Scratch Build – In Progress Project THINKTANK - Finished [High Res Photos] 18th April: Post #45
Discussion in 'Project Logs' started by GamerIDGoesHere, 25 May 2013.
  1. GamerIDGoesHere
    GamerIDGoesHere www.^.com
    3 May 2012
    Hello everyone and welcome to my first ever scratch build :D.
    I've been patiently waiting to make this for an extremely long time, so here we go.
    So the main inspiration for this build and the colour scheme came from looking at all the amazing watercooled mods on here and the colour scheme is almost directly derived from the one l3p used in his d3sk.
    The shape of this is actually extremely similar to that of my logo as you can see. I dont know where I came up with the idea for it but its mine, its unique and I think its kind of cool :).
    The actual case will be almost entirely made from transparent black acrylic, apart from a motherboard tray from Mountain Mods and the eyes which will be made from a UV reactive green transparent acrylic.
    Firstly, I'll give you some specs of my current PC, in which the parts will be used for the build.
    CPU: i7 3770K w/ EKWB Supremacy Acetal CSQ
    MOTHERBOARD: Asus P8Z68-V EDIT: This is now a Gigabyte G1 Sniper 3
    GRAPHICS/GPU: 2x EVGA GTX 680 4GB+ Backplate in SLI w/ Hydrocopper waterblocks Yay! EDIT: This is now 3x 680s
    RAM/MEMORY: 16GB Corsair Dominator RAM 1866MHz w/ EKWB Acetal CSQ Dominator
    PSU: Corsair AX1200 Gold
    I am also going to watercool the CPU, GPU and RAM.
    I will add what other watercooling parts I am using on the pictures they appear in the pictures.
    Okay so initially I wanted to plan this exactly right so that everything fit perfectly, heres a Sketchup picture of my planning (I'm not very good with Sketchup :sigh: )
    And heres a 1:1 cutout I made so it will be easier to make the acrylic
    Yay its like presents!
    New GPU's :)
    Slim DVD Drive
    Heres my current setup now:
    And now into the fun stuff - watercooling :) - Coolant to flush rad and loop if I need to (also random surprises?!) Thanks to the guys at the Kool Room for the random free stuff
    HYDROCOPPERS!!! (Got the only ones, found them on eBay by chance)
    Massive Box finally arrived from FrozenCPU :)
    Sleeved 140mm fans
    Gonna use Monsoon Free fittings entirely for this build (except for Crystal Links and a SLI fitting)
    1 of 5 bottles of Coolant
    And finally got around to cutting out the acrylic, I have 3 of these pieces, this one it the middle piece, with a carbon fibre wrapped Motherboard Tray from Mountain Mods and a Bitspower Upgrade 150 Res with a Swiftech 12V pump :)
    Zoomed in for better clarity:
    Now the FrozenCPU box looks like this:
    Thats all for now :) :dremel: :dremel:
  2. The_Crapman
    5 Dec 2011
    This looks like it'll be interesting. Why not call it Modbot?
  3. GamerIDGoesHere
    3 May 2012
    Sounds good :)
  4. GamerIDGoesHere
    3 May 2012
    Small Update!
    Okay so here's a small update on how things are going.
    I have just about cut all the holes out on the acrylic, but had to remake the middle piece in a thicker one for sturdiness.
    AND I received a new motherboard in the mail which I bought :) sorry for the bad quality/blurriness
    Not sure if its DOA or not as it was apparently thrown over my front gate. So fingers crossed (will check on the weekend [I have looked at it and it all looks alright except I had to buy a separate IO shield as mobo didnt come with one :worried: ])
  5. Darkwisdom
    Darkwisdom Level 99 Retro Nerd
    27 Aug 2011
    Thrown over your front gate?! I'd take up a complaint with whichever company delivered it. If it's broken it's their fault.
  6. GamerIDGoesHere
    3 May 2012
    My thoughts exactly :sigh: I just hope it's not broken because I'd actually like to use it soon
  7. Cheapskate
    13 May 2007
    I imagine it was treated far worse on the way to your front gate. The box IS frisbee-shaped, after all.
  8. GamerIDGoesHere
    3 May 2012
    Haha :) well the box actually doesn't have any markings or damage on it (besides the cosmetic bullets) so we'll see (the picture might be misleading I know)
    - Dan
  9. GamerIDGoesHere
    3 May 2012
    Success Update!!!!
    So... the motherboard... IS NOT DOA. :rock::rock::rock::rock::rock:
    So thats very awesome :)
    This is the new one which has a small hint of green on the side
    And this one shows the space in between because for some reason the 4 PCIe x16 3.0 lanes have the bandwith in order x16,x8,x16,x8. So my 680s (which I've decided to keep) are in lane 1 and 3 (if more hydrocopper blocks pop up then those spaces may be filled :) )
    Thats all for a quick update, I will be able to do some more on the case next week hopefully.
  10. GamerIDGoesHere
    3 May 2012
    Guess what popped up!?
    So in the last week a GTX 680 Hydrocopper went on sale on eBay. I contacted the guy selling it about the waterblock, and turns out he had another waterblock which he'd used on a different card. So if I ever wanted to upgrade to a third 680, here was the chance. I purchased the block and look whats on its way!!!
    So that makes a total of 3 waterblocks when it arrives! :clap: (If I can find some money to put aside for it, ill try and buy a third 680 before watercooling)
    Might be able to get a case update out by next week, didn't get a chance this week :wallbash:.
    Pranja likes this.
  11. Jeti
    Jeti What's a Dremel?
    9 Sep 2012
    Subbed. Looks like this is gonna be nice.
  12. GamerIDGoesHere
    3 May 2012
    Thanks man :). Should hopefully be able to get an update out next week for the case, I've been really busy lately.
  13. GamerIDGoesHere
    3 May 2012
    Hydrocopper Block Arrival and other news!
    Hi,
    So unfortunately I don't have a case update this week, but there will 100% be one next week for sure.
    What happened in the last week however was good anyway.
    So firstly, I bought a 3 way SLI bridge cover from ColdZero, however it arrived in the wrong colour, because they dont print the order notes when they print the order to make it.
    I emailed them and Ricardo said that it was a mistake and said he would send me a new one free of charge! :lol: So that arrived and is now blu-tacked in place.
    Then my 3rd Hydrocopper block arrived with a bit of residue from the previous owners coolant (I'll make sure to flush the system first with clear coolant before I put in the actual coolant)
    Unfortunately, as you can see, no thermal pads came with it (Though the screws and plate did so thats ok)
    Due to the lack of thermal pads and because my other 2 hydrocopper blocks have some ripped thermal pads, I bought 4 new thermal squares (in case I stuff one up)
    Also, I managed to get a stable overvolted overclock on my 680s :naughty: of 1202mhz base clock, 1254 boost clock and 7010 mhz mem clock running at 1.212v (the fans are really loud trying to keep the GPU's under 60C so its a good thing I'll be watercooling :D Also the skin is my custom Precision X skin I made that I use :)
    So thats it until next week! Will definitely have an update as I want to make some good progress!! :dremel::dremel:
  14. GamerIDGoesHere
    3 May 2012
    Case Update!
    Ok! So I have a case update. Currently the middle piece is too thin so I'm going to re-cut it in 10mm thick (its currently 2-3m), but I'll leave the other panels be. This is because all of the components will be put on the middle piece so it will need quite a bit of sturdiness.
    This is the old middle piece:
    This is the new piece of acrylic which will be cut out.
    This is the first of the side panels (there are 2 cut out). This specific one will have the back of the PSU coming out of it.
    This is the old piece with all the measurements for the new one (they need to be perfect so that the new piece fits with the other 2 that I already have cut.)
    Thats all for today. I have some free time most Wednesdays now so updates should become more regular every week.
  15. The_Crapman
    5 Dec 2011
    I would strongly recommend you remove the old thermal pads and use the new ones anyway. I'd also see what the contact is like without the pads and see if you can use paste instead.
  16. GamerIDGoesHere
    3 May 2012
    Yeah, thats a good idea. I will do that then. Thermal paste is an interesting idea as well.
  17. OrangeClockwerk
    OrangeClockwerk Clockwerk Industries
    28 Jul 2013
    Nice work, very interesting, subbed.
  18. GamerIDGoesHere
    3 May 2012
    Thanks mate :)
  19. GamerIDGoesHere
    3 May 2012
    HUGE UPDATE
    OK, so I've been a bit slack with last weeks update :grr:, but I have it and this weeks update here and now in a super massive update!
    I'll start with last weeks work/update:
    So this is the cut out PSU hole for the side of the case
    This is the new middle piece in 10mm solid black acrylic, the ear is cut off on the left because behind the motherboard tray there will be a slim DVD drive and power buttons
    Here is the saw in action!
    And here is the newly cut out base piece with markings for holes for a PSU grill and for the Radiator
    Ok, now this is on to this weeks update:
    This is an idea of how it will look on one side (the PSU grill has been cut out and the rad holes have too, they're just hard to see)
    Here is the other side, showing the rad holes with the metal grill
    Here are the rad holes at a better angle without the metal grill on top
    Here is a closer shot of the PSU grill
    Here is a shot of the protective paper peeled off on one side of the left side piece and prepping the bottom piece for gluing
    Now it has been glued and is being held so it can set over night
    Here is what it looks like from the other side
    And some tape to hold it at a perfectly perpendicular angle with the metal supports
    That's all for this week and last week, next week I will try to remember to post the pictures on the day haha.
  20. GamerIDGoesHere
    3 May 2012
    Coming together at last!
    Before I start, why the 3 stars guys? :(
    Ok so, today I did some gluing, but first heres a picture of the side after it has been glued
    Heres a picture demonstrating how it will look after
    Here is a picture of the back after gluing the middle piece and of the support triangles in place
    And a last picture with everything in place for today :clap:
    That's all I had time for this week, next week I'll start cutting out and gluing the side pieces and work my way up to the top.
