Scratch Build – In Progress ROG Crawler-completed
Discussion in 'Project Logs' started by Pranja, 14 May 2013.
  1. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Few months ago I showed one concept. Concept that now will became reality.
    I present you ROG Crawler-with support of:
    ASUS Republic Of Gamers
    EK Waterblocks
    ENERMAX
    Thanks to all sponsors for their generous support, and also thanks to my friend Guriga who helped me to find some components that I needed for this project.
    Like all my scratch builds, Crawler also starts as bunch of parts on the floor.
    After sorting all of the parts, I started gluing:
    -rear legs:
    -shoulders:
    -bottom part of torso:
    -shoulders and neck:
    -front legs:
    Assembled rear legs (without feet).
    Gluing of feet.
    Start od torso assembling.
    I attached all fully assembled legs on bottom part of torso.
  2. dombak1608
    dombak1608 What's a Dremel?
    3 Apr 2012
    Another awesomeness from you. :jawdrop: :clap:
  3. Guest-16
    Guest-16 Guest
    :D:D:D Can't wait to see this.
  4. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Hvala ti. ;)
    Thank you Bindibadgi. I am glad that you like this build. :)
    You will see it finished soon since I only have three weeks to finish it until ASUS event in Belgrade.
  5. 666painkiller
    666painkiller If only....
    23 Jun 2010
    looks great....can not wait to see the finished ROG Crawler
  6. Asouter
    Asouter --------
    18 Jan 2012
    Yay, Liking this lots, Subbed
  7. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Thanks mate. ;)
    Glad to know that you like it. :thumb:
  8. KrunchR
    KrunchR What's a Dremel?
    22 Apr 2008
    Nice components, good start!
  9. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Thank you KrunchR. :D
  10. Boorach
    Boorach Minimodder
    16 Feb 2013
    Wow, loving the design. Should be awesome once finished. Good job.
  11. Azariel
    Azariel Minimodder
    23 Oct 2008
    You're on a roll it seems Pranja!
    But looking awesome as usual! Quite big though! What will be the total size?
  12. Phame
    Phame COOOOFFFFEEEEE
    17 Sep 2012
    I want to see moar now please!
    Such schweet gear to work with, I know you will do fantastic things with it as always! :D
  13. Waynio
    Waynio Relaxing
    20 Aug 2009
    More techno insect inspired awesomeness, yes please. :D:clap:
  14. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Tahnk you Boorach. It will be finished in three weeks. ;)
    Well, you know me-I am always on the roll. :D
    Hight is sbout 120-130 cm, shoulder part is 60 cm wide and total windth (measured from toes to toes) is 100 cm. It's biggest case I ever build.
    Thank you Phame. :thumb:
    I will do,sir. :D
  15. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Update time!
    Ribbs are stacked and assembled in one piece.
    Placed on rest of the structure.
    Shoulder part is addred on top.
    Pics with half finished head-since eyes are not installed, I put my protection glasses. :D
  16. Asouter
    Asouter --------
    18 Jan 2012
    It looks soooo menacing, like it'd blast you into oblivion for just looking at it. Cracking stuff it's good to see original ideas
  17. KrunchR
    22 Apr 2008
    ^^dopnt look at him! He doesn't like you!
    Great mod.
  18. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Well, that is what heppens when someone from ASUS tell me to make something "like Terminator". :hehe:
    This was my first concept I made for them: https://www.dropbox.com/sh/pr0fb9zvz9sjhd7/1eul3ERCdI
  19. Pranja
    Pranja Blackwolf
    18 Dec 2011
    :hehe: Wait until he gets eyes. :D
    Thanks!:thumb:
  20. Waynio
    Waynio Relaxing
    20 Aug 2009
    Love it. :D:rock:
    And I love Asus for suggesting such craziness to someone who can, "do a Terminator". :D:clap:
    Even just the prototyping stage is looking like some mad advanced building as the torso but can definitely see the shaping up of a freaky monster robot, excellent stuff. :D
    I'm a bit excited. :blush::D
