurechial can run CrysisZurechial can run CrysisZurechial can run CrysisZurechial can run CrysisZurechial can run Crysis
Interesting approach, Horrible latency.
__________________
Main: CM Cosmos II <-> i7 4770k <-> EVGA GTX 780Ti SC <-> Sabertooth Z87 <-> 16GB DDR3 <-> Samsung 840 Pro <-> Crucial M4 <-> Dell U2410 <-> HP ZR24w
Laptop: Core i7 2670QM<-> GTX 570M <-> 8GB DDR3 <-> Crucial M4 <-> XMG P511
Zurechial is offline   Reply With Quote
Old 13th May 2013, 21:45   #5
Sloth
#yolo #swag
Sloth's Avatar
Sloth is a Super Spamming SaiyanSloth is a Super Spamming SaiyanSloth is a Super Spamming SaiyanSloth is a Super Spamming SaiyanSloth is a Super Spamming SaiyanSloth is a Super Spamming SaiyanSloth is a Super Spamming SaiyanSloth is a Super Spamming SaiyanSloth is a Super Spamming SaiyanSloth is a Super Spamming SaiyanSloth is a Super Spamming Saiyan
Originally Posted by Article
That compatibility does come with a cost, however: because the system watches for gestures in order to transmit a control signal to the game, unavoidable delays crop up which threaten to ruin immersion. In the demonstration video, which sees the controller connected to an Xbox 360 running Skyrim, this is seen most clearly during the hammer-swing portion: the hammer begins swinging in-game after the player has fully finished the swinging motion. 'The time delay between moving the controller and swinging the sword or warhammer is part of Skyrim' the team claims in defence of its technology. 'It's not a delay in the controller. The controller fires the command as soon as the player has done the motion.'
The claim of unavoidable delays, is that made from looking at the video or an actual reported drawback from the creators? It would seem that the quote from the developers clarifies what appears to be huge latency.
With just a little bit of figuring what's actually going on in terms of what the controller is telling the game it would seem that the "swing hammer" motion must be entirely completed for the controller to recognize it and report a "swing hammer" input to the game, which then begins the hammer swing animation. The controller is effectively turning the "swing hammer" motion into a standard input like "X button" since Skyrim doesn't support real time motion capture for melee weapons.
Just look at the movement and aiming, particularly the over the shoulder portion, to get a better idea of latency involved. It's not extreme.
__________________
Intel i5 2500k | Gelid Tranquillo | ASUS P8P67 | G.Skill Ripjaws 8GB | XFX 7970 Black Edition | SeaSonic X650 | Intel X25-M 160GB | WD Caviar Black 1TB | CoolerMaster HAF922
Dell U2412M | 2x Samsung Syncmaster 931B | SteelSeries Siberia V2 | Razer DeathAdder 2013 | Leopold FC200RR/AB | Leopold FC200RC/AB
Sloth is offline   Reply With Quote
Old 14th May 2013, 08:00   #6
Gareth Halfacree
WIIGII!
bit-tech Staff
From watching the video. I couldn't very well write an article about the video without watching it, could I?
Who said it was extreme? I describe the delay as "unavoidable," not "extreme" or "huge" - both words you have used in your comment. As the article explains, and as confirmed by the developer, the system works by recognising the gesture and *then* triggering the action. As a result, the delay - the start of the in-game attack action always occurring at the end of the gesture motion - is unavoidable, a drawback of the technique used.
Now, whether that would "ruin immersion" as I claimed depends entirely on the player: it would certainly annoy me, but then again I'm not a huge fan of gesture recognition gaming in the first place.
__________________
Reply
Tags
dualshock 3, game controller, mad genius controller, mad genius controllers, motion tracking, playstation move, skyrim, sony, wii
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
